Question about Lexmark X364dn All-In-One Laser Printer
No paper jam wheel is turning but paper will not go through
  • 32 Answers
The feed wheels are small rubber circles, and the flat edge that contacts the paper can get dirty, and even a small hard layer of "gunk" so that it slips on the paper, and does not push the paper ahead as it should. Preferable remove the wheel and clean it (rubbing with soap and water has been successful for me) and dry it and put it back on. Good luck.
Posted on Oct 21, 2013
Paper jam in tray 2 but there is nothing jammed.
Paper not being picked up, does it have a 3rd tray, take all paper out of tray 2 and see if you can get paper to feed from 3. Also make sure the lever on the cassette tray is in the normal position and check the menu in the settings. Some times the front registration area above the cassettes goes bad, not very common but does happen...place som toner on the wheels in tray two and try to print, see if the toner rubs onto the paper, if it does means wheels are turning, if not wheels are not turning....
Sep 30, 2013 | HP LaserJet 4350 Printer
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Paper jam, paper was removed still says paper jam
some small partical must be their on printer papper sencer ... or may be senser spring in jammed
clean it
Dec 02, 2008 | Office Equipment & Supplies
How to change ink cartridges? Release jammed paper? Paper won't feed!
Sounds like it needs cleaning:
You will need : 1 can of "compressed air", 1 container of ether rubbing alcohol or some form of Goo-Gone.
1. In short blasts (NOT LONG ONES) blow through the paper path. Open any paper jam access trays before doing this so the bits escape.
2. Using a SMALL amount of Goo-Gone and either a Q-Tip or small dust free cloth, clean all the rubber rollers on the bars. Cheap paper leaves a fine dust and after time will make the wheels very slick.
Doing this every other month can save you from jams and is just a good maintenance plan for your printer.
Also don't use 'cheap paper'.
Good luck! :)
Oct 26, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Savin 2513 Jam
Many printers have a paper jam alert.But you need to remove the jam the correct way. You can't just pull the paper from the machine. If you have the manual--look up the proper procedure to un jam the paper. The machine can detect if the paper is stuck and it will not know it is fixed if the proper method isn't used. The system has a mechanism that loosens the rollers to allow the paper to be removed without damaging the wheels.
Oct 12, 2008 | Office Equipment & Supplies
PAPER JAM
The problem sounds like your rollers have lost their grip. Remove the paper tray and tip the printer up. Push the red lever on the left of the printer down and you will see the feed mechanism with two wheels. Remove the rubbers on the wheels and turn them inside out. Replace them on the wheels with the worn side now inside and the 'sticky" side out. You should get at least another couple of years worth of use before you need to replace them.
Aug 22, 2008 | Lexmark E232 Laser Printer
Lexmark P6250 paper Jam
Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Jan 27, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Canon imageclass printer 5550
I have crazy feeding/paper jam problems with my MF5650.
Oct 06, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Paper jam at the Transfer Roll
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Apr 10, 2007 | Konica Minolta magicolor 2400 Laser...
Lexmark X364dn All-In-One Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
