Question about Indesit 24 in. DI67 Free-standing Dishwasher
1st and 2nd lights flashing? - Indesit 24 in. DI67 Free-standing Dishwasher
Its broken cant do qanaything with it
Posted on Oct 21, 2013
On/off light flashing with 1st and 2nd light flashing as well. dryer will not work
These blinking lights refer to a trouble code that is usually listed in the users manual for most common problems. If it's not listed then it will only be available in a service manual.
Jun 21, 2015 | Dryers
I have a 2003 Mercury Mountaineer, the O/D light keeps flashing as the truck trys to shift from 1st to 2nd gear. I had a transmission flush thinking that would solve the problem but it didn't. I c
The flushing could make it worse
I never flush a trans,could put sediment
into solenoids
Have a trans shop diagnose & replace the
clogged or failed solenoids inside the pan
Dec 05, 2012 | 2003 Mercury Mountaineer
Dishwasher lights flash half way through program
you will have to consult your owners manual
Jun 07, 2012 | Dishwashers
Novotronic 1918 front load washing machine- not spinning 1st and 2nd rinse lights flashing
the flashing lights mean it's "disabled". You need a qualified repairman to service it further.
May 06, 2012 | Washing Machines
Power light flashing red on router
READ THIS AND PERFORM IT TO TRY TO RESET.IF THIS DONT WORK POWER OFF THE ROUTER AND THE MODEM FOR 20-30 SECS.THEN POWER ON:1ST-MODEM
2ND- THE ROUTER
Apr 10, 2012 | Computers & Internet
4gb usb cannot be detected on my computer. how to fix the problem?
Try it on the other pc just to see if its working atleast,if yes then try it back to your PC but using different usb port.or also go to my computer management then check your Universal serial bus controllers if not showing any errors rght click on them and scan for Plug and Play complaint components.
Sep 04, 2011 | HP Computers & Internet
2nd controler not logging onto system to allow 2nd player but lights flashing as though trying to log on
There are 2 possible issues.
1.) That second controller is back (not likely since you're more than likely alternating 1st and 2nd controllers)
2.) Your bluetooth pcb chip needs to be replaced inside your Nintendo Wii
It would have to be sent in for repair.
Dec 31, 2009 | Nintendo Wii Console
Overdrive light flashes on and off
This will occur if the control solenoids that are located inside the pan on the valve body, are malfunctioning. First, i would check the fluid level. if the fluid level is proper, have the tranny flushed and change the filter as well. If this doesn't fix the issue, go ahead and replace the control solenoids.
Aug 24, 2009 | 1999 Ford Ranger SuperCab
Overdrive light is flashing and tranny is slipping in drive and 2nd
my overdrive light is flashing due to a shattered speedo cable tip. check your fluid level. you may have to change the tranny filer and redo all the fluid.
May 21, 2009 | 1992 Toyota 4Runner
Lexmark x2500
There 3 light on the printer that able to indicate to user when problem occur. Find your printer error accordingly as below and may solve your printer problem.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
Hope this help.
YBC (/\)
Feb 05, 2009 | Lexmark X2500 All-In-One Printer
Indesit 24 in. DI67 Free-standing Dishwasher Logo
47 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
noel
noel
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
