Question about ETC SmartFade 1248 48 Channel Control Console
How do you reset the lights - ETC SmartFade 1248 48 Channel Control Console
  • Kevin DeYoe
    Kevin DeYoe Dec 19, 2013
    Hi chip rutledge, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? When you say "reset the lights," what do you mean? Have you set a lighting cue and need to get back to everything dark? Or are you having an issue with the backlight on the console?
Reset oil light
turn ignition on (do not start) press accelerator pedal to the floor and hold for 30 seconds, let off for 30 seconds, then turn ignition off allow an additional 30 seconds and start veh. if does'nt work 1st time repeat. this sounds strange but thats how to reset the oil change light.
Aug 27, 2012 | 2004 Chevrolet Impala
0% oil life
to reset the light with the doors closed key on press the gas down to the floor 3 times then the light should flash then its reset
Aug 27, 2012 | 2007 Chevrolet Cobalt Coupe
How do i reset the oil change light in a 2003 olds alero
turn key on (dont start engine) floor gas pedal 3 times 1,2,3. turn key off, now start engine it should go off, if not try it again.
Aug 03, 2011 | 2003 Oldsmobile Alero
How to reset service light on 2007 Acura MDX
The full procedure how to reset oil service light Acura MDX. After an oil change, if you like to reset any maintenance oil light for Acura cars. Or any error which appears on the display.
http://resetservicelight.com/reset-oil-service-light-acura-mdx/
Oct 14, 2010 | 2007 Acura MDX
How to reset the change oil light for a 2007 lincoln town car. Hitting reset button doesn't do it.
FIRST press and release the setup button to display oil life= xxx
then press and hold the reset button for about 2 sec it should then display oil life set to 100%
Just pressing the reset button when the change oil light comes on while driving will not reset the computer
Feb 15, 2010 | 2007 Lincoln Town Car Signature Limited...
How to reset check engine light and change oil soon light
You should not reset the ck eng light until you have repaired the problem. Its just going to come on again, unhooking the battery MAY reset it. To reset the change oil light, turn the key on and floor the gas pedal 3 times, that should reset the light.
Nov 11, 2009 | 2005 Buick Century
How do i reset my oil light? my husband changed
TURN THE IGNITION KEY TO RUN WITH THE ENGINE OFF.FULLY PRESS AND RELEASE THE ACCELERATOR PEDAL THREE TIMES WITH IN FIVE SECONDS.YOU HAVE TO DO THIS MORE THAN ONE TIME.ITS NOT GOING TO RESET FIRST TRY BUT DO THIS PROCEDURE.UNTIL THE CHANGE ENGINE OIL LIGHT WILL FLASH WHILE THE SYSTEM IS RESETTING.TURN THE KEY TO OFF.WAIT A FEW SECONDS.START CAR UP TO SEE IF CHANGE OIL LIGHT COME BACK ON.IF YES YOU HAVE TO TRY THE RESET PROCEDURE AGAIN.
Sep 26, 2009 | 2006 Chevrolet Equinox
How do I reset the change oil soon light?
Hi to reset the oil life monitor
turn the key on engine off
push the gas pedal to the floor 3 TIMES WITH IN 5 SECONDS
the light will flash then go out
May 12, 2009 | 2005 Chevrolet Equinox
SERVICE DUE SOON LIGHT
Press odometer reset/adjustment shaft in, hold in and turn key to run position. Keep holding in the reset shaft in for about 30 seconds. release shaft. turn key off. restart car. Service Light should go off in about 5 seconds.
Mar 25, 2009 | 2008 Acura Tl
Change oil light reset?
Hi Shady, here is the procedure for resetting the light.
Resetting Procedure
Follow this procedure to reset the GM Oil Life System™
  1. Turn the ignition to RUN, with the engine off.
  2. Fully press and release the accelerator pedal three times within five seconds.
  3. If the CHANGE OIL SOON light flashes, the system is resetting.
  4. Turn the key to OFF after the light has finished flashing, then start the vehicle.
  5. If the CHANGE OIL SOON light comes back on, the engine oil life system did not reset. Repeat the procedure.
With Trip Computer
  1. Press the MODE button until the light appears next to OIL LIFE.
  2. Press and hold the RESET button for three seconds. The oil life percentage should change to 100 percent.
Nov 02, 2008 | 2002 Pontiac Grand Prix
ETC SmartFade 1248 48 Channel Control Console Logo
Top ETC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an ETC Audio Player and Recorder Expert? Answer questions, earn points and help others
