Question about Kenmore Refrigerators
On my Kenmore model 59669932011, with the freezer at the bottom, there is sort of a "hissing" sound coming from the freezer a few times during the day. Why is that? It seems normal, but where does it come from?
  • Kenmore Master
  • 17,162 Answers
The unit has an auto defrost and when it turns on, there is a heating coil that gets red hot like a stove burner. It melts the ice on the evaporator coils. That is the sound that you are hearing.
Posted on Oct 21, 2013
Testimonial: "It makes perfectly sense... Thank you!"
  • Anonymous Oct 31, 2013
    I was having similar problems and my friend told me she called refrigerator repair in Las Vegas, NV and that it helped her out a lot so I'll probably try out the place she used.
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Makes a hissing sound in the freezer side and i see a puddle of water at the back
Defrost heater may be getting defrosted ice on it causing the sound because it's hot. It won't hurt anything. The water from the melted frost drains out a drain hole at the bottom of the freezer. If it gets stopped up it will come out the freezer door onto the floor.
Mar 09, 2011 | Kenmore Refrigerators
Inside of freezer on the bottom on the back lit up red as though on fire, heard a hissing sound as though water was leaking on hot surface. whats happing?
It's defrosting. Depending on your make and model, it'll do that a couple of times a day. There is a heating element behind that panel that's on a timer. The element looks like a bake element in an electric range, sort of. It's doing what it should be doing. The hissing is the frost/ice being melted off of the evaporator and dripping onto the element. All normal.
The end.
fil
Mar 01, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
We have a Kenmore side by side refridge serial #55251 that was making a hissing sounds. We looked at the bottom of the inside freezer and there appeared to be an element that was very red and water was...
Your fridge is fine it was in defrost mode during this an element heats up to melt any frost and ice in the freezer. But yes the hissing sound does sound alarming but is perfectly normal. hope you have a nice day
Aug 15, 2010 | Kenmore Refrigerators
I have the Kenmore refridgerator with the freezer on the bottom, and lately it has been making a loud noise when it comes on. It has been doing this for a week or more, today I noticed that the temperature...
You need to check for the refrigerator level, drain pan, condenser fan, evaporator fan and inspect the compressor mounts for the cause of noise. Any popping or hissing sound is normal on frost free refrigerators.
Good luck
Jul 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hissing inside the freezer
This is 100% normal, the element is there to get red hot and defrost all the ice off the freezer Evaporator, if you touch it you'll burn your finger. It's called a defrost element and comes on for upto 30mins every 6-12hours depending on the timer. Without it the freezer would be a block of useless ice cheers
Mar 27, 2009 | KitchenAid Refrigerators
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Loud shreaking sound coming from Kenmore Frost Freezer.
The fan behind the molding is hitting some ice build up and causing the sound. Sounds like the timer for the defrost isn't working. Try to turn off the unit for few hours or take off the molding in the freezer compartment and remove the ice build up with hair dryer.
Nov 23, 2008 | Kenmore Freezers
Defy Side x Side Refrigerator Freezer
Hissing is not good. You could have lost the gas.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
90 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
