Question about Endurance TF6iHRC Treadmill
E2 recalibrate on a true treadmill. No power. How can I fix it?
    Top Expert:
  • Endurance Master
  • 12,223 Answers
See the video and fix it. God bless you
Posted on Oct 22, 2013
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Sierra motorized treadmill with e2 code error
E02" You may not have enough voltage going to the machine. Turn the machine off and on
again at the switch at the rear of the treadmill. If this does not fix the problem you may have lower board problem see the diagrams attached and fix it.
God bless you2_4_2013_6_08_21_pm.jpg2_4_2013_6_09_23_pm.png2_4_2013_6_09_37_pm.gif
Feb 04, 2013 | Exercise & Fitness
E2 error code on my Tempo 612T treadmill
adjust and clean the speed sensor, and tight the connector very well, see the diagram
2) test the input voltage motor, if there are voltage the motor replace
3) test the output voltage board, if there are NOT voltage , the board is faulty, replace.
God bless you
Nov 11, 2012 | Exercise & Fitness
My Exerpeutic TF1000 treadmill shows a E2 error, motor will not start.
see this steps and fix it.God bless you
This is probably a 1( faulty speed sensor, adjust it , clean it and tigh the plug very well see the diagram attached. 2( test the input voltage motor, if there are the motor need repair 3( test the output voltage board, for input voltage motor, if there are NOT the board is faulty see the block diagram . The error codes will differ between makes and models but could be e1. or e2
Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Oct 01, 2012 | Ironman Exerpeutic TF1000 Walk to Fitness...
E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
Touch screen not hitting right keys. When recalibrating touchscreen, it never ends and I have to reset/reboot.
you can buy the app PowerDigi from palm powerups, it let you fix calibration problems up to 70 points, it worked just fine with my E2
Apr 08, 2010 | Palm Tungsten E2 Handheld
My Trimline treadmill 1050.E2 is showing an 'E2' on its screen and not working any more.
Hello all,
I have the same issue - it Shows "E2" on the time Display...
I already checked the Speed sensor and inclination potentiometer and both are OK... Moreover, I found that EEPROM Memory (Microchip 93LC46) is broken (reads "00"). After replacing it, I Need a way to reset / recalibrate the treadmill. I found on some Forums that there shall be a key combination (Speed+ & Start / Stop or similar) but None works for me. Could you please (if available) post the User Manual page describing the calibration entry? Or, maybe, advice a way to calibrate the 1050? Even the EEPROM Content (I guess the it is an issue) will be really helpful. Thank you in advance,
Milos
Oct 06, 2009 | Nautilus Exercise & Fitness
Endurance TF6iHRC Treadmill Logo
85 people viewed this question
Top Endurance Exercise & Fitness Experts
Electro Med Services...
vinayghl
Ron Dufek
Ron Dufek
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
