Question about Sewing Machines
How to change wheels on diamond pacific pixie machine
How should the bobbin and casing be lined up?
If you will do a search on "Singer Pixie Plus Manual," you will be forwarded to the Singer site, and if you scroll down, there is a link to the instruction manual. In the Google listing, below that is a YouTube video, demonstrating your machine. Here's the link to the manual: http://www.singerco.com/support/instruction-manuals/search?man_model_no=Pixie+Plus
Oct 02, 2014 | Singer Pixie Plus Sewing Machine
How do i adjust the timer on a Pixie Plus Sewing Machine
Go to http://www.singerco.com Read the list & click on those that pertain to your problem. Jimmy
Dec 28, 2011 | Singer Pixie Plus Sewing Machine
Need the manual
Most Singer manuals can be downloaded from their website:
http://www.singerco.com/accessories/instruction-manuals
I see the "Pixie Plus" isn't available online, but the Pixie is:
http://www.singerco.com/uploads/download/612_pixie_manua(tri-lingual)l.pdf
They should be similar enough to figure things out. If you need more help, contact customer support at singer.com; when I have needed them, I've gotten same-day answers.
Dec 07, 2011 | Singer Pixie Plus Sewing Machine
MACHINE WILL NOT STITCH - SUSPECT IT IS OUT OF SYNC FROM HAND WHEEL BEING TURNED CLOCKWISE. hOW DO I SYNC THEW MACHINE?
That usually is not a do it yourself job, because you have to have the right tools and know how. Only problem is that to get it fixed will cost more than you paid to buy it. You can check in your area.
Jan 01, 2011 | Singer Pixie Plus Sewing Machine
Looking for a service center in Pune if not in India for Singer Pixie sewing machine
Go to www.singerindia.net and you can see their website with contact information. Looks like the headquarters are in New Delhi. Good luck
Nov 21, 2010 | Singer Pixie Plus Sewing Machine
I have the singer pixie the bobbin wheel does not seem to sit properly and the needle thread is not able to pick up the bobbin thread. The bobbin wheel does not rotate when it is supposed to... how does...
you may have the wrong size bobbins. Most likely you have the wrong needles they are not long enough. Check your manual for the correct size.
Aug 06, 2009 | Sewing Machines
Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Jun 25, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
