Question about Toro 3 Blade Set For Wheel Horse 48" Deck 106637 106078
Just replaced the hydrotransmission pump on a Wheelhorse D200 but cannot get the pump to work. Any suggestions?
  • Toro Master
  • 15,557 Answers
Did you prime it first?
Posted on Oct 21, 2013
  • Julia Foster
    Julia Foster Oct 21, 2013
    We did prime it but still nothing. Thanks!
  • Brad Brown Oct 21, 2013
    What is the model number of the mower and the pump?
HELP! How do i replace the main selector button on the back of my Nikon d200? The large button that toggles picture review? My broke and I need to replace it. Thanks! Patti
Patti, replacing switches requires the outer case to be dismantled and a job for a service person. I don't know where you are in this world but the D200 is still a good camera and well worth the dollars to repair it. If it were one of mine I would send it back to Nikon or a Nikon authorized repair center.
Probably not the answer you wanted but working on these cameras isn't like changing a light bulb.
Mar 04, 2011 | Nikon D200 Body Only Digital Camera
I can't tell the diff between VR and VR OFF with my Nikon 18-200 lens. Is there a foolproof way to tell if VR is functional?
Charles, I can save you the effort. The D200 lacks the menu item I suggested and will not show any symbols in the viewfinder or LCD to indicate which VR setting you have the lens set to.
But Ken Rockwell's guide to the lens has a big clue: VR takes a moment to stabilise, so you ideally need to half press the shutter release and wait a second or so before firing the shutter.
I don't want to plagiarise his excellent article, so instead suggest that you click here to read what the man has to say himself. He discusses the benefits of your lenses VR early in the article, but you may want to skip right down the page to the heading, "How to use the VR".
Ken has also created an excellent alternative D200 users' guide, click here.
Good luck, and please take a moment to rate my reply.
P.S. If the hotlinks don't work then the 18-200 lens review is at:-
http://www.kenrockwell.com/nikon/18200/18200-vr.htm
and the D200 guide is at:-
http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Aug 05, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
I've recently upgraded to Windows 7 and now Bridge CS3 does not recognize raw files in my Nikon D200. D700 works fine all raw files on hard drive are okay. Have any suggestions?
Go to Adobe.com. In the support section, locate and download the Camera Raw updater. The original ACR in CS3 does not read D200 .NEF files
Apr 09, 2010 | Adobe Computers & Internet
I have Sundstrand Hydrotransmission the code number on name plate as follow BDP-10L-0351 87-48-10553 Please info us how to understand those nomenclature? Regards Dudy
This is now handled by Hydro-Gear. www.hydro-gear.com.
BDP stands for Bantam Duty Pump and the rest of the code calls out the configuration of your pump - shaft, rotation, size, etc.
Mar 27, 2010 | Danfoss Sundstrand-sauer-danfoss...
My Nikon D200 refused to turn on!
Afraid bad news is correct, it sounds like main control board.... You will need to get a quote from your local Nikon Service Agent..... Good Luck
Aug 29, 2009 | Nikon D200 Body Only Digital Camera
Error 11 at nikon camera
First, if you can try the lens on another camera body, please do. See if the same thing happens on a different camera body. If it does, it's a problem with the lens. If not, you need to look at the camera. You can verify it's the camera by placing a different lens onto the body and see if you're experiencing the same problem. If it is indeed the body, I would suggest you take a pencil eraser and gently but firmly clean the contacts located on the lens mount. It's my experience (I also shoot with a D200) that often times when a lens isn't autofocusing, it's due to direty contacts either on the lens itself or the camera body. Cleaning them is a good start though and will narrow your issues down to the lens or the camera body. After cleaning, try the lens again to see if it's working correctly. If not, send it to Nikon in New York for repairs.
Jul 11, 2009 | Nikon D200 Digital Camera with 18-200mm...
Grip is comming off, any glue suggestions.
Just take grip completely off and remove old tape, Go to Radio shack or Ace hardware, Pick up some double sided Tape that looks the same as what was on there to begin with, Put it all a round the edge of the grip, and it should work like new. If the grip is deformed then you have call Nikon Cailf, To order a new grip. TC
Dec 09, 2008 | Nikon D200 Body Only Digital Camera
Nikon D200 and microdrive
I assume by "microdrive" you mean the compact flash card - right? Not all compact flash cards will word with the D200 - what is the brand of each of the flash cards you have (and are they all the same-purchased at the same time)?
Nov 02, 2007 | Nikon D200 Digital Camera with 18-200mm...
Toro 3 Blade Set For Wheel Horse 48" Deck 106637 106078 Logo
87 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
