Question about Dometic Rooftop RV Air Conditioner
Water heater for vengeance 25v
Where do i turn on the gas on the water heater model sw6pe
  • Dometic Master
  • 6,674 Answers
Should be attached to manifold /lines from propane tanks. When propane tanks are on, it should be getting propane unless someone added a shut-off in line to it.
Posted on Nov 29, 2013
!990 Bounder By Fleetwood Water Heater is not lighting the propane
Check the gas line orifice for a spider web. Its possible the gas is not able to get past the web.
Nov 30, 2012 | Atwood Mobile Products Llc Water Heaters...
Turned down temp on Water Heater a little, and now we are not getting any hot water. Not even Warm. Whats wrong?
For electric tank: Push in the reset button located on upper thermostat.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
For gas tank, then more specific information might be needed for example if unit has power vent, when was the air intake cleaned, is the pilot lit, what brand and model number etc etc..
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
For tankless, or solar, or hybrid electric, gas boiler, or indirect, or RV heater, etc then please include brand, and model that appears on label on side of unit.
Sep 05, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Hot water heater pilot will not light
You have red wires connected to bottom of gas control valve?
Is this a power vent model?
What model, what brand water heater?
Is new thermocouple is finger-tight plus 1/4 turn and not shorted against gas control valve?
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Copy following link for safety magnet:
Magnet will click closed when pilot is turned off. Put butane lighter on end of thermocouple and listen for clicking sound.
http://waterheatertimer.org/pdf/Safety-magnet-Gas-control-valve.pdf
Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Bad gas control valve:
Low gas pressure, air in gas line, inadequate air supply, clean the air intake, tripped FVIR system, etc.
Aug 28, 2012 | Water Heaters
I have smoth's hot water tank. problem is pilot lite is off. how do u turn it on?
You have tank-type gas water heater with standing pilot light.
Instructions for lighting pilot light are usually on front of water heater.
Since water heaters vary widely, if you want specific information without guessing, then add a comment with model number that appears on label on side of tank, and also describe the gas control valve on front of unit.
This information will let expert located manual and look up specific information plus troubleshoot steps for that model.
Aug 24, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
We have a plumbing technician to repaire the water leakage out side of our house, which need to turn off the water supply to our house. After that, we found that hotwater will not turn on (burner light...
You have gas water heater.
Probably a tank-type gas water heater.
The plumber can fix water heater.
If you want to fix water heater yourself, then more information is needed to narrow down scope of answer.
1) Add a comment for possible help.
Instructions for lighting the water heater appear on front of water heater. Do those instructions include lighting the pilot light?
Will the pilot light stay lit?
On side of tank is a label. Label shows Brand, type (LP or NG), and model number.
This information can help narrow the type of gas control valve, and point direction for troubleshoot.
Add a comment with this information for possible help.
2) Do-it-yourself: Open following link for do-it-yourself resources to help solve gas water heater problems:
Generally the instructions show how to clean water heater parts, check venting, and show different types of gas controls, plus links for pilot light problems and cleaning air intake.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 24, 2011 | Noritz Water Heaters
My Honeywell Water Heater Thermostat will turn on for 30 seconds. Then it shuts down- wait 5 seconds turn it off EITHER with the ON/OFF switch OR by turning thermostat to off & back on immediately! If...
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
Aug 07, 2011 | Honeywell Water Heaters
I have a model 6G40PVW-40F water heater and we have no hot water... the thermostat light on warm/vacation is on and so are 2 other lights...If I diconnect it and re-connect it then it will start..the gas...
Most gas water heater problems today can be solved with yearly maintenance that includes cleaning burner parts, clean air intake, check venting, check electrical connections, bleed gas line, and check gas pressure.
Gas water heater manuals recommend yearly maintenance by service technician.
In past years, gas water heaters required less maintenance, but they were less energy efficient and more dangerous to operate.
Sounds like you have Intellivent gas control valve thermostat.
Open following link to identify gas valve and see error codes:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Error light on vacation + 2 other lights = 3 possible conditions:
1) Wiring error: check outlet with circuit analyzer:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
2) Pressure switch tubing not connected, air intake obstructed (clean intake), or vent exhaust obstructed (check for proper venting).
http://waterheatertimer.org/images/Test-water-heater-vent-400.jpg
3) System in lockout: Low gas pressure, hot surface igniter not positioned correctly.
You can do some of this yourself.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jun 30, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
When restarting my water heater the burner goes out when I turn the heat up. I have replaced the thermalcouple. According to the manual the next option could be a Combustion shutoff system was tripped. ...
