Question about Music
Fender serial number search N9422449
Is this a good number for a strat? They claim is a 2002.
    Problem Solver:
  • 5 Answers
The guitar is indeed a 2002 fender stratocaster. Many prefer older strats because they believe them to be of higher quality. It also depends on where it was produced. Mexican strats are okay, Chinese are usually the least liked.
N seems to denote American Made Strats though, American made are superb.
Posted on Oct 21, 2013
Testimonial: "Ok, they are selling it as American made. But the n9 made me think 09. Thanks. Brad."
5 Suggested Answers
  • 5603 Answers
SOURCE: I have a Fender Squier Strat. The Whammy bar is
There are MANY tricks to remove a threaded piece like this:
1. With a Dremel tool and a cutoff carborumdum disc cut a shallow slot in the remaining piece and use a straight bladed screw driver to remove. This can only be done if the screw is above or flush with the surface.
2. Carefully drill a small hole in the piece fairly well centered. Use an "EasyOut" to remove the broken part.
3. Carefully drill several small shallow holes on the top of the broken part in a line so as to form a slot for a screwdriver.
4. Carefully drill a hole JUST the right size into the broken part and then drive an Allen wrench into the hole to turn the broken part. The hole has to be just the right size so the wrench can peal tiny pieces off to grab the broken part.. this is tricky to get the size just right.
5. Use a detist drill to cut a slot.
In all these use a penetrating oil or CRC226 to make it easier to turn.
Posted on Mar 09, 2010
  • 3 Answers
SOURCE: CAN I FIT A FENDER STRAT PICKUP IN THE MUD
The Fender pick up has two wires, blue and white. The Jackson has four: red, green ,black, and white.
1st. Determine the hot wire and the ground wire on the Jackson pick up and then just replace the Jackson pup with the Fender pup. White on the Fender is the hot lead and blue is for the ground. If you hook it up backwards it will be out of phase with the other pup's and will sound thin and weak when selected with either the rhythm pup or the lead pup. Of course, by itself it will sound normal because switching the wires only changes the phase of the Fender pup.
On the Jackson pup, the green and black are ground while the white and red are the hot side. Just solder the white lead of the Fender pup to the pup selector hot side and the blue lead to the ground.
Posted on Aug 01, 2010
  • 298 Answers
SOURCE: Can i put my fender strat mexican guitar into
The Fender Stratocaster (in common with all Fender guitars) has passive pick-ups so should be plugged into the no 1 socket.
Whilst it will work in the No 2 input socket this has lower sensitivity and is intended for use with guitars that have active (battery powered) pick-ups.
Posted on Feb 10, 2011
SOURCE: Fender strat guitar. Want to know what year it was made. How?
what model is the washburn bass guitar serial number GE810003 and how much is it worth
Posted on May 04, 2013
What kind of Strat is serial no Z7041802 and what year. Is it an American Standard Series HSS or an American Deluxe Fat Strat
Your guitar was made at the Corona Plant, USA in 2007 - 2008. The serial number does not tell us the model with Fenders.
May 03, 2017 | AMERICAN Music
Any info on strat serial no G006212 please.
This guitar is a STRAT (Gold hardware, 2 position rotary tone switch)
made at the Fullerton Plant (Fender - Pre CBS Era), USA
in the Year(s): Circa 1980
The Guitar Dater Project Fender Serial Number Decoder
Feb 05, 2015 | Fender Music
I have a starcaster strat electric guitar by fender serial number is CSS 060805532 HELP ME FIND SOME INFORMATION ABOUT IT PLEASE
although info is slim, it appears that it is of chinese origin, mid-2000's. Modest value, not a collector, but a decent guitar.
Dec 28, 2014 | Fender Starcaster by Fender Strat Electric...
Fender strat serial number DZ0067060
Ok, this is going to be a lot of information. Let's start with the "D"; this usually means that the instrument is a "Deluxe" version. This would suggest it is an American Deluxe Strat. But Fender, themselves even admit that this letter ended up on some American Standard instruments. The second letter is EXTREMELY complicated and hard to explain. From the 1970's through recent years, Fender has used an "S", "E", "N", "Z", or "X". Here is the complicated part; "S"eventies, "E"ighties, "N"ineties, "Z" = 2000-2009, "X" = 2010 - present ;). The zero following the number suggests that this is a 2000 American Deluxe Strat. Keeping all of this in mind, there is another slim possibility. Fender has always used bolt on necks. Leo Fender decided to do this for a couple of reasons. They were cheaper to assemble, easier to work on, and easy to replace. Fender produces many replacement necks and they all have serial numbers on them. The previous owner could have potentially replaced the neck on a standard or even a made in Mexico Strat with an American Deluxe neck with a different serial number. I know this is a lot of info and the serial numbers do go more in Depth than just this, but more than likely you have an American Deluxe Strat. Good find!
Sep 01, 2014 | Music
Have a fender strat serial V019217
It is a US strat! Congrats! Guitar Info This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 19, 2014 | Fender Starcaster Strat Electric Guitar -...
Fender serial number year
Close as I can come is 2009-2010 per Fender's Mexican Strat Serial number chart here: (Scroll to the bottom of the chart.)
http://www.fender.com/support/articles/mexican-instruments-product-dating/
Mar 11, 2014 | Music
Ensenada Plant (Fender), Mexico
in the Year(s): 1992 - 1993
Jun 04, 2010 | Music
Music Logo
118 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
