Question about Omega Juicers 8006
I have 8006 omega juicer...the augar is suck in the drum..i cannot take off the cap. please help
Where do i send my omega juicer to for repairs?
Omega Juicers Repair Form
This is a link to the official repair form for all Omega Juicers.
Jul 08, 2015 | Omega Juicers
Why does juicer not start when assembled and plugged in?
It has a 10 year warranty, but check the instructions as there are bound to be safety features on it to stop it working unless properly locked together.
Omega BMJ330 Commercial 350 Watt Stainless Steel Pulp Ejection Juicer...
Review
Omega BMJ330 Review JuicerReviewsDirect com
Manual is here. Doesn't look as if there are any safety interlocks in the drawings. Aha, there is a safety lock! It is good to read to the end :>) Page 23 states;
IF YOUR JUICER ISN'T WORKING
If the latch arm on the right side is not secure and properly in place the juicer's safety switch will not engage. Therefore, the juicer will not work. Assemble the juicer properly.
https://www.omegajuicers.com/media/manuals/EFS_BMJ330_390_Manual_JUNE2014_web.pdf
Aug 22, 2014 | Omega Juicers BMJ330
Omega 8006 locking clip is stuck and will not come off
Same. It was working fine and now the black end piece (where pulp falls out) is locked on and completely stuck!! No hope of it coming over. I need help.
Jan 09, 2014 | Omega Juicers 8006
Hello, I just received my omega 8006 and it wont turn on
This juicer has a 15 year warranty which you can contact the manufacturer or retailer you bought it from depending on their return policies and exchange it.
http://www.omegajuicers.com/juicers/masticating-juicers.html
Mar 16, 2011 | Omega Juicers 8006
Need place in 60439 zipcode to get omega juicer repaired
What's wrong, you might be able to handle it yourself.
You can also call Omega for help. 1 800 633 3461.
Sep 30, 2010 | Omega 1000 Juice Extractor
Need to replace latch arm omega juicer
First thing to do is call Omega and order a pair
at 1 800 633 3461 and also ask them for tips on
how to remove and install the arm. If your juicer
is older the new arms may not be an exact fit, and
you will have to do a little filing and improvising to
install them. Its helpful to remove the 4 screws on
the bottom to separate the base for better access
and view of the situation.
May 20, 2010 | Omega 1000 Juice Extractor
I have an Omega juicer. I need to ajust it because it tremble too much Thank you
THIS IS A NON EJECTION PULP JUICER AND THEY
WILL VIBRATE LIKE MY ACME. BEST FOR HARD
PRODUCE LIKE CARROTS, APPLES, CELERY ETC.
FEED PRODUCE SLOW AND STEADY.
Oct 02, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Omega 8005 juicer will not start
flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Jun 30, 2009 | Omega 8005 Juicer
Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Jan 25, 2009 | Omega Juicers Juicer 1000 Brand: Omega
One bracket broke. Tried to glue it with no success.
IF YOU ARE TALKING ABOUT THE LATCH ARM, YOU CAN BUY THEM FROM OMEGA AT
717 561 1105. TRICKY TO REPLACE. I REMOVED THE BOTTOM OF THE MACHINE AND
GAINED ACCESS THAT WAY. ONCE YOU SEE THE LATCH ARM SUPPORT PRY IT AWAY
FROM THE JUICER AND SLIDE IT OUT. CALL OMEGA THERE ARE 2 WAYS TO REPLACE
THE LATCH.
Sep 29, 2008 | Omega 1000 Juice Extractor
Omega Juicers 8006 Logo
37 people viewed this question
Top Omega Juicers Juicers Experts
Tom Chichester
David Payne
David Payne
Are you an Omega Juicers Juicer Expert? Answer questions, earn points and help others
