Question about Pride Revo 4 Wheel Scooter
The rear axle on my fortress 2000 scooter moves about 1/4 inch to the left or right causing the left and right wheels to rub on a bolt on the inside of the tires. Is there a way to tighten the axle to solve this problem? Thinking maybe a bushing has wore out.
There is a bearing inside pin roller this get no grease unless pulled apart and serviced so if this has not been done the bearing is most likely worn out take apart and find bearing number very small ### so wash in solvent to see it go to auto parts store and order new 1
Posted on Oct 21, 2013
  • Gord Wallen
    Gord Wallen Oct 23, 2013
    Thanks. Took a closer look at axle and inspected bearings. Determined the collar holding bearing was loose. Tightened both and everything is fine now.
  • 118 Answers
SOURCE: Right rear wheel
You may need to be sure all the bolts are tight on the wheel, and that there is nothing stuck in the tread. is it a metallic or rubbery tick?
Posted on Nov 27, 2008
  • 29 Answers
SOURCE: Celebrity Pride SC440 scooter makes continuous clicking sound
the motor break assembly is going bad, if not replaced soon it will quickly draw down your batteries. smithrm70@hotmail.com
Posted on Sep 19, 2009
mcdevito75
  • 1970 Answers
SOURCE: What is the torque value for the axle nut on the
mcdevito75 here, I would figure 20 lbs.
Posted on Jul 02, 2010
guyster7148
  • 192 Answers
SOURCE: I had a clicking noise in my back wheels. Removed
There is a linkage spring that you might have undone when you removed the wheels. hate to tell you, but you need to remove them again and check to make sure the spring is on..... Guy
Posted on Sep 12, 2010
wcdoc1953
  • 280 Answers
SOURCE: my dad has a pride celebrity xl scooter and keeps
The noise you are describing usually comes from the trans-axle and not from the motor/brake. Motor brake noise is usually continuous. Sounds like the trans-axle may be slightly bent on the right or rubbing internally. The easiest way to identify this is to block up the scooter and remove the rear cover. Look and listen to all the drivetrain components while the scooter is blocked up and running. If you hear rubbing at the end shaft as you describe you can try the following:
Loosen the trans-axle metal mounts that clamp the rubber sleeves over the trans-axle
Spray the rubber sleeves with silicone.
Re-torque the clamps after checking the alignment.
An overtightened or misaligned clamp can sometimes cause noise.
The brake/motor/transaxle has a prorated three year warranty so you should go through a Pride dealer for warranty repairs.
Sometimes you can get a noisy wheel on the key and key-way of the trans-axle shaft. It may be worthwhile to pull both rear wheels lubricate the shaft key-ways and keys and re-install the wheels. This can sometimes quiet a multitude of noises from the trans-axle. Depending on the age of the scooter you can do nothing, replace the brake/motor/transaxle parts individually, replace the complete assembly. I like to replace the entire assembly under warranty so there are no future problems. The rest of the repair depends on your insurance coverage or budget. Hope this helps.
Posted on Dec 01, 2010
Pursuit XL scooter, rubbing sound during right turns...
My first guess is that you have either loose lug nuts(5)on one or more of the wheels, or you have loose screws(6)that hold the wheel rims together as these have split rims. This is more common on scooters with flat-free tires as the tire and the foam insert will chafe against each other and produce a rhythmic sound as the wheel rotates. Try tightening all of the lug nuts first and see if that helps. If it persists, try removing the tire by removing the 5 lug nuts and pulling it off the axle. You'll see six bolts that hold the rim halves together. Re-tighten all of these and install the wheel to see if that cleared the noise. Note: The real wheels have a key-slot in the axle and a key which slides into this slot to hold the tire to the axle. Be careful not to lose the key when you slide the wheel off, and be sure to get the key back in the slot when you install it back on the hub. Here is the page for your scooter. Click on the owners manual and scroll down to page 37 for info on tire removal.
Jan 10, 2013 | Pride Mobility Pride Pursuit XL 4 Wheel...
Replace rear wheel bearing 773 bobcat
you must unbolt it from inside chainbox. Raise cab, and remove about 8 bolts that hold a plate that is back toward the engine, in line with back axle. Inside you will see 2 large chains and sprockets, and a bolt that holds the sprocket to axle. Use a 1-1/8" wrench to remove bolt, then axle may be removed. Replacing outer bearing and seal is now possible
Sep 23, 2012 | Bobcat 773
My dad has a pride celebrity xl scooter and keeps getting a noise similar to a rubbing noise from rear right wheel while driving, it sounds once for every rotation of the wheel, iv checked that nothing is...
