Question about LG 42PC3D 42 in. Plasma Television
Have to hit power over and over before tv comes on
  • 3 Answers
I had this problem with another make of flat panel TV. Eventually it would not turn on at all. The following is what I did, and I am not suggesting you do any of this, especially if you are not experienced or knowledgeable with electronics. If your TV is under warranty, call the manufacturer. Mine was out of warranty and it turned out to be a bad capacitor on Power Supply board. I took the back off the TV. The power supply board is usually right in the center of the back of the TV. I then examined the capacitors very carefully. Electrolytic Capacitors sometimes bulge or split open when they go bad. Attached is a picture of my bad capacitor. The blue capacitor has a bulge in the top. They don't always bulge, but sometime leak oil or have a dark residue on them when they go bad. This is what I did. I am not suggesting you do this, but if you take your TV apart, be sure to unplug it first. I happened to have a spare capacitor in my junk electronics bin that was the correct capacitance. It had a higher voltage rating so it was a little bigger, but it still worked. I unsoldered the old capacitor and removed it. I took my spare capacitor and soldered it back into the motherboard. I also found that I could buy the correct electrolytic capacitor on Amazon for under $4 including shipping. Radio Shack also had one that would have worked, but it had axial leads instead of radial leads. Electrolytic capacitors have polarity (there is a + and -) so I had to be careful not to put it in backwards. I marked the circuit board with the + and - before I removed the old cap. I noticed that I could also buy a new power supply which would have only required removal of screws and plugs, but were considerably more $. Let me know how you make out.
Have to hit power over and over before tv comes on - 37f5038c-b0fc-4dde-be5f-b257c7074168.jpg
Posted on Oct 22, 2013
The power will not turn on, manually nor with remote. i use to be able to hit power a thousand times and it would tern on. or the red light would come on then off so then i would keep hitting power till it...
check you batteries in the remote. on the tv front panel button right lower run your hand long the bottom of tv it should turn on, then go to settings sync devices , than turn off tv try remote again should work.
if you need more help contact me
Mar 23, 2015 | LG 37LG30 37 inch LCD 720p HDTV w...
Lingthing hit my tv and the power don't come on.what o I have to replace
Almost always, the power supply board will need to be replaced after a lightning hit. If the cable or antenna input was hit, you will need to replace the main board also. It is usually cheaper to replace the TV than to repair a lightning hit.
Sep 23, 2014 | Sanyo Televison & Video
Universal tv remote tutorial
0017, 0463, 0178, 0016, 0092, it could be any of these codes if they dont wwork hold the program button til the light comes on and hit tv and then hit the power button on the remote until it turns the tv off or on and the hit enter or the set button which ever sets the code good luck
Sep 09, 2012 | Garden
Samsung UN55c6500 universal code
You can do a master reset on the tv. To performthis you get the remote point at tv with the tv off and hit mute,182, then power. Should come up with a sreen with a list, the first selection on that list you should hit the enter button between the arrows. Sub-menu should ave at the top factory reset or reset, hit the enter button twice. Unit should shut down. Turn power on and tv should be reset as if u just bought it. If u get into trouble in the service menu stop and power off tv. Do not adjust anything else you could damage your tv. Good luck!
Jun 28, 2012 | Samsung UN55C6500 55 LCD 1080p HDTV LED...
TV turns on sometimes
Maybe they got an electhrolitic capacitor near the horizontal side of the tv maybe about 250 volt to 1 mf or more
Apr 12, 2010 | Zenith B27A11Z 27" TV
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
Apr 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Problems w/ Sharp LC-46SB54U remote programming
i will help with the easiest way, hit the TV button, then hold the setup button untill the light blinks twice, then hit 991, it will flash again, hit the 1 again, then hit power, then hit the chanel up button, and if it dont shut off, hit the chanul up button again, keep going this every 2 seconds(with the chanel up button) untill the power shuts off, when it shuts off, hit the setup button again, that will lock it in, hit the power button again-TV should come back on, if that dont work, use the volum up button , after doing the first few steps, hope this helps
Jan 10, 2009 | Sharp LC46SB54U 46 in. LCD TV
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
LG 42PC3D 42 in. Plasma Television Logo
Computer Repairing
Computer Repairing
