Question about Canon imageRUNNER 2200
Broken paper sensor - Canon imageRUNNER 2200
What is your jam code ? which sensor do you need ? Do you know how to get the jam codes?
Posted on Oct 21, 2013
Testimonial: "I don't know the jam code, or how to obtain it. There is no jam that I can visibly see when I open the side where it shows the paper rollers."
  • Megan
    Megan Oct 22, 2013
I loaded paper and alarm still worked
could be a broken or misplaced paper present sensor lever. When the paper tray is loaded and place back into the machine a "paper present sensor" is actuated and sends a signal back to the machines logic. If this sensor is broken or missing, it never sends the signal therefore the machine thinks its out of paper.
Nov 21, 2013 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
My Kodak printer wont grab the paper in the paper tray
Amandasplace:
There is a sensor that is located where the front edge of the paper sits when you load paper. If you take all of the paper out of the feed tray and use a flashlight to look in the throat of the paper feed area, you should see a small piece of plastic (in the shape of a blade) sticking up. If you do not see that sensor flag it may be broken off, or there may be a small piece of paper jammed against the sensor flag, keeping it from moving downward when you load the paper tray. That can happen if you pull a mis-fed piece of paper out of the machine in the opposite direction that the paper normally travels when printing. When you load the paper in the machine, it pushes that sensor flag down, telling the machine that there is paper loaded. either the sensor flag is broken off or there is something jamming the paper sensor, keeping it from being pushed down by the paper.
Nov 23, 2012 | Kodak ESP Office 2150 All-in-one Printer
Document adf wont clear off
Please open ADF access cover first and check if any broken paper block the paper sensor. If no broken paper found, means the paper sensor is faulty and you replace with new one :)
Source:Printer ClinicInstant Download Service Manual
Sep 28, 2011 | Canon PIXMA MX310 All-In-One Printer
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
My printer(canon pixma mp190) keeps telling me that there is a paper jam, but i checked and there is no paper jammed, is it broken?
If i not paper in the printer,you must unzip the printer,the paper sensor is skipped.The paper sensor is under the scanner in the middle of printer.If the sensor id broken you need to replace,if the sensor is skipped try to put in the rigth position.Good luck!!!
Apr 09, 2011 | Canon PIXMA MP190 All-In-One InkJet...
Paper Jam cleared but?
It sounds like the paper sensor in the paper try is broken or jamed. Remove the paper tray and locate the paper sensor. Check if it is jamed in the up position or if it is broken.
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Load paper light stays on
load paper, if paper loaded and light stays on then the sensor that the paper trips is bad or the sensor arm is broken or the main board is broken...
try reseting the machine and failing that taking it apart and finding the sensor thats bad...
Dec 07, 2009 | Office Equipment & Supplies
Cannon printer pixma mp470 paper jam
hmm, could you be more specific?. But I'll try to solve anyway
Paper jam error occurs because:
  • Paper end not detected by paper sensor; set paper properly and press Stop/Reset button
  • Paper sensor broken; replace paper sensor
  • Drive assy broken; replace drive assy
But before it all please check if any broken paper or another material is in paper path blocking the paper to reach paper sensor.
Nov 09, 2008 | Office Equipment & Supplies
Error 1300 keeps coming up on myh Canon Pixma IP4000 although there's no paper?
Dear pants53,
Code 1300 indicates that paper jam error occurs. First, check whether any broken paper inside the paper path, remove it then press Resume/Cancel button. If problem still persist, means paper sensor error or paper sensor cam is broken. If it so, then I suggest you bring your printer to nearest service center.
Regards,
Nov 08, 2008 | Office Equipment & Supplies
Keeps saying paper error, no paper stuck, paper in tray, Brother HL-2030 series
You may also want to check for a broken or otherwise defective paper sensor somewhere in the paper path. If it is giving a paper out message- and doesn't even attempt to pull a sheet from the tray, then there is a sensor there which isn't functioning. If it does pull a sheet part way into the path, then gives an error, then a sensor there is afoul, or the paper is somehow getting stuck.
Paper sensors sometimes have a lever which comes in contact with the paper- if this lever is broken, needless to say you will have a problem.
Nov 04, 2008 | Brother Office Equipment & Supplies
Canon imageRUNNER 2200 Logo
18 people viewed this question
old marine
old marine
