Question about EverFocus ECOR264-4F1/500 H.264, 4 Channel, Compact DVR with GUI, 500GB HD
One ptz camera not responding to controls - EverFocus ECOR264-4F1/500 H.264, 4 Channel, Compact DVR with GUI, 500GB HD
    Problem Solver:
  • 38 Answers
Cameras should have a reset button on the unit twords the back bottom, try this and re introduces the camera to the system.
If this does not work, try unhooking the power to this camera and reconnecting it . If that don't work recheck all your software setup and settings to see if something became corrupted. Other than that you may have a bad camera.
Posted on Oct 21, 2013
I have a cheap floureen DVR security system. I'm attempting to contact a electric rotating bracket which pans and tilts (it allows me to connect my cameras to it). My question is can I run this with the...
U have used Qsee, Swann and Lorex. I have a PTZ that has worked on several systems. There is a set-up for the actual PTZ camera which you appear to be aware of. The App or program you are using has a set up for a PTZ along with on screen controls for it in the program. If the DVR you are using is not PTZ ready there is your answer. Should have a 2 wire acceptors one negative one positive.
The movement you are seeing initially, are the PTZ powering up and self testing. What brand DVR are you using, and is is compatible with your PTZ camera?? LOL Swann Tech Service said my Lorex PTZ wouldn't work with my new hi-res system. Well it does...
I will try to look for your reply to continue to troubleshoot for you.
Cheers,
Chance
San Diego, CA
Dec 12, 2017 | Cars & Trucks
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
I can't access the "user settings" or the PTZ controls even as administrator. All I get is an empty box with a little x in the corner. Any help would really be appreciated.
Look for the administration tool on google. That will allow you to manually configure the device and setup users. If you cannot find it send me a msg back I'll send direct.
Jun 19, 2013 | Sony SNC-RZ30N Network Camera
Spin out of control
Reset the power to the camera and test first.
If it worked before you may have a wiring fault... or if it is new or someone tampered with it, the baud rate settings or protocol setting might have changed.
Apr 03, 2012 | Pelco CONTROLLER MATRIX- PTZ CONTROL
I need to replace a Samsung SCC-641 can't seen to find any online.
I have two non working cameras with working power control plates if you are interested. Contact pbyer14@gmail.com
Jul 19, 2010 | Samsung Power Supply, Control Plate for ...
I have a Pelco Spectra mini in a warehouse, we replaced the previous camera with this new one but the PTZ function does not work. The old camera worked for while and stopped. We moved the new one to...
Hi. Did you call Pelco's customer support? They should be able to talk you through troubleshooting the camera to at least determine if this is a defective camera or not.
Aug 18, 2009 | Cameras
I can't remove numbers that appears in screen when i use a Samsung PTZ camera. Can you help me?
sounds like you are seeing a display generated from the PTZ camera itself. can you access the camera's menu?
Jul 20, 2009 | Samsung SADT-100PM POLE MOUNT ADAPTER FOR...
Installing a pelco ptz camera using my old controller
pelco cctv ptz doec not moving can you give me a solution?thanks a lot.
Aug 18, 2008 | Cameras
PTZ controls stop working
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jul 09, 2008 | Sony SNC-RZ30N Network Camera
EverFocus ECOR264-4F1/500 H.264, 4 Channel, Compact DVR with GUI, 500GB HD Logo
73 people viewed this question
Top EverFocus Home Security Experts
Lawrence Oravetz
Are you an EverFocus Home Security Expert? Answer questions, earn points and help others
