Duplo dc 8 MINI COLLATOR
My problem is with powering up the machine. It began with the machine going on and off rapidly when switched on. It would eventually settle down and work normally. This has now stopped and the machine fails to power up when switched on.
  • Pat Dunne
    Pat Dunne Oct 23, 2013
    As far as I can figure , the problem would seem to be on the circuit board. I don't have sufficient knowledge to check that out. When the machine was going on and off the lights in the control panel were doing likewise. They are now failing to come on. There is a flap on the bottom of the machine that moves when the machine is switched on, and that is the only sign of life there is. Fuses etc. are OK.
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: lexmark z611 problem
Check that there is no paper inside.
Remove cartridges and put them back.
Reinstall drivers using the printer disk.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Posted on Dec 05, 2008
tehnik_bdg
  • 91 Answers
SOURCE: i have a sharp al-1041
Your machine might be low on toner, replace the toner cartridge
Posted on Apr 14, 2009
goodgold
  • 389 Answers
SOURCE: Paper Jam 8-112 when power on Xerox DocuColor DC 1250 Printer
You it is necessary to make sure visual(optic) to see the sensor(pick-off) of that node(knot;element), which(who) you is informed.Byvat that conk or клинят sensors(pick-offs) of the passing, electronics in this case her(its)(her) fault is practically excluded. Extremely(Most) seldom(rarely) such быват.I work(operate) 18 years I had 1 or 2 times, but only mechanical damages much(highly;very much) often were. The Sensor(Pick-off) conks or клинит, when remoove the stuck paper. I am simply(merely) run away that reason in sensor. Good luck you!
Posted on Sep 20, 2009
  • 39 Answers
SOURCE: FAILS TO POWER UP WHEN SWITCHED ON
You may have some bad capacitors in the power supply or bad surface mount fuses in the LCD inverter.
Posted on Dec 26, 2013
Error E-2-2 on tower A on Duplo DC 10000s
Contact local printer support technician, because printer servicing required so, better of options printer support technician call and full printer servicing do.
Thanks,
Sep 17, 2014 | Office Equipment & Supplies
Dec 26, 2013 | Televison & Video
Brother Fax 575 Manual
Duplo and Karagatan were early forms of Philippine drama.The Duplo was a poetic debate by trained men and women in the ninth night, which is the last night of the mourning period for the dead. The Karagatan was also a poetic debate like the Duplo, except its participants were amateurs. Both were held in homes and their theme was about a ring that fell into the sea.
Jul 13, 2013 | Office Equipment & Supplies
Paper jam
Jul 13, 2013 | Brother MFC-J410W Wireless Compact...
The machine was jamming. I pulled the collator away from the base of the image runner. The paper was only 1/2 in the black box and 1/2 up the upper section that the paper goes through. After the paper...
I problem on duplo collator 10000s, is missfeeding the paper, don't pick the the paper, i set the correct hight, and **** pressure, i technician toll me that power supply need to repair , but i don't trust, just some one gime adviced
Oct 28, 2010 | Office Equipment & Supplies
Lost Power Adapter for Unicom Mini-switch/8 8 port
method 1: buy a power adapter that has a switch controlled output voltage - they usually have 3V - 4.5V - 6V - 7.5V - 9V and 12V selectable output. Start with 6V and if its not working unplug, select 9 and try again etc. etc.
method 2: open the case and locate an electrolytic capacitor right near the power plug - the biggest one. Note the voltage (for example it may say: 1000uF/15V) and have in mind that your device MUST work at a LOWER level that this.
you can combine the two methods to be safe...
Oct 02, 2009 | Port Incorporated 8-port 100Base-TX Mini...
Xerox 6115 mfp has please wait on screen and has
General Troubleshooting
Product Will Not Turn On
Cannot Print the Configuration Page
Probable Causes Solutions
The power cord is not correctly plugged into the
outlet.
Turn off the product, confirm that the power
cord is correctly plugged into the outlet, and
then turn on the product.
Something is wrong with the outlet connected to the
product.
Plug another electrical appliance into the
outlet and see whether it operates properly.
The power switch is not correctly turned on (I
position).
Turn the power switch off (O position), then
turn it back to the on (I position).
The product is connected to an outlet with a voltage
or frequency that does not match the product
specifications.
Use a power source with the specifications
listed in Electrical Safety on page 1-2.
The tray is empty. Check that at least Tray 1 is loaded with
media, in place, and secure.
The product’s covers aren’t closed securely. Make sure the covers are closed securely.
Close all covers gently to avoid jarring the
product.
There is a paper jam. Clear the paper jam.
Driver Problems
With Pages/Sheet on Multiple Copies, the Output Is Incorrect
Booklet Left and Right Binding Output Is Incorrect
Did you set the correct date and time? Ensure you have set the correct Date and
Time on the control panel, through
CentreWare IS or the MCC.
The backup battery has reached the end of its
service life.
Replace the backup battery.
Media or settings are not correct. Make sure the duplex unit is installed and
enabled in the product driver.
Make sure that you are using correct media.
See Supported Paper and Media on page 6-2.
Do not duplex custom-sized media, envelopes,
labels, postcards, thick stock, or
transparencies.
Make sure that you have not mixed media
types in Tray 1.
In the product driver choose "Print on Both
Sides".
Both the driver and the application have been set to
Collate.
For Pages/Sheet on multiple copies, choose
Collate only in the driver’s Basic tab. Do not
set collation in the application.
Collate.
For Booklet Left Binding and Booklet Right
Binding, choose Collate only in the product
driver’s Basic tab.
Do not set collation in the application.
Status Messages
Message Definition Solutions
CANCELLING JOB The job is being cancelled. No action needed.
*ENERGY SAVE* The machine is in Energy Saver
mode to reduce power
consumption during periods of
inactivity.
*PLEASE WAIT!* After replacing a toner cartridge,
or after rebooting your machine
after environmental changes,
your machine automatically
pauses to do an Auto-Image
Density Control (AIDC) cycle.
This process is provided to make
reliable machine operation with
optimum output quality possible.
The machine is warming up.
Aug 19, 2009 | Xerox Office Equipment & Supplies
E 803 when machine is turned on
Hello sir;The error code you display including so many mesnings; transfer unit level switch, left front interlock switch, DC power supply, DC fuser board, DC driver board, CPU board, DC power cut relay.
My suggestion go to check al those switch first if still don't work then go to others.
Jul 18, 2009 | Canon CLC 1120 Color Copier
81 people viewed this question
jasbo
jasbo
