Question about PaceMaster Exercise & Fitness
Bad relay message and circuit breaker is pushed in and stuck
    Top Expert:
  • PaceMaster Master
  • 12,223 Answers
Reset the machine and follow the step and fix it.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Posted on Oct 22, 2013
U turn circuit breaker to off to turn spa off
bad control board or relay stuck
Dec 30, 2017 | Pool & Spa
I have a 91 t400 kenworth. Having trouble with running lights and dont know what relay to check and see if it is bad any help would be appreciated
the relays are under the kick panel under the dash on the driverside, the fuse is also a circuit breaker just push the reset button and they should work
Dec 09, 2016 | Cars & Trucks
2000 Isuzu Rodeo, how do I reset the circuit breaker for the power windows
a fuse is a circuit breaker
if the fuse for the power windows is ok the the problem is else where -- could be a relay that is faulty
Sep 10, 2016 | 2000 Isuzu Rodeo
The dashboard and climate controls comes on when the key turned to accessory for about 30 seconds then fades out sand nothing works. It runs fine, all external running running light work fine as well
Check your circuit breaker and relays (owner's manual will tell you which breaker or relay is for the dash lights). You may have a "circuit breaker" that shuts off when heated and then starts up again when cold. Replace the circuit breaker with another one from the car and see if the problem. I solved, you have a bad circuit breaker. If that's the case, replece the circuit breaker. If not, you have a bad ground or short in the system, so get the system checked.
Dec 31, 2014 | 1993 Cadillac Fleetwood
Sunroof will not work
Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
The RAP relay is responsible for the radio and windows working after the igntion is turned off.
The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
(7) Door Lock Relay
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
Jul 10, 2010 | 2000 Chevrolet Blazer
I have three bulldog pushmatic circuit breakers that will not push back in? Are they gone or can they be reset.
Either they are bad, or are "tripping" If they won't push in when removed, then they are bad. Not unusual. You can still buy them. Look online or Box stores
Jun 17, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
Heat pump that runs with the thermostat in the off position
On heat pumps your fan is controlled by a relay on your control or defrost board. It is possible that that the relay is stuck or the points welded together or the control board could be bad.
They need to check all the incoming volts to the board, there may be volts coming from another source. If not and the fan still runs that would be something in the board is bad.
As far as tripping the breaker, it could be weak or something is drawing high amps. If the motor is running then it's probably the compressor, but I can't say for sure without checking it out. You also have a capacitor and relays that also could be bad or shorted.
Jun 10, 2010 | Heating & Cooling
Unit will not turn on
Unplug the vacuum unit from the wall. If it is hard wired turn off the circuit breaker
Jul 30, 2008 | Broan-NuTone CV450 Central Bagged Central...
Oven Failure Code F1
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
to fix your F1 error
92028 RELAY PCB, 105 C
Nov 20, 2007 | Dacor Preference RSD30 Gas Kitchen Range
Exercise & Fitness Logo
217 people viewed this question
Top PaceMaster Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