The FV lockout varies by brand of heater... some require simple cleaning, while Rheem requires part
Following link has rundown for various models:
http://waterheatertimer.org/troubleshoot-flammable-vapor-on-gas-water-heater.html
Burner going out could be FV lockout, low gas pressure, or gas control valve thermostat:
Following link has troubleshoot for pressure and various models of gas control:
http://waterheatertimer.org/troubleshoot-gas-water-heater-thermostat.html
Oct 23, 2017 | Rheem Water Heaters
Rheem water heater model #82V661 serial # RH0106D11663 leaking water at lower panel. Water is coming from above wiring and control panel. Is this fixable or need to be replaced? Mfg date is 01/2006
You have 240volt electric water heater
Check both elements for leaking.
Check top of tank for leaking pipes.
If water heater is leaking from side of tank, then tank is rusted out and could rupture.
This tank must be replaced.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
My friend welded his tank to get more life out of tank, but he assumed the risk.
Hot water heaters are under pressure from heated water which expands.
If tank ruptures, water will flood out of tank and water will run until shut-off is turned OFF.
This causes major damage inside home.
Protect yourself first, and then let's talk more.
1) Turn off water at shut off located on cold water line above tank.
2) Turn off power to water heater:
Gas heater, rotate valve to 'pilot' so pilot is lit but burner does not turn ON.
Electric heater, turn off circuit breaker.
3) Open tub spout on hot side and let run a bit to relieve pressure.
4) Now your property is safe.
You can limp along with failed heater if leak is slow.
Turn heater ON when you need hot water.
Typical Gas heater makes 41 gallons hot water per hour.
Typical Electric heater makes 21 gallons hot water.
Shower uses 5-9 gallons hot water, bath uses 12-14 gallons hot water.
http://waterheatertimer.org/images/Water-heater-reference-guide-2.jpg
If you are going to install heater yourself:
Look at label on side of old tank to identify size and particulars.
I buy ordinary heaters from Lowes and Home Depot and always buy scratch-n-dent models when possible, because superficial damage to outer tank does not lower lifespan of heaters I have installed.
Buy same size heater if it worked fine before.
Buy new flexible water connectors.
Set water heater in drip pan.
Offer 10% less than price shown. Make them deal with you. Shop Ace hardware, Lowes, Home Depot. Kick the tires since you have a bit of time.
I know you have electric heater, but many folks read these answers, so I include info on gas too.
#1 rule) tankless heaters are a rich-man's toy, because tankless will never pay you back, and will become major money pit if you encounter 1 repair. Electric tankless heaters require larger electric service box. Gas tankless require larger gas line (larger gas line, more gas consumption, bigger bill unless you cut consumption)
2) How to install gas heater:
http://waterheatertimer.org/How-to-replace-gas-water-heater.html
3) How to install electric heater:
Read link above because many of same steps apply to electric.
The difference with electric, is turn off power, disconnect wires, and reconnect wires exactly like before. Set electric heater directly on insulated surface like dense blue styrafoam. Cut styrafoam in circle so it fits inside dip pan. Wrap entire electric heater with insulation blanket, except don't cover TP valve.
4) Connect bare copper jumper wire between hot and cold pipes to prevent stray current corrosion which will shorten life of tank. Make sure cold water line is grounded.
Also read:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free assistance.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone about any do-it-yourself problem.
Jan 07, 2011 | Rheem Water Heaters
No water comes out of the hot side of my shower or bathtub
Based on gas prices, often gas hot water heaters can be a more cost-effective option than electric models and preferred by many homeowners. However, gas hot water heater models can have their own set of problems that differ from electric versions. You will not find it difficult to perform some basic troubleshooting to resolve an issue with a gas hot water heater.
Instructions
  1. 1 Determine if the gas supply has been shut off. No gas will cause the hot water heater to stop producing hot water. Turning the gas supply back on should be your first troubleshooting technique.
  2. 2 Check the pilot light. If you are experiencing no hot water, the pilot light of your gas hot water heater may have distinguished. Turn off the gas source and place a match over the pilot light tube to relight it.
  3. 3 Adjust the thermostat of your hot water heater. If you find that the hot water runs out quickly or does not get hot enough, you may need to set the temperature of the gas hot water heater higher. Typically, set the dial between the medium and hot setting for adequate hot water.
  4. 4 Inspect the gas hot water heater. The burner orifice and flue can both become clogged on a hot water heater. Turn off the gas and use a wire brush to clean out any debris that may have become lodged in these sections.
  5. 5 Ensure that all the burner access covers are in place. If the pilot light will not stay lit, it could be due to exposure to drafts.
  6. 6 Flush the tank. Certain deposits can build up over time when using a gas hot water heater which can cause the tank to produce a banging noise. To flush it, turn the heater off and open the pressure relief valve and drain valve on the water heater. Use a hose to flush water through the system until the hose runs clear.
Thanks.
Oct 15, 2010 | Kohler Home
Dometic Rooftop RV Air Conditioner Logo
83 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
