Change flamerite corello lamp fuse
Lights not working. bulbs replaced
2 Suggested Answers
SOURCE: Breakdown with Flamerite Corello FO1
my Flamerite Corello fire does not work we had to have the circuit bard fixed within the first 12months of getting it and it went again over a year ago how can i fix it
Posted on Sep 18, 2011
I have a flamerite milan fire suite lights not coming on checked bulbs they are OK heating working also
No power to the fire: Check the wall socket, plug and fuse. No illumination: Make sure the fire is turned on. Check heater is working, if so change lamps. Illumination but no heat: The safety cut has operated see note on operating the Fire. Noise when illuminated: Due to moving parts, the electric fire will make a noise. Noise from the heater when in use: The sound of rushing air is normal. Logo
Jan 21, 2017 | Heating & Cooling
2007 chevy equinox license plate light won't work after bulb and fuse replacement
Do the park lamps work ? license plate lights get power from same fuse ! Check ground wire ! use a volt meter an do voltage drop test ! Voltage Drop Testing The fuse for the license plate lights is in the under hood fuse box -engine compartment ! fuse #12 RT PRK LAMP 10Amp .
May 23, 2015 | 2007 Chevrolet Chevrolet Equinox LT
Indicator not working
Check the light bulbs, the connections to the bulbs and the fuses for the indicators. Start with the indicator lamp fuses if all indicator lights are not working.. Their location is shown in the owners manual.
If the problem is isolated to just one or 2 of the lights, you need to check the wiring, the connections and the light bulbs. However there will likely be multiple fuses on the car covering the indicator lamps so check these also. I have 4 different fuses on my own car covering different indicator lamps so check the fuse information in your owners manual for details of which fuses cover which lamps.
If you do find a blown fuse is the cause, only replace it with a fuse of the correct amperage. If it is a 15 amp fuse that has blown use only a 15 amp fuse as a replacement.
If the fuses, wiring, wiring connections and bulbs are all fine, but non of the indicators are working, the likely problem is a faulty indicator switch on the steering column.
Feb 17, 2015 | 2003 Ford Focus
2004 Toyota Highlander, have no tail-lights, all other lights work ?
With the car jacked up and on safety stands, follow the wiring harness from the taillights to the front of the car. The wire is probably pinched, burned or shorted somewhere along the way. Did you have any work done on the bottom chassis area recently? Does sound like a pinched wire.
Sep 12, 2014 | 2004 Toyota Highlander
Aug 15, 2010 | Heating & Cooling
Have no rear parking lamps or dash lights when
In that car the fuse for the rear lights is also the same fuse for the dash lights. They did that so you would know when your tail light were out. Replace the fuse.
Apr 03, 2010 | 1995 Pontiac Bonneville
1999 GMC Envoy: replaced both GE 3057 lamps in left rear light assembly. Lamps both light. However depressing brake pedal does not initiate brake light. The righ rear brake light does work. The high mount...
The high mount brake light has its own fuse, so check that first. The high mount bulb is generally a stabdard type (there may be more than one bulb) or you can replace with an LED. As for the left rear bulbs not working when depressing brake pedal, check the bulbs again for any spring that may be broken. If the bulbs are still good, make sure there is sufficient contact with the socket. If still not working, have someone check it out further.
Feb 15, 2010 | 1999 GMC Jimmy
2006 Hyundai Sonata brake light problem
there is a tsb for the brake switch in 06 sonatas. it must be adjusted or replaced by dealership. is your check engine light on, if so its probably code p0504
Jun 20, 2008 | 2006 Hyundai Sonata
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
