Question about Compaq Presario Notebook
A900 bios update windows 7 - Compaq Presario Notebook
    Sergeant:
    Champion:
  • 272 Answers
Goto --> http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2100&lc=en&cc=us&dlc=en&sw_lang=&product=3641176
  1. scroll down to "bios"
  2. download file
  3. Execute SoftPaq .EXE
  4. follow directions.
Posted on Oct 21, 2013
2 Suggested Answers
  • 2291 Answers
SOURCE: sound is not produce from
First verify you see a small sound icon in the Systray . If this icon is missing follow the below section
1. Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start.
Now next you can do is
If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button.
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Sep 14, 2010
Bios update for windows 7 {sp27726}
You should be able to restore it to an earlier time before you added the Bios update. I've read so many problems after bios updates, that I don't install mine when I get a notification of one available.
Jan 26, 2013 | HP Compaq nc6000 Notebook
Tip
Do not update Lenovo E430 bios to V2.54
Updating Lenovo Edge E430 could destroy your motherboard and cost you $450. Latest bios update is V2.54 and will update but leave you with a non bootable computer with no access to setup. Do not ever remove the power cord, battery, and bios backup coin cell battery at the same time. Result is Instant destruction of your system board. Update of bios up to V1.18 is okay but I would not activate the UEFI bios. Read all update directions carefully to understand procedure. Windows 7 and Windows 8 have different procedures.
on Feb 12, 2014 | Lenovo ThinkPad Edge E430 Laptop Computer
I need a gateway gt5426e bios update for windows 7 64 bit
There is no bios update for this model. there should be no problem installing 64bit windows 7.
The athlon 5200 is a 64bit chip so there is no problem there. If you cant install and you think its bios related then reset the bios by either shorting the rtc pins or remove the battery and refit after 10 mins. make sure you reset the bios back to defaults before you make any changes to it.
Jul 16, 2011 | Gateway GT5426E Refurbished AMD Desktop...
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
VGN-N230N can not read SD card when install windows 7. (vista is ok)
Download all the windows 7 updates and install then restart. Windows update are not only updating your windows 7 but also updating your hardware driver. After updating try again your sd card or if still the same can not read try some memory card reader then test it to your laptop. Have a nice day.
Mar 26, 2011 | Sony VAIO VGN-N230N/B PC Notebook
P4m800pro-m v20 random reset I have windows 7. I
Your not going to be able to update the BIOS without having XP installed on the computer.
I had the same problem myself as a motherboard i had would not update with Win 7 installed.
If you have a spare hard drive and an XP install disk then i recommend installing XP on that and then download the exe BIOS update file and run it from within Windows to update the BIOS.
After that just turn the PC off, put back your Win 7 hard drive and your good to go.
Regards.
Jul 02, 2010 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Problem with ibuddy ECS A900
Found out computer got so hot DC plug melted;
The thing is that it had a poor Ground so ran my own Ground.
Works Fine Now Bill
Nov 21, 2008 | Computers & Internet
Updating bios, iBuddie A900, Ubuntu.
Go to bootdisk.com and download Driver Free Disk For Bios Flashing. Click the link #1 next to it. It is right there on the front of the page. After that throw a floppy drive in your pc. Run the program I made you download after inserting a floppy. It will create a floppy image. Then take another floppy and copy the 2 bios files you got from the manufacturer ( the exe and the bin file) and copy them to the second floppy. Now boot the pc from the first floppy. Once it says A:\ pop the floppy out and switch it. Dos will continue to run from your system ram. Now make sure the second disk is in. Run the exe in dos. Then once in the exe. enter the name of the bin file. Remember to include the file extension. Back up your original bios file if it gives you the option. It will copy it onto your floppy just incase your new bin file is corrupt. Then you can use this process again if everyting is screwed. Do as the prog says and it will do the rest. Enjoy!
T0X1K66O
Apr 26, 2008 | Intel Motherboard
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
