Question about Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive
Unexpected turn off
I have a seagate 1tb external desktop drive and when i plug it into my computer it sounds like it's loading then it just shuts off, can you help please?
  • 55 Answers
Can you navigate to the external drive via Windows Explorer?
Did you try restarting your computer? Unplug the external completely, then reconnect it?
Posted on Oct 21, 2013
SOURCE: Seagate Free Agent Desktop Drive Not Recognized
I took my enclosure apart completely (not recommended since it was difficult breaking the snapping points), and I hooked up the drive just like an internal HDD. The BIOS was able to detect the drive so nothing is wrong with the drive itself.
I've also read that the controller on some of the FreeAgent drives fail. Mine started making buzzing sounds and finally failed. So you can take the drive out and put it in your computer, get a new enclosure, or send it back to Seagate where they should replace it.
Posted on Sep 14, 2008
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
Posted on Jul 24, 2009
bob_computer
  • 3153 Answers
SOURCE: seagate 1tb external hd just beeps
You may want to open the drive and check the internal connections first to make sure none came loose after you have powered it down.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care. this is a real hard drive and knocks and bumps can quite literally kill them.
If a drive is CLICKING after an accident there is a very strong possibility that it is dead or dying. This is known as the "click of death".
Posted on Sep 07, 2009
  • 1768 Answers
SOURCE: I have a Seagate FreeAgent External Hard Drive,
1. the drive is damaged and needs to be replaced
2. You probably have separated the platten inside or damaged the reading mechanism inside by dropping it.
3. Hard drive are assemble in a clean room environment and have very precise tolerances are delicate devices. dropping one from just a foot from the floor will damage it.
Posted on Sep 15, 2009
How can I find the files on my 1tb, seagate external drive?
You maybe removed the driver for the hard drive when you ran the anti virus. Those programs can do some strange things. If you click on the start, then computer. It will show all hard drives on your system. If you cannot find your files. I would think your computer does not see the external hard drive. To reinstall the driver, you would need to go to the driver's manufactures web site to down load or yours may have came with a disk. If so just run the disk. Could do a system restore , but that would be last option .
Aug 02, 2014 | Seagate FreeAgent Pro 1TB External USB...
Seagate Expansion 1TB Portable External Hard Drive USB 3.0
Try with proper USB 3.0 drivers obtained from Intel, must work with original cable on the USB 3.0 computer port.
Feb 13, 2014 | Seagate Expansion Computers & Internet
Spins but makes a beeping sound and wont register.
Well, It sounds like there is something lodged in your Hardware drive...The beeping is probably a warning signal to tell you that it is not properly booting up...You should go to a Computer Repairman...
Jul 11, 2013 | Seagate FreeAgent GoFlex Desk 1TB USB 3.0...
Seagate Expansion 1TB external Desktop Hard Drive (9sf2A4-500) not detected.
Claire,
Have you tried connecting the drive to another computer using Windows 7 or later. You could try chkdisk /f at a command prompt or get the testdisk app to identify deeper issues with the drive.
Chappo07
Oct 24, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Install seagate expansion
New drives have to be readied for use. Try Start > Run (aka Search in Win 7) type dskmgmt.msc. Look for your drive there. It should be without a drive letter. Right clicking will give you the options of initializing, creating disc partitions, and assigning logical drives. If this seems a little daunting. A wizard should load. If not there is refresh icon on the tool bar. You may want break down the 1TB down to a few partition because of the large size.
Aug 30, 2012 | Seagate 1TB Expansion External Desktop USB...
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
My seagate 1TB external hard disk (the little compact one) cant be read anymore. Was working fine a couple of days ago. The lights on top are flashing constantly. After the drive is plugged into the...
Right click "My Computer" >properties> hardware> device manager. Expand "disk drives". Right click your seagate drive and click uninstall. Reboot your computer; the drive should automatically be reinstalled.
Feb 10, 2011 | Seagate FreeAgent Pro 1TB External USB...
I have a 1tb seagate desktop, the light doesn't turn on and it makes a clicking sound and when plugged in the computer nothing happens
Try first connecting the drive to a different USB port on your computer and check if it will be working fine, but if still not working better try connecting it to a different computer ad check if same result. If still not working try using a different USB cable and see if that will fix the problem but if still not working the drive is already bad and better try to check it with the manufacturer of your drive and have them recover your data inside it.
Apr 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Ex hard drive not responding -light's on but nobodys home
Try Testdisk. see if it picks up the drive and if so get it to check the boot sector and rebuild it if necessary.
Aug 03, 2017 | Seagate FreeAgent Pro 1TB External USB...
Seagate FreeAgent Pro 1TB External USB 2.0/eSATA Hard Drive Logo
71 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
