Question about GE G.e Refrigerator Wr55x10942 Motherboard Main Board
Hotpoint wr55x10942 - GE G.e Refrigerator Wr55x10942 Motherboard Main Board
GE model Pfs22miwww. Condenser fan and compressor not running. Tested start cal it is ok. Changed ontology board. Condenser fan now running. Still no compressor
Have you changed out the WR55X10942 Motherboard? Here is a link to test points on the motherboard HERE and here is a service manual HERE I don't mind helping answer your questions so feel free to contact me, Thanks Sea Breeze
WR55X10942 Main Control Board
Mar 22, 2013 | GE G.e Refrigerator Wr55x10942 Motherboard...
Fan motor will not engage
everything runs through the computer board part number WR55X10942,unplug it,remove the cover off of the computer board located on the back outside wall of the machine,look at the relays,if any are missing i think there's 7 of them then you don't have the updated board and most likely this is your problem,next time send some info on what the machine is doing or problems you're having but like i say everything on these machines runs through the board
Nov 02, 2011 | Hotpoint HSS25GFP Side by Side...
DOES THE HSS25IFMWW AND THE HSS25IFMCC HAVE THE SAME PARTS I NEED A NEW CONTROL BOARD
Yes they both use the same board when searching both model numbers parts breakdown for both i came up with the part# WR55X10942
GENE
Aug 29, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Top half of freezer is not working, ice has melted and all food item's have thawed. the lowr half of the freezer seem's to be working and item's are frozen, this is a Hoptpoint side by side maybe 3 to 4...
Your freezer fan has stopped working . Usually , this is a main control board gone bad . This board controls the fan in the freezer and is located behind the refrig , behind an 8 X 10 " panel . Pt.# WR55X10942 .
Jun 13, 2010 | Hotpoint HSM25GFRSA
My is SxS fridge is warm on top & freezing on bottom- both sides
there is a computer board part number WR55X10942 ,if you're in front of the fridge it's on the left hand side down near the bottom,
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
When enziering door dispener on ice on augur fan and motor stot running and light din.
Another GE common issue, I have had it both ways. I would suspect the motherboard first, then the dispenser board. The issue can be either or both. Both are fairly easy to install. But most parts sellers will not warranty electrical parts or when teh average Joe install them. Motherboard WR55X10942 est $165 - 200... dispenser board WR55X10195 est $85 -120
Ric
Mar 09, 2010 | Hotpoint HSS25GFP Side by Side...
HOTPOINT/GE hss25GFPHWW first the water stopped running, then no ice, now it is not running at all. Water to the filter, lights on
If your refrigerator is not working at all then this is a common problem related to the mother control board located on the rear of your refrigerator. Many times you can unplug the refrigerator and remove the control board and examine both sides for burn marks or signs of heat damage. The part number for *********** board is WR55X10942 Surge suppressors are helpful because electrical surge is one of the causes for failure. Have a look with power unplugged and let me know what you find. Thanks, Sea Breeze
Sep 26, 2009 | GE Refrigerators
GE G.e Refrigerator Wr55x10942 Motherboard Main Board Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
