Question about Intel Computers & Internet
Sb pwr light keeps on / one beep and the PC turns off
I cannot turn on my Desktop (it has not been used for a couple of years). Once i connect it, the fans start working, and its beggins to work, but then a beep alarm sounds, and the pc turns off. And the sb pwr light keeps on... Anyone knows what this might be? I've tried to clean it all inside the best I can, I've unplugged and plugged back all the cables, and I've changed the location of the RAM card (as I read that one beep could be relate to that). But so far nothing... Thanks in advance
  • 54 Answers
Check that keyboard is plugged into correct port.
Can you Enter CMOS setup ? Try replacing battery on main board.
Posted on Oct 22, 2013
kornho
  • 781 Answers
SOURCE: Orange Light permanently on motherboard. PC won't start
1. motherboards for atx form factor pc's are powered even when the computer is off, particularly if you leave the computer plugged in to wall outlet... you better do not work on you computer while power cable is still connected to both, your pc and the wall outlet..
2. I found this thread that may be helpful, it may be the motherboard may have gone bad, cmos is corrupted or something may not be seated properly...it could also be one of these: Bad CPU, BAD ram, Bad power supply.. read the thread for details:
http://www.dellcommunity.com/supportforums/board/message?board.id=oplex_other&message.id=23925&c=us&l=en&cs=&s=gen
Posted on Sep 25, 2008
  • 190 Answers
SOURCE: Scaleo P Does not Start up, No Fan, No Boot Up Nothing at All
something is shorted or PSU has failed
make sure cards are seated down (with power cord out)
try if works ;) your good
if not next step is cord out an remove power and cable off the CDROM drive
try it, just go through all hardware till it starts
to determin what failed, if still same no boot then PSU has died
Posted on Apr 16, 2009
CompuFirm
  • 89 Answers
SOURCE: Sony VAIO RB30C (VGCRB30) PC Desktop Won't Turn On After reinstalling ram
Unplug the tower
Remove the ram and turn the tower on wait till it give you fast beeps. (telling you no RAM)
once that happens shut the system down by unplugging it again
Re-install your RAM and try to boot again
Posted on May 27, 2009
SOURCE: PC STARTS BUT NO VIDEO SIGNAL IS PRESENT AT THE MONITOR
i was wondering if this person helped you
Posted on Aug 25, 2009
  • 5 Answers
SOURCE: Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Posted on Oct 22, 2009
I turn the power on and my light stays yellow and the fans work but it beeps
The beeps you hear are BIOS Beep Codes and tells you what problem is keeping the computer from booting. We need at a minimum, the computer make & model or the motherboard model #. If you also know what BIOS it uses (Award, AMI (American Megatrends), Phoenix...etc), this was displayed during the boot process when the computer worked if you happen to remember it.
Once you know this we can find the code that tells what the problem is.
Oct 28, 2013 | Gateway 506GR PC Desktop
What means sb pwr
'SB' stands for StandBy. When the motherboard is connected to the power supply but not turned on the SB voltages are supplied to different parts of the motherboard. In some motherboards you are able to charge devices like Phone without powering on the computer, that's because of the SB.
The SB in turn triggers other voltages used for the motherboard.
Oct 13, 2013 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Gateway LX6810 Desktop turns on but will not boot up
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
here is the explenation to the beeps.
one beep means bad memory.
Apr 16, 2013 | Gateway LX6810-01 PC Desktop
A friend gave me a Dell Demention 8200. When I boot it it beeps 5times then 2 another 2 then once. Nothing shows on the monitor. Suggestions?
The reason you are getting the beeps is simply because there are some connections that have not been made in the system so when it is powering up it will not be able to come on fully.
Try to open it up and rerun all the connections that you can see. Turn it on first to see how it is faring inside. Then you turn it off and couple it back together.
Then you check the cable that connects the monitor to the System to see if there is any wrong connections made.
After running this check, your system will boot properly without any sound and it will bring up some information to the monitor.
Take care
Jul 07, 2010 | Dell Dimension 8200 PC Desktop
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
Fans comes on for 3sec
Here are a couple of things...heres the Intel site about this board, with connections (with a very clear front panel drawing) diagrammed:
http://support.intel.com/support/motherboards/desktop/d850gb/sb/CS-013238.htm
and here is a page of pictures of this model board to compare to youre to make sure it is the same board:
Jun 04, 2008 | Intel Desktop Board D850GB Motherboard
Compaq evo d500 does not turn back on
If its powering on, but the screen isnt turning on and the computer starts beeping, try replacing the ram.
Mar 15, 2008 | Compaq Evo D500 PC Desktop
Computers & Internet Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
