Question about Dishwashers
I have frigidaire m#fphd2491kfo it will not start when you hit start bitton
    New Friend:
I have a Maytag dishwasher
Posted on Oct 21, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Brand new first time using it Frigidaire
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Nov 24, 2010
Dishes not getting clean
Hey Julia! I understand that your dishes are not coming out clean. There can be several things that you might want to try. First, make sure that your detergent is fresh. If not, try using a fresh detergent. Next thing I would try would be to make sure that everything is loaded correctly so nothing is blocking the spray arms inside, and preventing them from rotating. After that you can check to make sure that the water coming into the Dishwasher is hot enough. Try running the water into the sink until it becomes hot and then starting the dishwasher. If you're still having trouble after that, you might want to check and see if you have hard water. If you do, you'll want to make sure that you are filling the dispenser cup completely and if you have soft water you'll want to make sure that you use less detergent. The only other thing that I can think of that might cause the dishes to not be clean would be maybe the water pressure itself. If the pressure is good, you might need to reach out to a local service tech who can better pinpoint the problem for you. Best of luck!
Dec 14, 2013 | Frigidaire Dishwashers
Frigidair dishwasher model fphd2491kfo wont drain does every thing else
Good Afternoon Tyler, thank you for your question! Often when a dishwasher does not drain, it is because the drain hose may be clogged or you have a faulty drain pump. First, I recommend cleaning the glass trap that is located in the center of the unit designed to collect pieces of broken straws, bones, glass, etc. The filter can be removed for cleaning by simply grasping the handle and then lifting it out. However, if you continue to have water left in the sump and the dishwasher is making a grinding noise, then there is a possibility that the drain motor may need replacing after a proper diagnosis from an expert. You can locate a certified technician directly through the manufacturer website or in your local directory.
Aug 28, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Dishwasher leaking from pump housing.
If it is not leaking around a shaft seal, you can disassemble it again and use permatex or silicon sealer on the mating surfaces
May 03, 2013 | Frigidaire Professional Series 24 in....
Frigidaire Dishwasher not working
try pressing button instead of hitting it, then check water inlet, check the filter at the inlet pipe if clear
Mar 18, 2013 | Dishwashers
Frigidaire dishwasher model # fphd2491kfo has standing water in bottom after the wash cycle is complete
it could be a clogged pump its self,maybe a peice of food or a skin off some thing is hanging up at the last cycle
Apr 22, 2017 | Frigidaire Dishwashers
Hi Bill Walters - Generally speaking, the drain pump receives power directly from the main control board. If you have verified that the drain pump does not work then more than likely it is not getting power or the drain hose is restricted. If the drain hose is attached to an in-sink garbage disposer, please verify that the plug in disposer has been removed. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Jan 21, 2013 | Frigidaire Dishwashers
Brand new first time using it Frigidaire dishwasher not draining has water in the bottom. Model # FPHD2491KFO
heatman101
Nov 23, 2010 | Frigidaire Professional Series 24 in....
Ps3 can't pick up second guitar do i need twowith
connect both transmitters .turn on both guitars hit the button on transmitter then hit PS bitton on each guitar
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
Where is the Program button on the DKT3220-SD ?
press intercom #9876 HOLD, flexible buttoon pressed to assign, press the bitton code, press again the bitton to set DND = 180 short key for extn 610+extn number to change display name must set at administrator phone usually is receptionist phhone
Mar 17, 2009 | Toshiba DKT3020SD Corded Phone
Will not function in the Picture Taking Mode
It appears that the rechargeable batteries were low and probabaly need to be replaced.
Thanks for this site.
Aug 27, 2008 | Sony Cyber-Shot DSC-P71 Digital Camera
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
