Question about Orbit Baby Orbit G2 Stroller with Stroller Seat Red
I have the orbit g2 travel system. Today I noticed it is very hard to get the car seat off the stroller base. It goes on the car seat base with no problem. This has just started I am squeezing both handles on both sides. Help please!
ANy adjustments to be made to make a 4 month baby sit in Graco trilogic car seat ?
The Graco Quattro Tour travel system is one of the most popular styles, thanks to the big basket, one-hand fold and nice parent tray. There are some downsides to this travel system, though. Most notably, the Quattro Tour stroller is big, whether folded or unfolded, and it's heavy to boot. Whether you choose the regular version or the Graco Quattro Tour Deluxe travel system, the included infant car seat will be a winner. Paying extra for the Deluxe buys you a higher weight range on the car seat, which means a longer useful time, but again, adds weight to the whole system.
Graco Quattro Tour Travel System FeaturesThe foundation of the Graco Quattro Tour travel system is the Quattro Tour stroller, a full-size model with an aluminum frame. It also has one-hand folding, a multi-position reclining seat (including fully reclined for infants), a drop-down basket that can be accessed even while the seat is reclined, and a sunshade that rotates to cover nearly any angle you need. The parent tray has two cupholders. The front tray also has a cupholder for baby, and it swings open for easier access with bigger toddlers. The regular version of the Graco Quattro Tour travel system comes with a Graco SnugRide infant car seat, which holds babies up to 22 lbs. and less than 29 inches. The Quattro Tour Deluxe travel system comes with a SnugRide 32, which holds babies up to 32 lbs. and 32 inches. The difference in car seats is the only real difference between the regular and deluxe versions of this travel system.
What I Like About the Graco Quattro Tour Travel SystemOf the infant car seats that come with travel systems today, both the Graco SnugRide and the SnugRide 32 are good choices. These car seats are fairly easy to use, and they install pretty easily in most vehicles. Some of Graco's less expensive travel systems include a SnugRide with a back-adjust harness, but the car seats included with the Quattro Tour travel systems are a front-adjust version, which is much easier to use properly. You can use both SnugRide seats without their bases, as well, which is a plus. The Quattro Tour stroller feels sturdy out of the box and has a respectable 50 lb. weight limit. The steering is OK for a stroller of its size and price - better than average for full-size travel system strollers.
The one-hand fold on the Quattro Tour stroller works well. You just have to twist the middle of the handle and let gravity help the stroller fold itself. Since you have to deliberately twist the handle, though, there's not much chance of the stroller collapsing accidentally as there would be if you just needed to push a button or lever.
The basket on the Quattro Tour stroller is big enough to fit a large purse or diaper bag. It also has a nifty drop-down feature so you can get into the basket even if the stroller seat is fully reclined (a common problem on full-size strollers).
The canopy is good-sized and rotates around to cover almost any position needed. It's easy to put the seat into the fully upright position, and I like that it reclines all the way, in case you don't want to use the infant car seat in the stroller all the time.
What I Don't Like About The Graco Quattro Tour Travel SystemThe Quattro Tour stroller is heavy. At more than 26 lbs., you may get pretty tired, literally, of lifting this stroller in and out of your trunk after a few weeks. It's not small in terms of dimensions, either. When the stroller is open, it's just over 24 inches wide, which doesn't leave a lot of clearance for narrower doorways. Some parents complain that the wheels, which stick out a bit from the frame, are easily caught on things in stores or in other tight spaces. When the Quattro Tour stroller is folded, it's smaller, but not by a lot. It measures nearly a foot and a half thick and about two feet by three feet, which means it will pretty well fill the trunk of the smallest cars. Though the steering is better than most full-size, lower-priced travel system strollers, it's still not great. Once you've added a heavy toddler (or a bigger infant plus the infant car seat and a diaper bag), the steering can be a bit balky.
While the folding mechanism is sleek, unfolding the stroller is awkward. Similarly, while the seat is easy to move up, it's harder to recline.
