Question about Stoves Kitchen Ranges
The white dot on the oven dial has moved, I now don't know what the temp is set at. I have taken the knob off and found a broken black disc.
  • Shaun Walker
    Shaun Walker Oct 22, 2013
    The model number is 050564157, serial number 40458679. I believe the part could be called a (stainless) indicator disc oven. the temp goes up to 240 degrees
    Top Expert:
  • Stoves Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Oct 21, 2013
aborcass
  • 2651 Answers
SOURCE: I have a hotpoint RGB745 oven temp problem
sounds like abad oven ignitor issue, repalce hte ignitor nad it should light everytime
Posted on Mar 16, 2008
Maytag317
  • 1136 Answers
SOURCE: My son just bought a used Caloric self-cleaning
Hi, It is the wrong knob. Do all the burner knobs look the same?
The oven knob has to have #'s on it so you know what hte temp is.
Please get me a model # and I can get you the part # for the knob you need.
Vic
Posted on Jul 15, 2009
  • 534 Answers
SOURCE: BROKEN STOVE KNOB
try web site www.firstsourcesupply.com they should have the parts as long as you have ser# and model# they can ship to you. Good Luck
Dave
Posted on Aug 26, 2009
  • 491 Answers
SOURCE: viking vdsc305 white round grid like disc fell into my oven
THIS SOUNDS LIKE YOUR GRILL ELEMENT .
Posted on Oct 18, 2009
erpaalai
  • 999 Answers
SOURCE: my Temp knob on my Hotpoint gas oven, doesnt turn
The knob should have a flat spot to line it up on the shaft. Likely the knob is cracked and spinning on the shaft.
Eric
Posted on Nov 22, 2009
Nardi oven F86
I have a Nardi f86 but I Don't know how can I used the Bud ( knob ) of the furnace, please can you help me, thanks verf much, greetings of ANNE
Jun 03, 2013 | Ovens
We are renting a property with a Westinghouse mod 05-208307, never used it before, the setting have worn off around the oven nobs and don't know what they where pls help, can use over
The knob is the image of this link http://www.repairclinic.com/PartDetail/Knob-Dial-or-Button/5304441580/1063188 is pretty typical of all westinghouse knobs, that one shown is for westinghouse and perhaps can give you a good idea of the temp. set based on how far you turn it
Gene
Aug 13, 2011 | Ovens
Pizza, banana bread, etc. doesn't get done in the middle.
some oven temperature dials are adjustable by pulling knob off,turning a bit and pushing it back on in a different position.use an oven thermometer to determine the accuracy of your control knob.adjust knob or make note of difference between dial setting & thermometer reading.i.e.knob is at 350* thermometer says 300* set knob to 400* to achieve an oven temp of 350. could you E-mail me a slice of banna bread?
Sep 27, 2009 | Ovens
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Oven temp 30 degrees low
Usually you remove the temperature control knob. A screw on the back can be loosened to allow the dial to be moved to correlate the temperature in the oven to the the setting on the knob. Tighten the screw, put the knob back on and you are good to go!
I hope this helps
Jan 02, 2009 | Kitchen Ranges
Farberware Turbo Oven T4850- can't understand temp dial
Use an oven thermometer to test it the temperature at the various dial settings to see which is which.... Good luck!
Dec 08, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Pioneer 301 cd player
I found a fix in another thread. I tried it last night, and it worked. Nothing was broken; a moving plastic piece had just jumped out of its track. Here's the fix:
1. Remove the cover (2 screws on each side & 3 in the back).
2. Find a small white arm (more or less cylindrical, about 1" diameter, & about 3/4" long) and a longer (4-5"?) thin black arm in the center of the unit. These parts load/unload CDs to/from the playing area. You should see that a little knob on the white piece has jumped out of its track in the black piece.
3. Carefully put the knob on the white piece back in its track in the black piece. That should do it.
Feb 02, 2008 | Pioneer PD-F1007 301-Disc CD Changer
Jenn Air 88370
You need a new knob part y715403 . Turn knob clockwise first clik should be bake position
Jan 08, 2008 | Ovens
Kitchen Ranges Logo
41 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
