Question about Electrolux Cooktops
Hairline crack 10 inches long on electrolux cooktop with 1 inch long "bubble" I did not drop anything on the cooktop
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Mainly caused when customer uses aluminium on the glass top.
only solution: new glass.
Posted on Oct 23, 2013
4 Suggested Answers
  • 338 Answers
SOURCE: Supporting a ceramic cooktop
Yes. It is. i always feel weary when i see it to however the top is not glass its ceramic so it is a little stronger.if you are in fear wrap tape all the way around the top and tight. if the top is tempered then wrapping the tape around it would make it almost indestructable.
Posted on Nov 26, 2008
SOURCE: Electric coils for old Thermador cooktop Model #TMH45
I have a thermador 45 cooktop with all the parts. Do you want to by the whole unit for $50.00.
Posted on Aug 06, 2008
SOURCE: Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Posted on Nov 18, 2009
How do u replace filter board on induction module of a 30 inch hybrid
Hello friend, thanks for your post!
I see you are searching for instructions on how to change the filter board on your Electrolux cooktop. Some of these intricate part replacements do require precision and patience, therefore when replacing electrical components or removing them from your appliance, I would suggest seeking professional assistance. One must be very careful as there certain replacement parts could result in potential harm. Best regards. -Matt
Oct 18, 2014 | Electrolux EW30EC55 30 inch Electric...
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
How to dismount KitchenAid cooktop model KECT 365
Why not refer this issue directly to KitchenAid. Maybe they can explain the disparity between what the installation sheet shows and what you actually don't see.
Dec 30, 2013 | KitchenAid Cooktops
My glass cooktop has cracked across the top left corner. It has created a triangle, about 1-1/4 inch on each side. Is this a flaw in the glass?
most of the time for this to happen something would have had to been dropped or excessive weight on the unit ... it is possible over time the unit had a unseen hairline crack and the heat has caused it to become worse... the glass for these units are ridiculous in cost but can be repaired...
several online sites sell parts.... a few reputable companies are
www.sears.com
www.apdepot.com
www.repairclinic.com
Jan 21, 2011 | Whirlpool GJC3034 Electric Cooktop
Can i install bosch cooktop in a 26-1/2 by 19-1/2
No you will not be able to put in that cut out. The reason why is you will have 2 inches on each side or 4 inches on one side.
Apr 17, 2010 | Bosch PCK755UC 30 in. Gas Cooktop
I have a whirlpool drop in ceramic stove and a burner isnt working. i had a repair man come and he was trying to pry the stove up but was having trouble because the person that insatlled it years ago...
When you dont replace the ceramic top that ios cracked could cause issues in your circuit board. The best thing t do is buy a new stove. The parts nad labor along is going to cost you about the same price as a new one.
Apr 25, 2009 | Stoves 23 in. Premier TC600I Electric...
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Wrong type cooktop securing bracket for tiled cabinet
If it were me, I would go to Home Depot or Lowe's and get a small roll of metal strap with holes every 1/2". Should be an easy find and easy installation
Dec 19, 2008 | Electrolux Cooktops
Clearence to hood fan
I just had a similar cooktop installed with a micro over it. From the bottom of the upper cabinet to the top of the burner frames you need 33 1/2 inches and from the bottom of the micro to the burner frames you need a minimum of 16 1/2 inches.
Aug 01, 2008 | Amana AKS3040 Gas Cooktop
Jul 20, 2008 | Cooktops
Cooktops Logo
76 people viewed this question
Top Electrolux Cooktops Experts
rugby prop
paulcarew
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
