Question about Canon PIXMA Office Equipment & Supplies
How do i get to the ink cartridges on the Canon MG5300?
  • Canon Master
  • 5,102 Answers
Make sure that the printer is plugged in and the unit is on. Then make sure that the document cover is closed. Lift the entire scanner unit. (Lift from the center above the paper output tray.) A support rod should engage to hold the scanner unit.
The print cartridge carrier should move into center of the printer to allow you to access the cartridges. (If there is anything blocking the carrier, you may need to remove the foreign objects. See below.) If you take more than about 10 minutes to change the cartridges, the carrier will return to its home position. Close the scanning unit and reopen it.
If you put a cartridge in incorrectly, the cartridge could block the carrier from moving properly. You should unplug the printer before trying to slide the carrier back and forth to either check for foreign objects or attempting to reseat the cartridges. To insert a cartridge, push it into the appropriate slot and then push down. For removal, lift up and then pull the cartridge back.
I hope this helps.
Posted on Oct 21, 2013
Canon mx479 printer printing with white line through text on every other line
does this Canon mx479 printer have a self clean
or maintenance menu
user manual link
https://www.manualowl.com/p/Canon/PIXMA-MX479/Manual/218086
something wrong with the black printer cartridge
PG-240XXL XXL Black Ink Cartridge
PG-240XL XL Black Ink Cartridge
PG-240 Black Ink Cartridge
CL-241XL XL Color Ink Cartridge
CL-241 Color Ink Cartridge
May 11, 2016 | Canon Office Equipment & Supplies
Canon printer mg5300. Suddenly ink on photos not drying. Should I clean something? Thanks.
No has nothing t do with dirty heads or nozzles. I think you used the wrong paper (or plastic) and did not tell the printer what it was printing on. Be aware ink yet printers need special paper, so the droplets (how small they may look with only a few pico litre) don't give a splash pattern and the ink will dry very quick. What looks like normal paper, has an absorbent on top of it. Only use photo paper when it says photo paper for ink yet printers. The best results you get, when you use the Canon paper, canon ink and use this in the settings while printing.
Feb 27, 2015 | Canon Office Equipment & Supplies
Canon MP620 , full ink cartridge reads as " ink has run out" U041
The Canon printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
Feb 01, 2013 | Canon Office Equipment & Supplies
The cartridge
Is this a Canon ink cartridge or a refilled ink cartridge or an after market type. If it is not a Canon ink cartridge then printer will reject the ink cartridge.
Dec 23, 2011 | Canon PIXMA Office Equipment & Supplies
Can i use pg-40 ink for my canon mp480
Sorry you can't use PG-40 on MP480. Canon MP480 printer takes only Canon PG-510 Black Ink Cartridge, Canon CL-511 Colour Ink Cartridge or Canon CL513 Colour Ink Cartridge (this one is high yield colour cartridge).
Feb 02, 2011 | Canon Pixma MP480 All-In-One InkJet...
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
What is error e5 in mp 198 printer
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly..
  • In certain models of Canon Pixma printers such as the Canon MP160 and Canon MP150, you may receive an E5 error when trying to print. In this state, you will not be able to use any of the functions of your printer. The error itself is an ink cartridge error. It may be that you are using generic or off-brand ink cartridges in your Canon Pixma printer. Canon Pixma printers do not work with other brands of print cartridges; invest in Canon brand ink cartridges and this should take care of your problem.
  • Nov 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    How to load new ink into printer Canon Pixma 620B ? Thank you!
    Step 1.
    Open the hood of your printer; if the ink cartridge holder does not slide into view, check to make sure the printer is turned on.
  • Step 2 Remove any empty cartridges from the ink cartridge holder and dispose of them properly. Some Canon printers have a protective cartridge lid that must be opened before you can change a cartridge.
  • Step 3 Remove all protective tape and plastic film from the fresh cartridge. Canon uses a bright orange protective tape on its ink cartridges. Some Canon ink cartridges also have a bright orange protective cap over the ink nozzle that must be removed before installation.
  • Step 4 Insert the new cartridge into the ink cartridge holder. Tilt the cartridge up slightly and insert end-first into the proper slot; push down gently on the cartridge to lock it into place. Some Canon printers have an indicator light that will activate when the cartridge is firmly installed; other models have a cartridge cover that will lock into place when closed.
  • Step 5 Close the hood of the printer. The printer will indicate when it is ready for use with a message on the LCD screen or by blinking the LED indicator light.
  • Jan 22, 2010 | Canon Office Equipment & Supplies
    Price of catridge of cannon ip1300
    these are the cartridges used in 1300
    CL-41 FINE Colour Cartridge
    PG-40 FINE Black Cartridge
    click here for cl 41 prices
    http://www.google.com/products?q=cl-41
    Click here for pg-40 prices
    http://www.google.com/products?q=pg-40
    Let me know if you need anything else.
    Thanks,
    Ekse
    Mar 05, 2009 | Canon PIXMA iP1300 Printer
    Installing new ink cartridge, canon pixma 1600
    Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
    Apr 04, 2008 | Canon PIXMA iP1600 Printer
    161 people viewed this question
    old marine
    old marine
