Question about SEJU USA, Inc SafeDrive Pro Alcohol Breathalyzer Breathalizer Tester
Can't calibrate my Safe- Drive alcohol detector
It says need to calibrate
Follow the direction of the radar detector. Usually you push the button sequence for calibrate and you drive the car in two circles so it can calibrate the compass.
Jan 28, 2014 | Passport 8500 Radar Detector
93 Corvette engines will not turn over with key
Does it have an alcohol detector fitted? Is the alcohol detector stopping the car from starting. Its meant to do that unless you prove you have no alcohol on your breath.
Dec 15, 2013 | 1991 Chevrolet Corvette
I hav3e a Whistler 1765 unit and when I tried to transfer it to a new car it would not calibrate, even after 5 tries. It was "stuck" on 315 degrees. Then the display changed and was stuck on...
There could be few reasons for this.
1. There is strong magnetic field near the radar detector. This could be even car speakers.
2. There is power lines going above the place where you are trying to calibrate.
3. To complete calibration you need to press both the volume control buttons while the vehicle is parked.. The display will show "CAL MODE". Then slowly drive at least 2 complete circles while in calibration mode. Then again press both the volume control buttons for 2 seconds until it beeps and shows " CAL DONE" in the display.
Sep 03, 2011 | Whistler Vehicle Parts & Accessories
Manual is not clear how to calibrate detector where can i get a further guide for whistler xtr -540
On the bottom of the unit there should be a sticker that calls out the steps to calibrate the compass.
Jan 02, 2011 | XTR540 Radar Detector
Just bought a porshe with a calibre radar detector
Surf the internet (Porsche calibre Houston) & you'll find what you are looking for.
Sep 19, 2009 | Calibre Radar Detector
Calibrating my cobra radar detector
I dont know of any radar detectors that need to be calibrated. To calibrate the radar, you would need a source of RF energy like a radar gun and a ton of specialized equipment.
Just turn it on, place it up high enough on the windshield or dash so that it has a clear "view" of the road. Suction mounts on windshields get the detector higher and it offers you a better view and an earlier warning as it can "see" over the hill better.
Jul 21, 2009 | ESD 6060 Radar Detector
Service required
If this sounds like a dashboard alert for a fault then you need to have your car diagnosed by a computer to find the exact fault.It works out to be cheaper..Check digimotolite on google ...
Jun 15, 2009 | Passport 8500 Radar Detector
Early Warning EW-3400 Radar Detector Digital Compass Calibration??
I looked at another simuilar Detector and read on Digital Compass Calibration and through the process of elimination found that if I Press CITY for 3 sec.'s COMPASS CALIBRATION showed on the display. Then it says TURN YOUR VEHICLE SLOWLY 2 TIMES to CALIBRATE. Then press the CITY button to complete the calibration. Done. It worked my Early Warning EW-3400 Radar Detector's Compass is now Calibrated.
Thanks for asking.
May 11, 2008 | EW3100 Radar Detector
SEJU USA, Inc SafeDrive Pro Alcohol Breathalyzer Breathalizer Tester Logo
620 people viewed this question
Top SEJU USA, Inc Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a SEJU USA, Inc Health and Beauty Expert? Answer questions, earn points and help others
