Wallstar boiler i have a worcester wallstar wall mounted boiler it ran out of fuel, filled tank next day burner tripped out blead fuel but burner will not ignight plenty of fuel in system as you can smell fuel but still trips out ??
    New Friend:
It pops a lot and is noise when I turned it on, it's a NEW ONE
Posted on Oct 21, 2013
5 Suggested Answers
  • 69 Answers
SOURCE: i have a worcester 28cdi boiler and the pressure keeps rising..
you bled the radiators, so this is a water system not steam. Sounds like you expansion tank is "slugged" or full of water, so there is no place for the water to expand when it warms up. get some water out of the expansion tank
Posted on Aug 03, 2009
  • 7 Answers
SOURCE: empire mod# gwt-35-2 burner will not light periodically
I had the same problem when it would not light by itself I could press the sparker and it would light. I stold the limit switch from another one i was not using and put it in and it has not done it since. I think it was just getting weak.
Posted on Dec 09, 2009
heatman101
  • 43501 Answers
SOURCE: I have an ideal standard he30 boiler instaledi
You have a problem that the installer does not know how to fix so they are just stringing you along hoping that you will give up and find some one else or forget about it..
You need to tell them to
1. fix the boiler correctly
2.take it back out and give you a new one at their expense
3. or tell them you will call another comapny to fix it and will give the bill to them to pay.
You did not get what you have paid for... do not pay them any money to come out and troubleshoot the boiler.
The boiler should work as the instructions say or someone did something wrong...
Sometimes it is best to call the boiler company and talk directly to their Tech. Support people.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 24, 2009
Testimonial: "offerd good advice"
  • 3248 Answers
SOURCE: my boiler will not light worcester junior 24i
look at the water pressure gauge on the boiler it might need topping up ?
Posted on Jan 07, 2010
Worcester 25si water from overflow and gurgling from boiler when switched on
Check the filling loop is turned off.
Does the water pressure rise from cold to hot, if so the expansion vessel has gone.
Apr 16, 2014 | Heating & Cooling
Worcester 24i boiler..how do i re-ignite the pilot light??
Overheat thermostat has tripped. If a modern Worcester need to press reset on control panel.
If older style Worcester - Pull front cover off the boiler (just above control panel flap pull the cover from both sides forward to unclip and then lift upwards to remove cover) and you will see a little brown reset button - press this back down.
However the over heat thermostat trips for a reason - was the system running on low pressure? It could be the pump is sticking a bit (dirt in the system) which can be sorted easily by adding an additive (DIY packs available at Home-base) . Or it could be the pump has completely gone. If this is the case it will trip again as soon as the boiler clicks back on.
Apr 27, 2011 | Heating & Cooling
The water pressure on my Greenstar 25Si Worcester Bosch combi boiler is so low that the shower won`t heat up. Can someone please tell me how to increaese the water pressure as there doesn`t seem to be an...
The boiler has a filling connection which uses a filling loop to connect the boiler to the mains supply for the initial fill and subsequent fills.
See the link below from the manual you can buy the filling loop connection online or ebay its a simple task to replenish the pressure. Worcester GREENSTAR 25Si Instruction Manual Filling The System
Feb 06, 2018 | Water Heaters
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Worcester bosch greenstar 25Si?30Si pressure gauge showing high
a couple of things , is your filling loop disconected ? , and are all your radiators blead from air, have you got a high point where the air can get stuck in system say pipes going into roof etc you may need to fit a air release valve in line at highest point to remove the air from system , your boiler should be around 1.5 bar running preasure average setting . if you are constanly filling with water you could be exceeding the pressure valve limet which releases pressure from system this could be faulty ?
Feb 02, 2009 | Water Heaters
Starting a pilot light on a hot water heater
Hi blaineandhea,
I'm Harvey the Master Plumber.
Your statement is: You ran out of oil,so got more oil in tank.blead the lines.but now you cant get pilot to start
Every oil burner I ever worked on had a type of spark ignition. No standing pilot. If this is the case for you then the only reason it won't turn on is that the lines weren't properly bled. It only takes a little bubble to ruin the day. Don't be afraid to blead lots of oil, you should be catching it anyway to put back in the tank.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Water Heaters
My oil boiler is a Danesmoor SLPJ 20-25 with an Electro Oil Inter 2011 burner. The oil tank ran out and after refilling the burner ran ok for approximately 6 minutes, the control box chattered and the...
you could have a problem with a temperature sensor.
it would not be the flame sensor since it could not wait 6 mins to sense that there is flame in the unit.
could be a temperature sensor problem where it is sensing a temperature which could be correct but it is sending a wrong signal to the controller to turn off the flame and start another cycle.
tnx 4 using fixya,
drcool
Oct 04, 2008 | Heating & Cooling
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
