Question about Frigidaire ATF6000ES Front Load Washer
Starts to call for water then stops, and I can hear a light hum.
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Nora, thank you for allowing me to assist you!
Often when a washer hums, it is because the drainage hose/pump of your appliance may be clogged due to not being able to properly drain and dispose of the water and detergent solution. Therefore the hose/pump needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Best of luck!
Posted on Oct 22, 2013
Mr Steam MS Super-1 kW: 10 doesn't generate steam
the first thing the generator should do when you hit the on button is fill. You will hear the water entering the tank. Once the water stops it indicates that the water has reached the water satisfied level, after which you should hear a loud click(your contactor engaging for the heat cycle, newer units will have all three light on the side lit). After this point is you aren't getting any steam after 5 minutes it probably means your heating element may be damaged. It would be best to remove the element at this point from the left side of the unit via 6 bolts and 2 wire leads. Any physical damage on the element such as a pinhole pop, burn mark, melting, or scar will surely prevent the element from heating
Jan 10, 2014 | Mr Steam Electrical Supplies
Light goes out and turntable stops, but still hums like power is still on.
You have a bad door switch that will need to be replaced.
May 13, 2012 | LG Microwave Ovens
Buzzing noise
hi, it sounds like the brushes on the motor 2 plastic blockes sit either side of the motor thses are made of carbon and wear down can cause the motor to stop working hope it helps
regards
shaun
Jan 05, 2012 | Washing Machines
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Whirlpool Calypso runs for 40 seconds and stops.
That is wxactly what mine is doing and it is only 3 to 4 yeaers ol
Jan 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
