Question about Logitech Z 313 - 2.1-channel PC multimedia speaker syst - 980-000382
The volume on my z313 I hook it up to my computer is to low
    Scholar:
  • 112 Answers
There should be a volume level adjustment on the speakers.
Verify the master volume on the computer is turned up as well as the volume of the app in use is turned up.
Posted on Oct 22, 2013
Can I connect the logitech z313 by usb cable instead of the earphone plug on my desktop Windows 10?
No, the 1.8" stereo cable coming from the back of the Sub is intended to be hooked in to your computer's audio-in (green) port, or the headphone jack on your laptop. There is no USB connectivity with this model.
Feb 01, 2018 | Logitech Computers & Internet
Logitech Z313 Sound System Failure
On the basis of your description, you can conclude that your Logitech speaker system has failed.
Mar 18, 2014 | Sun -115H Computer Speakers
How do i hookup logitech speakers #z313 to my emachine e202hl
The manual for your speakers can be found at http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf. The Speakers should be conected to your computer as opposed to the moniter. Disconect the small wire from the moniter to the computer and insert the plug from the speakers where it came from.
Nov 14, 2012 | E-Machines Computers & Internet
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
How can I change tone setting
You could try volume control > advance > Tone Controls. This will only work if you have decent sound card. Grey-ed out with lower end hardware. The other option is to use a media player with an EQ. Like VLC or Winamp.
Aug 27, 2012 | Logitech Z313
How to connect logitech speakers to computer
Have you gone into your control panel and checked the speaker volume ???
Start, Control Panel, Sound
May 17, 2012 | Logitech Z313
I am having trouble with the speakers making any sound when I hook the speakers into the Rear Panel (RL RR) of my computer but the speakers work if I use them in the headphone jack. The subwoofer works...
The main reason why the rear speakers are not working because the sound you are playing are not surround sound or a not a stereo sound and check the setting of your speaker. There is an output sound in your speaker but to low because of the set up of your speakers. Try to set it in Hall, Church, or any set up you will notice that there is difference with there volume in every set up.
Jul 26, 2011 | Logitech Z313
We are hooking the speakers up to a new computer and we don't have the software
Threre is no software for these speakers. This is the installation guide:
Make sure you have the proper sound device activated and volume turned up. If after speaker set up, you have no sound, get into your "device manager" and click on the box next to"sound, video and game controllers"(on right) and, righy click on each device that shows in the list. You should see "disable". If you see "enable" click on that and exit. You should have a speaker icon in your taskbar, lower right of screen. Right click on that and then on "open sound mixer" and, adjust your volume.
Jun 14, 2011 | Logitech Z313
Connected up z313 speakers. have motherboard HD sound installed with my windows 7. no sound coming from sub or speakers. can plug head phones into the z313 controller and listen to music. plz help
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 31, 2011 | Logitech Z313
Logitech Z313 how to install it in your computer
plug these speakers
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | Logitech Z313
Logitech Z 313 - 2.1-channel PC multimedia speaker syst - 980-000382 Logo
227 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
