Question about HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply
En donde se encuentra el vulbo - HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply
SOURCE: Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Posted on Sep 11, 2008
SOURCE: Error al instalar driver de scanner HP Deskjet F380
hi dear
i need ho deskjet f380 All in one
thanks
Posted on Sep 23, 2008
  • 359 Answers
SOURCE: reparar mi computadora
I do not speak Spanish (no hablo Espanol) -- but this is the solution...
Please see this reference, as it is a known and identified issue with this model at HP: http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&product=18703&docname=c01087194.
Your issue is most likely a defective machine, and HP should assist you with repairing it or replacing it as appropriate. If you do not one of the specifically identified product numbers, or are in a different location, you still have a solid case for getting it corrected. The documentation is there that the product is defective, and HP needs to correct it for you. Good luck - I hope it goes well!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 26, 2008
rajdeepdutta
  • 2517 Answers
SOURCE: cuando instale a 5to usuario
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Sep 02, 2010
puertobori
  • 7733 Answers
SOURCE: En el display me muestra el error "Atasco
Trata este link en ingles pero facil de entender.
Posted on Oct 22, 2010
Donde se encuentra el sensor map baro de mi nissan sentra 2000 1.8
Hola, eso se encuntre entre la manguera en donde entra aire a la cabina en donde se encuentra el filtro de Aire. Incluire un video para que veas en donde esta. Buena Suerte!
Jan 13, 2014 | 2000 Nissan Sentra
Donde se encuentra el filtro de gaso2003lina en una susuki aereo sx
en la linea de gaz cerca el bomba o cerca el tanque.
Sep 20, 2012 | Cars & Trucks
Donde ese encuentra la bateria para pasarle carga aun carro buick lesabre 2000
En el aciento trasero tienes k kitar la parte donde te sientas y ahi esta la bateria
Aug 26, 2012 | 2000 Buick LeSabre
Donde se encuentra el sensor map de grand cherokkee 2000
donde se encuentra el map sensor para un jeep grand cherokee limited 2000
Jan 28, 2012 | 2000 Jeep Grand Cherokee
Yo tengo Necesidad de ubicar el sensor de los golpes en mi 1994 Isuzu el vehiculo prende pero cuando calienta prende la luz de check engine y despues no prende hay que esperar que se enfrie para prende...
El sensor de detonaci?n se encuentra en el colector de admisi?n en el lado del pasajero. Que los tornillos en el bloque justo debajo de la cabeza. ver http://www.myisuzuparts.com
Aug 02, 2011 | 1994 Isuzu Trooper
En donde esta el modulo inalambrico que abre y cierra los seguros
hola donde se encuentra el inmobilizador de una windstar 2001 ford ya estoy desmotivado nesesito ayuda x favor ya k estoy en un rancho y no puedo yevarla al mecanico
Jun 24, 2011 | Ford Windstar Cars & Trucks
Donde se encuentra ubicadoel el sensor que enciende y apaga el fan cuando el refrigerante se calienta Saturn 97
El sensor se encuentra en el pase del líquido refrigerador en la parte posterior de la culata.
Fig. 5: Removing the coolant temperature sensor
Hope helps (remember to rate this answer).
Jan 11, 2011 | 1998 Saturn SL
Donde se encuentra el numero de chasis en el nissan Pathfinder modelo 1994
donde se encuentra ubicado el numero de chassi de una nissa pathfinder 2000
Jan 09, 2011 | 1994 Nissan Pathfinder
Tengo un control nuevo de dish y no puedo cambiar los canale no se como programarlo
Mi nombre es Kimberly Escobar, representante de servicio al cliente con DISH Network. Siento mucho que este teniendo un problema programando su control nuevo con el recibidor. El procediminto es el siguiente: primeramente en la television donde esta el recibidor tiene que ingresar la pantalla llamada "System Info" esto lo puede hacer oprimiendo el boton de System Info enfrente del recibidor o puede sacar la tarjeta que se encuentra adrento del recibidor, en unos segundos sale la pantalla System Info. En la pantalla de System Info donde dice "remote address" va a ver una cajita blanca que adrento contiene un numero. Usted va a oprimir el boton de SAT hasta que los demas botones se iluminen rojos, una vez que se iluminen ingrese un numero entre 1-15 (pero diferente al que se encuentra adentro de la cajita blanca) seguido por el signo de numero (#) y oprima el boton de Record 1 vez, el boton SAT debe de iluminarce 3 veces. Trate de usar su control deberia funcionar. Espero esto le ayude tambien puede referirse a este link http://www.dishnetwork.com/SupportSection/remote-setup aqui encontrara todo el procedimiento. Si necesita mas ayuda o tiene preguntas por favor contactenos directamente al 1800-333-DISH gracias!
Nov 21, 2010 | DISH Network IR Remote Control
HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
