Question about Panasonic KX T7436 Corded Phone KX-T7436
Turn on backlight - Panasonic KX T7436 Corded Phone KX-T7436
I have a uniden bc340crs scanner that is 1 yr old. my backlit window does not display any of the info for my scanner. i want to reprogram and the 2-9-hold thing does not work even after trying ronnie...
This is how you control the back light display on your scanner.
SNOOZE/Backlight - Backlight: Tap the snooze button to turn the LCD backlight on for 15 seconds. Press and hold to permanently turn on the backlight. Press and hold again to turn off the backlight.
Here is a link to the users manual as well. http://www.uniden.com/pdf/bc340crsom.pdf
Mar 14, 2011 | Uniden BC340CRS Base Scanner
I changed the batterys in my 1F78-151 thermostat and now the backlite does not work.....
• Display Backlight - (Not available on earlier models.) The display backlight improves display contrast in low lighting conditions. Selecting backlight ON will turn the light on for a short period of time after any button is pressed. Selecting backlight OFF (default) will keep the light off. Turn the display backlight feature ON as follows: 1. Press TIME and RUN buttons at the same time. The display will show "d-L" and "OFF" alternately
Dec 22, 2010 | Heating & Cooling
Does the Asus U50F have a keyboard backlight? & how to turn on?
No i'm sorry but that model has no keyboard backlight. If you wanted one which did have a backlight you would have to purchase a customised one.
Regards.
Apr 12, 2010 | ASUS Computers & Internet
Backlight does not light when receiving an email on the 8330
To turn on the automatic backlighting on a BlackBerry smartphone, complete the following steps:
  1. Click Options.
  2. Click Screen/Keyboard.
  3. Click Change Option in the Automatic Backlight field.
  4. Click On.
  5. Click Save from the Screen/Keyboard menu to turn on the automatic backlighting.
Aug 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Backlight
Hi Em,
You wanted to turn off permanently the backlighting on your IPod Nano? Your player uses that backlighting in order for users to see the display during poor lighting conditions.
If you really wanted to switch it off, you can access the backlighting settings on your player; Select Setting then go to Backlight Timer, Choose the option that suite your need
(Always On, Off, Turn off after a period of time between 2 and 20 seconds) or you can press and hold the Menu button down to toggle the backlight on your player to on or off.
May 05, 2008 | Apple iPod nano
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Panasonic KX T7436 Corded Phone KX-T7436 Logo
37 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
