I have a toshiba l 300 satellite and lcd is flickering at the botom with white stripes showing the same things i ll move from the top. for example a shortcut...from vga output all is ok
Does the screen change when you move the lcd back and forth could have a loose cable to the lcd.
Posted on Oct 22, 2013
jonb3838
  • 237 Answers
SOURCE: Toshiba Satellite Laptop 1115-S103 trouble shoot VGA & projector
it should be f5 if not then look for an icon that has a computer screen on it
Posted on Apr 08, 2009
frankzjm
  • 191 Answers
SOURCE: NO VIDEO OUTPUT FROM LCD OR EXTERNAL MONITOR ON TOSHIBA SATELLITE L20 LAPTOP
you may do follow steps
1) eheck memory : reseat all RAM or change other same model RAM
2) take out wireless card at back of laptop MINIPCI. try it
3) still nothing run, your otherboard hardware damaged, need to change the motherboard. the parts please reference here
http://shop.ebay.ca/items/__Toshiba-Satellite-L20-motherboard_W0QQ_kwZToshibaQQ_kwZSatelliteQQ_kwZL20QQ_kwZmotherboardQQ_ckwZlaptop?_trksid=p3286.m104.l1200
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 22, 2009
Santhosh_7
  • 233 Answers
SOURCE: My Toshiba Satellite M305D-S4830's screen will
I recommend you to reinstall the display drivers of your laptop as the issue may occur due to the corrupted display drivers.
Uninstall the display drivers from Device Manager.
Expand Display devices.
Right click on the display device and select Uninstall.
On restarting the laptop, windows will detect the device and reinstall the display drivers.
You can even install the display drivers from your notebook support website:
www.csd.toshiba.com
Posted on Jun 29, 2009
maydude01
  • 22 Answers
SOURCE: Flickering Screen on Model P105 Toshiba Satellite
Flickering screen it means that the resolution of your graphic are to high for the resolution of your tv, lower the graphic resolution on your computer and you will see it will work.
Posted on Aug 11, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Toshiba Satellite L305 no VGA signal to TV
Try to roll back the driver on the Toshiba...there are times when the current driver will get corrupt out of the blue.
Posted on Aug 28, 2009
Toshiba satellite L775d clock runs fast
The CMOS Battery is bad. The name used by Toshiba is RTC Battery. (Real Time Clock)
Replace it.
1) Remove ALL power. Remove the AC adapter (Charger) and Battery.
2) Follow Anti-Static Precautions.
With a laptop this means buying an ESD wrist strap, and wearing it.
Average cost is around $3 to $6. (Electro Static Discharge)
Connect it's alligator clip to a good ground source.
This is one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Use an ESD wrist strap, and your laptop will be safe.
3) This is a pictorial guide showing, and detailing how to disassemble a Toshiba Satellite L675D Notebook PC. You'll find it also works for the Toshiba Satellite L775D Notebook PC,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/dismantle-laptop-1.htm
This is Page 1. Access to Page 2 is provided at the top of the page, and bottom of the page;
Page1::Page2::Find another model (In White)
Step 17 shows you where the CMOS Battery is located. Click on the photo to enlarge. (You can click on any of the photos to enlarge)
A note on the Keyboard Cable connector on the motherboard, and removing the Keyboard;
The Keyboard Cable is an FFC.
Flat Flex Cable.
As such, it is just a flat ribbon cable with no connector, on the motherboard end of the cable,
(The Keyboard Cable is detached from the motherboard, not the Keyboard)
A) http://en.wikipedia.org/wiki/Flat_Flex_Cable
B) http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The connector on the motherboard is a ZIF connector.
Zero Insertion Force.
This connector is shown in Steps 9 and 10.
Click on the photo in Step 9.
Note the white rectangular 'bar'.
This part of the ZIF connector is permanently attached to the motherboard. It is stationary.
Note the two tabs pointed out by the Yellow arrows.
This part of the ZIF connector moves.
As directed by the arrows, the top part of the ZIF connector moves towards the LCD screen.
This is seen in Step 10.
The top part ONLY moves VERY LITTLE.
The ZIF connector DOES NOT come completely apart.
The top part acts like a wedge, and wedges the Flat Flex Cable in the bottom part of the ZIF connector.
Point?
DO NOT move the top part TOO FAR. As said the ZIF connector Does Not come completely apart.
If the top part is pushed too far, and the ZIF connector comes apart, it is broken.
This means Motherboard Replacement.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 31, 2012 | Toshiba Satellite L775DS7220 Notebook
White stripe on monitor
I suggest try to isolate the problem of the machine. Try loading to BIOS and see if the white stripe on the monitor exist, If happens that it have the white stripe it means its already a hardware, it could be a problem with the LCD or the cable connector from the LCD to the Motherboard.
May 09, 2011 | Toshiba Satellite P105-S6104 Notebook
My Toshiba P105 has a vertical white stripe on its monitor. Any help is appreciated.
A vertical white stripe means a portion of the lcd has failed...it will continue to get worse as time progresses. The ONLY way to fix it is to swap the lcd out with a working one. It isn't a loose connection, etc.
Mar 18, 2011 | Toshiba Satellite P105-S6104 Notebook
Samsung LCD monitor (SyncMaster 710v) displaying white stripe.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 21, 2010 | Samsung SyncMaster 172N 17" LCD Monitor
Laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
Aug 15, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
LCD problem
if the screen flickers and goes white, it could be your lcd screen (the board on the lcd) or the lcd cable. i would suggest replacing the cheapiest which would be the lcd cable. You could also use the laptop externally and use it that way. Or just get a HDD caddy and change the securities and youll be able to get your info on any other laptop.
Nov 02, 2007 | Toshiba Satellite A105 Notebook
LCD monitor problem
What you described sounds like a loose LCD cable inside. Does it flicker or have video distortion when it's moved?
Jun 27, 2007 | Toshiba Satellite A105-S2716 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
