SoleusAir 10,000 BTU Portable Air Conditioner Logo
paul fluke Posted on Oct 21, 2013
E2 error code
What does the code mean and what is the fix
What does an E2 code mean? How can I solve that error? I have a Honeywell Dehumidifier model TP70WKN that is about a year old. It have been working well until now that start showing "E2"at the display
Step 1: Reset the printer
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Wait at least 60 seconds.
  3. Reconnect the power cord to the rear of the printer.
  4. Turn ON the printer, if it does not automatically turn on.
  5. Wait until the printer is idle and silent before you proceed.
Step 2: Update the printer firmware
Click here to know different methods of updating printer firmware.
Step 3: Printing Documents
You can resolve the error by canceling the print job, and then changing the print settings in the printing software.
My Danby dehumidfier model DDR2510E showed the code E2 after I emptied it and now won't work and no where in my manual does it say what to do or what it means.
Hi There,
The E2 error you are receiving is likely the float switch sensor when turns the system off when the bucket is full. Please contact our customer service department to be connected with a service depot in your area.
1-800-263-2629 Business hours are Monday to Friday 9am-4pm
Thank you!
E2 error
Unfortunately, for whatever reason, Haier does not list the Error Codes and what the problem is, in their Owner's Manuals. To find out what E2 indicates you will have to contact Haier Customer Support
1-877-337-3639. It's very important to have your Model Number handy before you call.
Hope this helps you to get the answer. Thanks for choosing FixYa.
Dehumidifier not turning on showing an e2 code
Lisa, unfortunately, Haier for whatever reason does not list what error codes mean, in their Owners Manual. You will have to contact Haier Customer Support 1-877-337-3639 for that.
In the meantime, turn the ON/OFF Switch to OFF and unplug the unit for 15 minutes. Then, plug the unit back in and turn the ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the electronics reset and reverted back to the original factory settings. If they did, you can set the controls as you like.
Hope this helps you and thanks for choosing FixYa.
4helpful
2answers
My dehumidifier is showing an E2 code on it. It is a brand new haier, can you help me out with this problem?
E2 Code indicates a Sensor Error automatic shutdown. To find out which sensor it is you will have to call Haier Customer Support 1-877-337-363.
In the meantime, turn the unit OFF & unplug it for 15 minutes. Then plug the unit back in and turn ON. ON. Hopefully the unit reset itself and reverted back to the original factory settings. And you can set te humidity extraction level where you desire. If the error code reappears, definitely contact Haier, as youtr unit is still under warranty.
3helpful
3answers
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
Hope this helped you to solve the problem.
9helpful
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
2answers
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Danby ddr401 dehumidifier reading 'E2' error code on screen.
Check the wiring that runs below the fan for nicks and cuts. I had this error code and was in the process of junking my dehumidifier when I noticed the wiring going from the capacitor to the compressor and a few other wires had somehow been chaffed and cut by the fan blade. I had already thrown the control panel away by this time so I don't know if replacing those wires would have cleared the code or not.
Top Soleus Dehumidifiers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
