Question about Acer Aspire One AO725-0899 11.6-Inch Netbook Volcano Black
How to flash bios in acer aspire one AO725-0899
5 Suggested Answers
  • 244 Answers
SOURCE: All Drivers for Acer Aspire 3680
you can download from www.acerpanam.com
Posted on Oct 01, 2008
  • 5 Answers
SOURCE: RECOVERY BIOS OF ACER ASPIRE 1640Z
Ok what you need to do is unsolder you old bios chip and solder in a new one!
Posted on May 05, 2009
  • 1481 Answers
SOURCE: Bios laptop Acer Aspire 1360 is empty / broken after wrong flash
how come ur BIOS is empty....
did u FLASH ur BIOS with any firmware update....
Posted on Dec 20, 2009
drifterK
  • 4924 Answers
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Posted on Dec 21, 2009
Set the bios password and forgotten whaat it is
You need to preform a Acer Aspire One BIOS Recovery
instructions here: http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
Summary:
You need a flash drive formatted as fat (Right click on drive. Click format. Select fat for file system. Press start)
Down load the bios 3310 from here: http://macles.blogspot.com/p/acer-aspire-one-bios.html
Extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Make sure laptop is off and has battery and power plugged in.
Plug in flash drive to netbook. Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The netbook will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the netbook reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Aug 20, 2011 | Acer Aspire One AOD150-1920 Netbook
My Acer One was given to me and I need the Bios password. Any Ideas???
The Acer Aspire One has built-in BIOS recovery which can be used to flash its BIOS. Once the BIOS has been flashed, all BIOS settings are reset to default which gets rid of the BIOS password. This procedure has been posted Aug 2008 on macles for friends of the aspire one to address the BIOS failure that frequented early versions of the Aspire One BIOS. I have used the procedure on my own Acer Aspire One when it bricked in the fall of 2008 and once more in 2009 to install a later BIOS version. Acer also posted Feb 2009 the similar procedure on AcerSupport but has since removed it. Be aware that you must follow the procedure carefully and do so at your own risk. Here is the macles link.
Feb 09, 2011 | Acer Aspire One PC Notebook
I have acer aspire 4315.i have a problem in winows.i want enter bios set up,asks a password.but i dont knw the psasword.how can i remove the bios password
What you need to do is Flash the BIOS.
http://support.acer-euro.com/drivers/notebook/as_4315.html
With this utility you should be able to FLASH BIOS to factory default and enter BIOS without password. Be extremely careful to follow the steps exactly, because one false move and your system could be rendered useless.
Hope this helps
Nov 20, 2010 | Acer Aspire 4315 Notebook
How do i update the bios on a acer aspire 4315 notebook? can anyone help??
Please follow the link mentioned below in order to update the bios.........
http://www.laptops-drivers.com/acer-notebooks/download-bios-updated-acer-aspire-4315.html
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 17, 2010 | Acer Aspire 4315 Notebook
Dec 20, 2009 | Acer Aspire 1360 Notebook
Acer Aspire 5100-USB, Touchpad, keyboard all quit working.
Bad motherboard or a failed attempt at a bios upgrade/flash
Jul 21, 2009 | Acer Aspire 5100 Notebook
Acer aspire one model zg5 battery won't charge
I have exactly the same problem and am searching at the same time as you. I think you are wrong. I think the 150 is for the larger screen model. I think we need the 110.
I think it's this one that i found at acer-euro
ftp://ftp.work.acer-euro.com/netbook/aspire_one_110/bios/v.3309.zip
but I'm afraid to use it (which is not to say I know how). Somthing about putting it onto a USB drive and running scripts. At least that's what they do with this problem on a 150
Jun 29, 2009 | Acer Aspire One PC Notebook
Acer Aspire 3620
flash the bios to the latest version (bios flash update available on the computer manufacturer's website). if this is a bios glitch, flashing the bios will solve the problem.
Sep 25, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire One AO725-0899 11.6-Inch Netbook Volcano Black Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