Nov 30, 2010 | Pride Celebrity Xl 4 Wheel Scooter
I have the exact same problem. This is a Fortress Scientific 2001LX C series. Not sure what exactly the free wheel lever is, but I'll assume that it's the lever that touches the tire? You can't budge this...
MaryJain The scooters freewheel lever should be at the right rear of the scooter under the shroud and no it shouldn'd be touching the tire. To put it freewheel you should push the lever down. Now if the lever is rubbing the tire you can try to get someone to push it sideways toward the left tire to get it away from the right tire. It should move easily into and out of gear. Be careful not to break it or the small micro switch on the brake. Hope this helps you
Oct 27, 2010 | Electric Mobility Mobility Electric Power...
I have a pride celebrity dx sport that the battery is charged but wheels are locked on even in neutral. wont go forward or reverse...please help!
I suspect that the electromagnetic brake has seized. I have come across this a few times on some of the larger pride scooters, usually if they have got wet and been left for a while. They can normally be free'd off. First, loosen the left hand rear wheel nut (the one in the middle of the wheel). Put the scooter into freewheel and jack the rear wheels off the ground. Remove the left hand rear wheel and be carefull not to lose the hub key which locates between the axle and hub of the wheel. Unplug the wire that comes out of the brake, then remove the brake from the end of the motor. Before going any further, check to see if you can move the disk inside the brake (the disk is the black part that you can see on the inner side of the brake with the hexagon cut out). If you can move this disk at all, the brake is NOT seized. While at this stage, plug the brake connector wire back in , turn on the scooter and press the throttle lever. If the motor spins, you can discard the motor as being of any promblem. If the brake IS seized, it will need to be dis-assembled. Dis-assembling the brake usually requires the removal of 3 or 4 small allen headed bolts on the rear of the brake, followed by some spacers, small washers and a small ball bearing or two. Watch what comes off and in what order, and be carefull not to lose any parts. Free off the black fibre type disc from the metal plate that it is stuck too. This can be done using a small hammer and large flat bladed screwdriver taking care not to damage the disc. Lightly rub the metal plate with fine grade wet and dry to remove any rust or dirty deposits, then re-assemble the brake in the reverse order, and refit the rear wheel making sure you apply a small amount of grease to the axle shaft.
This should work for you but failing that, I think you will need a new brake assembly.
Hope I have been of some help to you.
Aug 09, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
My scooter is making loud clicking sounds as though something has come loose & hitting something in the rear wheels as it goes around. The repair tech rotated the rear tires last week & this helped...
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
Jun 29, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Jun 24, 2010 | Pride New Mobility Legend 4 Wheel Scooter
How do I tighten the chain on a 1979 Honda CB 400 Hawk?
loosen rear axle bolt and nut, tighten chain tensioner at rear axle,use the nut on the tension bolt to lock it down to the same calibrated distance(about 3/4 inch chain slack movement up and down not a total of 1 1/2) when the axle alignment is the same on left and right tighten the axle nut and bolt,lube the chain. Make sure you adjust the rear brake tension to make up for the wheel being moved toward the rear.
Apr 25, 2010 | 1977 Honda Cb 400 F
Rear wheel assembly for flstc 1994 rear wheel is not centring,too far over to the left, drive belt is rubbing on wheel
Unless someone has changed a spacer or something , the rear wheel should be centered with the frame, not necessarily the swingarm. The rear brake caliper bracket acts as the spacer on the right side and there is a spacer on the left side. This spacer on the left side should be just short enough to get into the swingarm without a lot of excess space once installed. You should not be squeezing your swingarm more than 0.125 inch or so.
Now, there are other things that will cause the tire to rub the final drive belt. Too wide tire will do this. The '94 models used the old style wide belts unlike the narrower belt used by the later models. If you install a like is on a later model, it's too wide and will probably rub. The next reason for tire belt interference is the rear tire not being adjusted correctly and it is not under the bike straight. Adjust the rear wheel by measuring the length of the adjuster bolt relative to the axle. These measurements should be the same on both sides of the swingarm. If you can't do that, find something about six feet long that you can use as a straight edge to check the alignment of the rear wheel to the front wheel. Keep in mind that there is an offset designed into the front wheel. Just make sure that the rear wheel is as straight relative to the frame as you can get it.
Even with all this stuff correctly set, the final drive belt will be close to the side of the tire but it should not rub.
Feb 28, 2010 | 2000 Harley Davidson FLSTC Heritage...
93 FXR Rear tire rubs belt guard w/axle centered.
Try just bending the belt guard or removing it and fileing some material off the guard so it does not rub. You may also be able to remedy this by adding washers to the belt guard attach points.
May 30, 2009 | 1993 Harley Davidson FXR Super Glide
Pride Revo 4 Wheel Scooter Logo
88 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
