Electrics not working on baxi kingston deluxe gas fire
3 Suggested Answers
  • 3315 Answers
SOURCE: Baxi Bermuda VP gas fire.
try cleanig the spark elctrode could be dirty use some steel wool carefully to clean it
Posted on Jul 25, 2010
  • 3315 Answers
SOURCE: i want to use my baxi bermuda gas fire just as a fire as having a combi boiler installed is it possible
yes a combi boiler has to be piped so they would cut off the pipes to your baxi and you can ues it as a gas fire only
Posted on Nov 07, 2012
How to remove thermo copling and thermostat from my baxi bermuda 401 back boiler
You will to remove the fire at the front .You will need to take the case of first , On the left there is 3 way gas shut off you will need to shut off the gas to the fire and disconnect the line to the fire . there are two res on the side off the fire take them out slide out fire.you should see a copper wire going in to the heat exchanger this the is thermostat bulb remove screw and pull out you will see plate on the front remove two screws at the top and two wingnuts at the bottom take it off this will expose the burner tray you should see burner tray with the controls . If this all to much then call in a gas fitter to do the work .
Jan 28, 2017 | Heating & Cooling
I want to use my baxi bermuda gas fire just as a fire as having a combi boiler installed is it possible
Nov 06, 2012 | Heating & Cooling
Baxi Bermuda 5 bbu has just stopped firing up ,pilot light good
The unit is clogged up. Pull it apart and blow it out. If nothing is cracked or damaged it will fire right up
Oct 11, 2012 | Heating & Cooling
How do i replace the coals on my baxi bermuder fire after serviciving
if you go to the potterton baxi wedsite you can down load a manual for you fire with the coals in the postion or how to put them back in the right way round ,
Nov 30, 2010 | Heating & Cooling
We have just moved into an old house with a Baxi open fire and have no idea how to use it. Do all Baxis have boilers? How do we find the model name/number? Is there any risk in using it if the backplate is...
baxi do boilers they are on the baxi potterton wed site, but they are gas would not use with the back platecracked this old fire place you may have trouble finding parts if any , try someone one that deals with woodburners of fire places , they could well be you bestline to go down or a chimney sweep
Oct 15, 2010 | Heating & Cooling
Baxi Bermuda VP gas fire. No spark to ignite the gas burner, has the spark generator given up?
Jul 24, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
How to arrange the gas fire pebbles for a valor soraya gas fire. My little boy has messed around with the pebbles and ive noticed that the pebbles are lettered and when i initially installed the fire, the...
the user guide can be download here:
http://www.partsarena.co.uk/baxi/System/DATA/Dx/DS1/user/4332/U14-4332/U14-4332.htm#zfuelbedrefittingceramicpebbles
Jan 07, 2010 | Valor Toys
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
