Question about Electrolux EIED55H Dryer
Dryer turns on, buzzes, then puts itself on pause. Electrolux dryer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 93 Answers
You need a timer
Posted on Oct 22, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have an Electrolux IQ
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Testimonial: "Thanks for the advice. Yesterday a technician came, said the same thing, took the cover off, spun the cylinder and it worked. Must have been blocked"
My electrolux dryer was working fine and now it won't start
The hum normally comes from the motor trying to start turning but wont.....motor problem.
Jan 21, 2016 | Electrolux EIMED60LT Front Load Electric...
When i try turn my frigidaire affinity dryer on it buzzes and goes to pause
Good Morning friend, thank you for your post!
From the information you have provided your Frigidaire dryer is buzzing and goes on pause when you attempt to turn it on. This could be a possible issue with your door latch, door strike, or control panel. If you dryer shows pause that means there is an interruption within your cycle. I would advise to look over your door latch and strike to see if there is any apparent damage to either component. If both components appear to be working properly I would advise to have a technician come out to review your control panel. I hope this information has been helpful to some degree. -Matt
Feb 17, 2015 | Frigidaire Dryers
How to fix so it turns on and drys instead of humming and Pausing
If the dryer is I humming but the drum is not turning then the motor is turning but the belt is not attached, it is probably broken and needs a new belt. if your belt is intact then your motor or start capacitor is bad.
Aug 09, 2014 | Electrolux Frigidaire Affinity AGQ8700FE...
Aeg electrolux dryer
Displaying the alarm code
The alarm code is displayed by a repeated sequence of flashing of the ANTI-CREASE/END OF CYCLE LED (0.4 seconds on, 0.4 seconds off, with a pause of 2.5 seconds between sequences). The buzzer emits a series of ,bips" in synchronization with the flashing of the LED.
  • ANTI-CREASE/END OF CYCLE LED: indicates the first number of the a alarm code
  • START/PAUSE LED: indicates the second number of the alarm code
Now you must count how many times the LED lit up and we will know the fault code.
24383347-wycorcio5u0xxoh2plbhrodj-5-0.jpg Dado
May 10, 2014 | AEG Dryers
Dryer is stuck on paused and won't spin. Turned off and re-started but the motor ran for a few seconds and then went to paused again.
Good Morning Jill,
So I see that you were drying bath mats and the dryer got stuck in a "Pause" mode and even if you cancel and restart it shows "Pause" on the display. I would suggest resetting the dryer. What you will need to do is either unplug it or you can shut the power off at the circuit breaker. When you do this you will need to leave it off for at least 2-3 minutes. Cut the power back on, start any cycle. If you are still having trouble not being able to start the dryer and "Pause" showing, I suggest you either contact the manufacturer or your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Mar 25, 2014 | Electrolux Dryers
Dryer will try to turn but will not and will go to Pause
Hello david_whi764 - Try reprogramming the dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit, and select a normal cycle. Does it continue to Pause? If so, then the unit may be experiencing a communication error with the control board or wiring failure. I personally recommend contacting a professional to move forward accurately and to assist with the repair(s).
Feb 23, 2013 | Electrolux EIED55H Dryer
When start is pushed, dryer hums then immed. flashes to Pause
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The motor is going bad...
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | Electrolux EIED55H Dryer
I have an Electrolux IQ Touch dryer. Just now it stopped working. When I hit the start button, it makes a buzzing sound and then goes on Pause. I called Electrolux and they had no idea what was...
heatman101
Aug 25, 2010 | Electrolux Dryers
Model EWF1087 washing machine will not spin or drain just makes buzzing noise.
your pump impeller is blocked or fouling on something inside the filter compartment,turn machine off unscrew fiter (be prepared for water to come out),then get a long screwdriver and turn the impeller anything caught in there will free itself up,and you should be able to mremove forieghn object if impeller doesnt turn then it more than likely your pump is seized and will need replacing hope this helps.
Oct 06, 2009 | Electrolux EW1200i Front Load Washer /...
Electrolux EIED55H Dryer Logo
265 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
