Question about Dishwashers
Samsung dishwasher dmt400rhs
Won't start--no lights--checked breaker,child lock,water line,plug--all ok but no lights and will not come on--is there a fuse and if so where is it--thanks
  • david johnson
    david johnson Oct 21, 2013
    could not get fixed without a service repair call at the cost of $95.00 plus labor and parts--sooo--decided to trash and buy a new dishwasher---not a Samsung--thanks anyway.
    New Friend:
NO FUSE PROBLEM
Posted on Oct 21, 2013
3 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: How do you get the child lock off?
Please find complete process to switch off the child lock.
http://www.ehow.com/how_5144877_turn-kitchenaid-dishwasher-child-lock.html
Most of the dishwashers are same so the model should not be a problem
Thanks
Posted on May 17, 2010
rylee_smith
  • 8619 Answers
SOURCE: The KitchenAid dishwasher "child lock " is on and we can not star
Hi
Thanks for using FixYa. To turn off the child lock press and hold the Energy saver Dry for 10-15 seconds. If this does not help the unfortunately you’ll have to replace the control panel.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
I can use my Samsung dishwasher because the door is in te lock position and wont close , howdo i unlock the door do close it?
If possible, unplug the unit and wait 10-15 minutes. Alternatively, the D/W may be on a separate circuit breaker so just identify the circuit breaker and turn it off for the same period of time.
Dec 26, 2014 | Samsung DMT400RHS Builtin Dishwasher
Samsung dmt400rhs blinking HEAVY light
I believe that error code indicates that you've got a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but then you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Jul 09, 2014 | Samsung DMT400RHS Builtin Dishwasher
Samsung DMT400RHS Leakage error
check you house circuit breakers if you have no lights and the DW is plugged in next check to see that the door switch still locks the DW shut otherwise;call a serviceman
Nov 18, 2013 | Samsung DMR78AHS Builtin Dishwasher
Low water level
I have a Samsung DMT400RHS and I started getting the low water level error ('Normal'+Heavy'+Smart Auto' LED blinking). The error started intermittently a few weeks ago, but the the last day or two the problem was solid, and simply restarting the cycle no longer worked.
I looked of the code in the dishwasher user guide and it said 'low water level.' Searched the internet and located the repair manual at tradebit.com for $15. The manual was well worth the $15.
The manual suggested: 1) loose level sensor connector 2) Faulty Assy case sensor or stuck floater aka 'remove foreign matter' 3) Bad Main PBA assy.
Since we do 10+ loads a week for the last 18 months the stuck floater seemed to be the most likely cause.
Go to Samsung DMT400RHS Low Water Level Error ('Normal'+Heavy'+Smart Auto' LED) (new link is https://photos.google.com/album/AF1QipNtp1neOR7icVG8cSs71bLpxQD5k_xljiWcJD2P click the i on each picture to see the caption - DM 04/17/2016) to see the pictures and read the captions documenting what I did. Do this at your own risk. You must turn off and disconnect the electric power and turn off the water supply before you begin.
Jul 24, 2013 | Samsung DMT400RHS Builtin Dishwasher
Samsung dmt400rhs low water level alarm
It sits at the bottom of the lowest plastic tub. assuming you have no more active leak, you may have to tilt is on it's side to drain the last bit of water.
Dec 27, 2012 | Samsung DMT400RHS Builtin Dishwasher
Low-level water level error DMT400RHS
We took off the left side bottom and the float was stuck on ours. We bumped on it on the very bottom plastic while it was feeling up with water and the float flew up and now its working. We gonna let it run its course then clean it out where float is to make sure it doesnt have any more residue or gunk in it.
Sep 26, 2012 | Samsung DMT400RHS Builtin Dishwasher
How do I reset DMt400RHS dishwasher?
read you instruction manual, section troubleshooting, go to the menu, and proceed. If you do not have instr.manual download from www. retrevo.com or www.fitness.manualsonline.com
However you can reset from the main power, reset the c.breaker that control the dishwasher machine.
God bless you
May 25, 2012 | Samsung DMT400RHS Builtin Dishwasher
Dishwashers Logo
198 people viewed this question
Top Dishwashers Experts
