Goodman heat pump restriction - Heating & Cooling
  • 3 more comments
  • Jeana Oct 22, 2013
    Unit seems to be running fine - but ac guy said there is a "refrigerant" restriction. Different ac guy said I need to replace 7.5 run capacitor. Still another guy said need to clean coil and $750 to clean coil and clean screen in meter device?
  • Cris Sparks
    Cris Sparks Oct 22, 2013
    Is the unit freezing up? Sounds kind of fishey on what they said was wrong. With a restriction you will be freezing up on the lines. Have you changed your filter lately?
  • Cris Sparks
    what made you call them? does the inside blower start right up?
    Everything seems to be workng fine. This was a regular maintenance call that started everything. I have unit professionally checked and service every 6 months. Change filter every month. They said "partial" restriction. Lines are not freezing that I know of. I am quite ill - emphysema - therefore I am very meticulous about changing filters. Also just had all ducts cleaned professionally.
  • Cris Sparks
    WIth my experience with heat and air if the lines are not freezing up then you dont' have restriction. Three is no such thing as partial restriction its either restricted or not If you have a restriction then your pressures are below freezing and your unit would be freezing up. IF the unit is cooling and shutting offwehn it gets to the desired temp I would forget this..
    Sergeant:
  • 338 Answers
What kind of restriction? What is the unit doing?
Posted on Oct 21, 2013
2 Suggested Answers
  • 334 Answers
SOURCE: I need to find a parts dealer for goodman heat pumps.
let me know where you live and I'll find you a dealer
Posted on Jun 18, 2009
I would like to know how to replace the heat strips in an Amana GPH1330M41 unit
Buy a heat kit from a Goodman dealer. Check that your existing wire will carry the amp load.
Jan 17, 2014 | Goodman Manufacturing Goodman GPH1330M41...
Goodman pgb036075-1A heat pump
Check your filter if u havent, most heat units have some sort of safety interlock should inlet air flow be restricted or blocked. If not could be ignition components or board issues. Over 8 major items will cause "No Heat" issues if it malfunctions, a few costly, so you'll want to be through tracing out your circuits & safety loops.. Or Call a Pro......
Oct 20, 2013 | Heating & Cooling
Capf3636c6ba
That is a 36000 btu inside unit.
That is a 24000 btu heat pump.
The heat pump is undersized and that will never work out.
Sep 04, 2013 | Goodman CKL36AR36 Air Conditioner
Replaced cracked heat exchanger on Goodman gas furnace( model# GMPN060-3) main limit trips constantly. Temperature at limit reaches up to 250 degrees. Downflow application, clean evap. coil and no return...
It may help if you increased the blower speed. It sounds like you have a restriction in either the return air duct or in the heat exchanger. Does it help to open the blower door panel. If so, you have confirmed a restriction. How do the burners look? Are they good and blue or yellow? Are the correct orifices being used for the type of gas? I know I am asking more questions than you, but it may help us with the answers. Good luck to you Wade.
Jan 31, 2010 | Goodman Heating & Cooling
New goodman pkg heat pump i wired up 2 brand new
You may have defective tstat wiring, or a bad control fuse. Check both.
Jul 30, 2009 | Goodman CKL24AR24 Air Conditioner
Jun 16, 2009 | Goodman CKL60AR60 Air Conditioner
Runs on emergency mode
By emergency mode I am assuming that you have a heat pump connected to the furnace. If so your heat pump is not functioning properly. For this I recommend a service man. To many possible problems in a heat pump to diagnos over the computer
Mar 02, 2009 | Goodman GMS90703BXA Heater
Goodman with 2 thermostats, freezes in summer, no heat in winter
is the system zoned? if so maybe the zoning control board to the damper motor is wired improperly. when a system freezez its because of 1- restricted air flow across coil, (maybe dirty filter) or 2-low refrigerant charge. again could depend on how its zoned.
Feb 16, 2009 | Goodman PHKJ048-1 Air Conditioner
Blower motor on Janitrol heat pump does not blow at a high speed. There are no air flow restrictions.
cHECK THE BLACK WIRE FROM THE FAN MOTOR TO THE CIRCUIT BOARD FOR LOOSE CONNECTION!.
Sep 15, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
