Question about ViewSonic ViewPad E100 9.7in 1024 x 768 IPS Tablet PC E100_US1, 1GB DDR3, 4GB Fl
How do I hard reset and soft reet - ViewSonic ViewPad E100 9.7in 1024 x 768 IPS Tablet PC E100_US1, 1GB DDR3, 4GB Fl
How come my tablet fails to come on, but back light flashes
Depending on the make and how much you paid for it, it is dead. If it is an iPad you can get it repaired.
You can try and reset it. For Android, hold the power button and the volume up button. Note that it will scrub everything off the tablet. You MAY get an opportunity to back it up.
Google
make model soft reset
make model hard reset
Try a soft reset first.
Nov 20, 2016 | Tablets & eReaders
Does anyone know how to reset my kids Click N Kids tablet?
Hard reset or soft reset? Softreset, push a pin into the reset hole on the back or side. Hard reset, hold down vol- and power until the reset screen appears.
Aug 03, 2015 | Tablets & eReaders
Forgot patten to this kurio 4s of my chld so have can i get in it.
Reset your Kurio's password using a Google Account that has been linked to the Parental Profile
Kurio Password Reset Kurio 4S Kurio 7S Kurio 10S
soft reset
Kurio How to Perform Soft Reset
if that doesn't reset it
hard reset
https://answers.yahoo.com/question/index?qid=20140125135603AAAqQyt
Jul 18, 2015 | Tablets & eReaders
My tablet is hang how can restart all button are not responding
My first guess is that It is "frozen." If you turn it off and back on, it probably asks for an "unfreeze" code related to unlocking the phone. If that is the issue, you can try to work with Samsung's support via their live chat. http://www.samsung.com/ae/support/model/SM-T331NZWAXSG
This may be helpful related to the above:
http://www.unlocking.eu/how-to-enter/samsung-t331-galaxy-tab-4-80-3g/
I included the above link simply for illustrative purposes. The avove is if you entered the wrong code 3 times that locked the phone.
But alternatively, if the device is truly "hung", you can try first a soft reset and if that does not work, a hard reset (which will return the system to the factory defaults reverting it to how it was when it came out of the box. With a hard reset, you lose whatever you did on it after you took it out of the box.
If you do a soft reset and you get some access to the keypad functioning, you might want to uninstall whatever you probably just installed immediately before it froze up. A soft reset retains your data. I would avoid trying the last program you installed again to see if it ran! You might subsequently download the SD Maid app and select corpse (no kidding) to get rid of residue after the uninstall of what is the problematic program.
Hard reset Utube: https://www.youtube.com/watch?v=nZBZYa4nZ18
Soft reset: http://smallbusiness.chron.com/soft-reset-samsung-galaxy-s4-81670.html
Jun 03, 2015 | Samsung Galaxy Tab 4 8.0 3G T331 16GB GSM...
How do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Hw do i reet my tablet
Try to reset your tablet to its factory default mode. To do this, follow the steps on the video provided below.
Sep 24, 2014 | Hannspree SN10T1 101 Tablet
This is what I received as recommendation because my Samsung tablet wonturn on and I was given the following tip: "Try to hard reset or soft reset, for this procedure search on google.com how to reset
http://www.samsung.com/us/support/faq/FAQ00055283/66871/SM-T3100ZWYXAR
If you give us the model number then we may be more accurate with our answers as this was you a Samsung Galaxy Tab 3 but I think the procedure would be similar across all samsung tablets.
Sep 15, 2014 | Tablets & eReaders
What is a hard reset
A hard reset wipes all data and restores device to way it was out of the box, also known as factory reset.
Mar 22, 2014 | Ematic 7" Touch Screen Tablet
How to fix my Lenovo tablet A1000-F it won't charge?
If you ask "how to disassemble, repair, and reassemble" it, you should not be trying to do it -- take it to the nearest Authorized Repair depot. Check Lenovo's web-site to find the location of that depot.
Mar 08, 2014 | Tablets & eReaders
ViewSonic ViewPad E100 9.7in 1024 x 768 IPS Tablet PC E100_US1, 1GB DDR3, 4GB Fl Logo
19 people viewed this question
Top ViewSonic Tablets & eReaders Experts
Gareth Cockram
Gareth Cockram
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Are you a ViewSonic Tablet and eReader Expert? Answer questions, earn points and help others
