Kubota manual i am trying to split a kubota grandel gl 280 between the gearbox and transmission it moves about 20 mm but something inside is holding it?
4 Suggested Answers
shanat
  • 359 Answers
SOURCE: removal of evo6 gearbox
is the bellhousing removable? also check the flex plate isnt bolted on
Posted on May 24, 2008
  • 3567 Answers
SOURCE: I am having trouble trying
I don't know what has not been removed so pardon me if I suggest something already removed. Remove the cylinder, intake manifold, magneto, stator, sprocket and shift lever. A case splitter is highly recommended. They don't cost that much and it makes for a clean separation. The two positioning guides will tend to hamper separation as will the crankshaft and output shaft as they slide through the bearings. That's another reason for a case splitter. Now would be a good time for new crank and output shaft bearings and seals and a new shift shaft seal. I assume the reason for the teardown is either a bent shift fork or broken gear teeth. If replacing a gear with a broken tooth or two, also replace any gears the broken gear meshes with. If you don't, you will get to do the gear repair a second time very soon after the first ride. Whatever pressure broke the teeth on one gear was also present on the meshing gear. It may look good, but it isn't. Please take a moment to rate my answer. Thanks.
Posted on Apr 13, 2011
bonnes777
  • 42 Answers
SOURCE: Need to cross T0070-37723 hydrolic filter for my
Go NAPA auto parts they cross reference the part number
Posted on Nov 28, 2014
What type of gearbox oil in Isuzu rodeo 1991
USE A FULLY SYNTHETIC MANUAL TRANSMISSION FLUID IN 75w-85 viscosity. (API GL-4)
Feb 10, 2016 | 1991 Isuzu Rodeo
Tip
Vs commodore series ute manual gearebox removal 2000 model
<ol> <li>Jack car up and place on chasis stands on all 4 wheels</li> <li>remove battery</li> <li>drain transmission oil</li> <li>remove electrical coneecters on gearbox..(2 on the gearbox and 2 for oxygen connecters-remove all attachements from gearbox and zip tie wires on engine block away from the gearbox as these can get caught and split)</li> <li>using a deep 13mm socket remove exhaust flange nuts and 19mm for the mid section-pull exahust out </li> <li>Mark alignment of drive shaft in the middle where it attaches to the rear half</li> <li>Place a jack under gearbox and remove mounting plate</li> <li>remove bolts from drive shaft on gearbox end and slide spline out-no need to remove the complete drive shaft from up to the rear.Only 1/2 will do.</li> <li>Looking up from underneath there are 4 bolts holding 2 plates from the place the gear lever sticks out .remove bolts and using a flat screwdriver push locking clip out to completely free gear linkages(no need to do it from inside)</li> <li>remove slave cylinder (13mm)and zip tie it out of the way</li> <li>remove starter motor</li> <li>place a bigger trolley jack under the gearbox and undo all bell housing bolts(19mm &17mm)NOTE:you will need longer extensions for this</li> <li>put another jack under engine</li> <li>using a pry bar make a gap between geabox and engine block and with a little bit of elbow grease push gearbox out of the way</li></ol> <br /> <br />
on Aug 08, 2011 | Ford Aspire Cars & Trucks
Tip
How to change (check) AUDI transmission oil
Transmision oil for Audi A4 (1.8, 1.8T, 1.9 TDI):
Manual gearbox (5 speed):
- Capacity = 2,25 liters
- Specification: Gear oil SAE 75 W 90 (synthetic oil)
Part number G 052 145 S2 (1 liter)
- To check oil level, unscrew oil filler plug placed on the left side of the gearbox in front and near of transmission axle, using an Allen 17 mm key.
- Check oil level with locally manufactured tool, e.g. a piece of angled wire.
- Specification: oil level 7 mm below bottom edge of oil filler hole.
- Install oil filler plug, tightening torque = 25 Nm.
on Dec 19, 2009 | Audi A4 Cars & Trucks
How do i fix gearbox on a g2160 lawnmower kubota diesel
I worked on a lot of Kubota and what you have to do is split the transmission from the engine a the differential take it apart and replace worn and broken parts re adjust and re assemble the tractor
May 07, 2015 | Diesel Garden
Gearbox fault
Check your transmission fluid level - a 'how to' is in the owner's manual.
GL,
Td
Oct 01, 2012 | 2005 Jaguar S-Type
2003 ford transit turbo manual gearbox, stuck in 2nd gear, cant start
does the clutch push normally or is the linkage broken not disengaging clutch, and then does shifter move around or locked and wont move, loose linkage in shifter or gears are jammed inside transmission and something went, if shifter wont move at all then trans is jammed inside and needs repair.
Jun 09, 2012 | Ford Transit Cars & Trucks
My 1996 audi a4 just wont reverse any more is there anything i can try before buying a new transmission? Please help
two possibilities ?? the control switch on the gearbox ,its full of carbon tracks inside and it costs about 280€ or the computer under the passenger floor ,find a local mechanic and ask if they can have a look for you but at the end of the day then it could be a recon box
Sep 08, 2009 | Audi A4 Cars & Trucks
What do I need to buy or what should I do if my fuel reserve does not work or what is the fuel capacity for a 1991 Yamaha FZR 600?
var gDcsId="dcsmm6y3q0000004zhgx8uuaa_9g7g"; var dom=window.location.hostname.replace(/^www\./,''); window.onload = function() { init(); setThumbnailimages("galleryThumbNails", "galleryImage"); enableMenu("archive"); initLightbox(); }; Technical Specifications 1991-FZR600
Engine Engine type Liquid cooled, 4-stroke, forward inclined parallel 4 cylinder, DOHC 16 valves Displacement 599 cc Bore x stroke 59.0 x 54.8 mm Compression ratio 12.0 : 1 Maximum power 66.8 kW (91 HP) @ 10,500 rpm Maximum torque 65.7 Nm (6.7 kg-m) @ 8,500 rpm Lubrication system Wet sump Fuel System Mikuni BDST32 x4 Clutch type Wet, multiple disc Ignition system Transistor controlled (digital) Starter system Electric Transmission system Constant mesh, 6 speed Primary reduction ratio 1.708 Secundary reduction ratio 3 Final transmission Chain Ratios gearbox 1st 2.846 Ratios gearbox 2nd 1.947 Ratios gearbox 3rd 1.55 Ratios gearbox 4th 1.333 Ratios gearbox 5th 1.192 Ratios gearbox 6th 1.111 Chassis Front suspension system Telescopic fork Front wheel travel 130 mm Rear suspension system Swingarm (Link suspension) Rear wheel travel 115 mm Caster angle 25° Trail 94 mm Front brake Dual discs, ø 298 mm Rear brake Single disc, ø 245 mm Front tyre 110/70V17 V240 Rear tyre 140/60V18 V240 Dimensions Overall length 2,165 mm Overall width 700 mm Overall height 1,155 mm Seat height 785 mm Wheelbase 1,425 mm Minimum ground clearance 135 mm Dry weight 181 kg Fuel tank capacity (reserve) 18 L Engine oil tank capacity 3.1 L
Jun 27, 2009 | 1991 Yamaha FZR 600
Automatic gearbox of volvo S80 T6 2000 doesn't work.
hi i have a 99 volvo s80 2.0t drives very well but when i select R it doesnt move but the revs go up can any one tell me whats wrong and how much it will cost thanks
Apr 20, 2009 | 1999 Volvo S80
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
