Question about Cambridge Audio Azur 740A 2Channel Amplifier
Amplifier shows dc error and then reset - Cambridge Audio Azur 740A 2Channel Amplifier
    Champion:
  • 243 Answers
Fault at power output stage, add more information to help better.
Posted on Nov 08, 2013
I have a Harman Kardon HK990 which throws an error #005 if I switch it on with a digital input connected. If digital input is not connected, it turns on without any error and all buttons work as expec
If you had a bad amplifier, as suggested, the unit would most likely have a condition known as DC Offset. In this case, the amp would immediately shut off. As you said, the amp stays on, but you have no sound. First thing I suggest, turn the unit off. Listen carefully to the top of the amp. When you first push the power button, you should immediately hear one click, followed by a second click, within 5-20 seconds. If you hear that second click, you amp is likely not bad. If you don't, then you do most likely have a blown amp, with engages the DC Protection circuit to the microprocessor(computer within your unit).
Next step is to open your owner's manual. In there, you will find a procedure called, "Return to factory reset, or default". Follow that procedure, to reset the unit back to the factory settings. Those inputs are assignable, meaning that you can make certain inputs, analog or digital. You may have set one wrong by mistake. The reset will fix that. If you need more assistance, or would like to inquire about a repair, please visit my website at, Audioserviceclinic.com. By the way, I worked for HK, JBL and Infinity. Thank you.
Nov 28, 2014 | Harman Kardon Harman HK 990 Amplifier
Kdc-mp245 is in protect mode, how do i find what speaker is shorting out?
disconnect all the speakers , may still say protect , reset eeprom by holding preset 3 & 6 +reset , display may show dc error , hold preset 1 fpor a couple of secomds then hold preset 2 for a couple of seconds , then display should show dc1 - ok / dc 2 - 0 , then connect speakers one at a time , check wiring ,this may cure fault
Jul 25, 2010 | Kenwood DPX-501 CD Player
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and...
hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
Jul 18, 2010 | Kenwood KDC-MP342U Car CD Player
DC Offsets on output - protection don't allowd to switch on
you don't want to do this( bypass the protection0
that d.c. output will burn the coils in your speakers with out making a sound!! you have a biasing problem
or like you said a d.c. offset problem it is best to work on this problem with out a load on the amp, this will allow you to trace back where the trouble is starting at. caps will cause this sort of problem but leaky transistors can also do this, even diodes.
this will require an experienced trouble-shooter.
Apr 26, 2010 | Audio Players & Recorders
"Protector" error
I had a similar problem and went to Sony tech support.
Seemed my disc got stuck somehow...
Try reseting the system by holding the STOP and the EJECT and the POWER buttons together...
It should go to demo mode....
Then try PLAY to see if you can get the system to read teh disc...
then EJECT...
It took me several trys of doing this but it did work....on the 3rd try.
Aug 03, 2009 | Sony DAVHDX265 System
Error Code 63 on Phillips Plasma - what does it mean?
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Mar 30, 2009 | Philips Televison & Video
Sony car stereo
When the amplifier shows an offset fault, it's generally because there is DC voltage present on the speaker terminals. The amp has shut down to protect the speakers.
Aug 14, 2008 | Sony XM-754HX Car Audio Amplifier
System error 0013 benq DC E610 DIGITAL CAMERA
i had the same problem but now i have solved it.........its not a software problem..... the lens in fornt of the camera is not able to come out......just hit the camera 3-4 times on a table it will start working.......hope your problem is solved
Mar 01, 2008 | Nikon Coolpix 3200 Digital Camera
SHOW ''F61''
This is error code which system control detected either power irrgularities or dc voltage is detected from the speaker out put line.This fault we have noticed that both of them appears same time also.Pls change Amplifier ic TDA8920 and C1740 transistor and 27V1w zener diode.Transistor and zener diode is for voltage regulation and amp ic if the dc detect is active.Usualy change this three components same time.(this all is in power amp section)
Dec 17, 2007 | Panasonic SC-AK340 Shelf System
Cambridge Audio Azur 740A 2Channel Amplifier Logo
403 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
