Question about Jasco Wet Look Cure Seal 0613-GL Set of 4
I want to strip the concrete floor that I use jasco seal 6 years a go do you have any product I can use .
    Habit-Forming:
  • 45 Answers
  • 1 Make sure that the surface of the concrete is cleaned thoroughly. Remove stubborn dirt or stains with a mixture of one part degreasing cleanser and two parts water. Rinse the concrete well and wait 48 hours before continuing.
  • 2 Use a large paintbrush or a long-handled paint roller fitted with a fine-nap roll to coat the entire concrete surface in a thick layer of soy-based or other environmentally-safe chemical stripper. Allow the stripper to eat away at the sealant for 10 minutes, scrape up the peeling sealant with a paint scraper or putty knife. Clean up all of the debris.
  • 3 Rinse concrete to remove all of the stripper. Let the concrete dry 48 hours. Apply the new sealant or the finish of your choice .
  • Posted on Mar 19, 2014
    Is there a concrete floor sealant that eliminated moisture seeming through the concrete slab?
    if you want to seal the surface a epoxy paint is good !
    but if the water come from under the concrete slab only a hole with aggregates ( small rocks ) and a swamp pump works fine !
    Oct 04, 2015 | Washing Machines
    How do I polish concrete?
    it can be done as most what is termed "marble" products is polished concrete
    talk with a masonry business as to how it is done but from what I have seen it will be a lot of "elbow" work with out power tools
    Jul 23, 2015 | Cars & Trucks
    How do I fix rotted wooden expansion joints in my driveway?
    there is a tuberous strip that is used as expansion joints in concrete. To get the correct thickness you may have to use several strips together. they are normally black in colour and you may have to lay in several strips first and then use something like a bolster ( brick cutter) to drive in the last strip. Talk with your concrete supply shop for advice and products ( shop that sells concreting tools and products.)
    grout will crack out at that thickness. Because you have such a wide gap (2'' or 4''). I would make up a good concrete mix using bondcrete ( brand name for concrete glue) in the mix and use that with a strip of black jointer either side
    Seeing how the timber lasted 40 years if you used treated timber this time it will last another 40 years -probably longer.
    Dec 05, 2014 | Cars & Trucks
    Can I paint over a previously painted concrete floor that was sealed with a polyurethane type product?
    you did not provide info on the type of the paint and what surface it will be used on - there is difference between the floor, desk, wall and car body... all are flat surface but adhesion and work of the paint differs.
    depending on the pre-existing paint, but you need always to "key-in" using 120 grit paper or 150 grit screen.
    if paints are of same type, then paint in - if these are two different paints, you need to strip or isolate old paint, and then use new paint.
    Sep 30, 2014 | Building Materials
    Repair concrete floor, large cracks in flooring
    install backer rod into cracks that are more than an 1/8 and use concrete sealer (in the caulking section of your local hardware store). The backer rod is used to reduce the amount of sealer you have to use to bridge the larger gaps in the cracks.
    Nov 05, 2013 | Mozilla Firefox
    My pool deck was coated with Behr solid deck stain and now there are several exposed cement areas where the paint has chipped Can can I use this product to cover the whole surface area before repainting ?...
    I'm not sure if your wording is incorrect or if you've revealed the problem. Usually the difference between paint and stain is paint is a topical product, stain penetrates the surface. If you've stained your concrete, it should be wearing off or fading, not chipping. If this is the case, the profile on your concrete isn't correct. That could mean the concrete was sealed before you stained it or there was something that wasn't properly cleaned before the coating was put on. The most common solution to concrete adhesion issues where I live/work is to etch the concrete prior to re-sealing it. On the contrary, if the stain is adhering everywhere except in one spot, it would indicate there was an issue only there (perhaps from a grill, pool chemicals,etc.). I'd clean the area well, perhaps pressure washing the entire area to make sure everything is properly adhering and re-coat it. Be sure not to stain or seal over loose 'paint'. It'll flake again if you do.
    Sep 14, 2013 | BEHR Premium Plus 1-Gal. Multi-Surface...
    I painted a section of my garage floor with a cup of paint 1/4c oil base acrylic mixed with 3/4 c water base latex...will it ever dry thoroughly? it is drying slowly and is really sticky. will I just have...
    did you ever try to mix water with oil? what was the result? are you sure that you can cross the street without adult holding your hand?
    unfortunately you need to remove all that paint, just drop few shovels of fine sand over, and scrape it... sand will adhere to the tp surface of the pain and will allow you to scrape it. after you scrape it off, use any degreaser or similar product to wash reminder off, leave it for few weeks to dry through and then in small patch try if it would accept latex pain, roll it very, very thinly and leave overnight, if it is dry (solid dry) after 24hrs and do not peel off, you can then use this paint on the rest of your garage floor.
    now, i would advice strongly against painting garage floor with any paint except concrete paint (they are usually water based with strongly alcalic ph), and after that use concrete seal. this should give you long lasting surface, sealed from oils, dust, water and whatever contaminant you can imagine in the garage.
    Sep 12, 2013 | Sherwin-Williams Best Look Latex Garage...
    Sauer sundstrand gearbox seal TMG 61.2 L1 112B Serial no. PX043210667 Think no.on seal is 145 245 14 or could be 145 215 14 Regards Ivor Reid
    The part numbers you are reading on the seal are the seal's dimensions in millimeters. I believe that the seal in the link below is what you are looking for. TMG Stands for Transit Mixer Gearbox. 61.2 is the gear ratio. The owners of Mixer & Plant Parts Mfg have been in the industry for over 40 years. Their phone number is 877-327-2116 and they can help you with virtually any concrete mixer part or concrete batch plant part:
    http://www.mixerandplantparts.com/product-p/301010.htm
    Feb 24, 2010 | Danfoss Sundstrand-sauer-danfoss...
    Jasco Wet Look Cure Seal 0613-GL Set of 4 Logo
    189 people viewed this question
    Top Jasco Tools & Hardware - Others Experts
    Are you a Jasco Tool and Hardware - Other Expert? Answer questions, earn points and help others