The biggest problem with the Graco Quattro Tour stroller is durability. While this model seems to have a better track record than many of Graco's travel system strollers, there are still plenty of parents who complain that their Quattro Tour stroller is creaking and wobbly after a year or so of constant use. This is probably not a stroller that will last through multiple children, and you likely will not recoup much money by reselling it later on.
Should You Buy A Graco Quattro Tour Travel System?The Graco Quattro Tour travel system is not a bad choice if you're set on a travel system already. Many of its downsides won't be answered by choosing another brand or even another of Graco's travel systems. If you have realistic expectations about a travel system in general, you may be very happy with the Graco Quattro Tour. The infant car seat is the most important part of the travel system, and you can't go wrong with the front-adjust SnugRide or the SnugRide 32. You should try out the car seat in your vehicle before you buy the travel system, if at all possible, just to be sure it's a good fit. If the car seat doesn't fit your vehicle, that would be one reason to choose a different travel system.
In the whole of the stroller world, the Quattro Tour stroller wouldn't be one of my first choices since it's heavy, bulky whether folded or unfolded, and doesn't have a great track record for durability. However, as far as travel system strollers go, those things are to be expected. The Quattro Tour stroller is above average on a few convenience features, though, so combined with the decent car seat, it's among the better ready-made travel systems available.
Jul 26, 2012 | Graco Baby Gear
I lost the keyfit 30 stroller manual where can i get one... or any website please
hope this help you:
  • Chicco USA - 30lb Cortina Travel System - Adventure Cortina ® KeyFit ® 30 Travel System Travel in style with your baby. Designed especially for the Chicco KeyFit 30 Infant Car Seat, the Cortina Stroller works as a travel ...
    www.chiccousa.com/gear/travel-systems/cortina-30lb-systems/travel-systems-30-adventure... · Cached page
  • Amazon.com: Chicco Cortina KeyFit 30 Travel System in Adventure: Baby Memory Recline seat remembers the last position seat was in when the stroller was folded. Has convenient one-hand fold. 3-position leg rest and flat recline for ...
    www.amazon.com/Chicco-Cortina-KeyFit-Travel-Adventure/dp/B000MAERLG · Cached page
  • Chicco Cortina KeyFit 30 Travel System - babyearth.com The new KeyFit Infant Seat is also available in a Travel System! With its unique Memory Recline seat and fresh, new patterns, you will be traveling in style!
    www.babyearth.com/chicco-cortina-keyfit-30-travel-system.html · Cached page
  • Cortina KeyFit 30 Travel System - Chicco USA - Strollers, car ... Cortina KeyFit 30 Travel System Travel in style with your baby. Designed especially for the Chicco KeyFit 30 Infant Car Seat, the Cortina Stroller works as a travel system ...
    www.chiccousa.com/gear/travel-systems/cortina-30lb-systems/travel-systems-30-midori.aspx · Cached page
  • Sep 19, 2011 | Chicco Cortina KeyFit 30 Travel System...
    Adjust car seat inclination on Aura travel system
    try installing the aura car seat a next way r a way u hav never tried and bring it back words in the car so the baby would ly back as it shud b
    May 14, 2010 | Evenflo Aura Traditions Travel System...
    I just purchased a graco literider 320 stroller
    Yes, you can get a matching car seat with base. try your local baby store, or look online for the travel system..once you find the travel system, you'll find the car seat.
    Aug 04, 2009 | Graco LiteRider 320 Travel System 7303BRL...
    Installation of base into car
    Place the base into the car ,pull seatbelt through the large holes on the base, lock seatbelt and place the infant carseat in you should hear the seat click into the lock position. Hope this helps.
    Jul 08, 2009 | Evenflo Journey Elite - Pink Lemonade...
    Model Number on my Evenflo On My Way Travel System - Need Cover
    My used Evenflo On My Way travel system model number for the stroller is 4951F7. The model number on the car seat is 4951F7P2.
    Question for you - Is there a front tray to snap on when not using the car seat? Mine is missing that part. Thanks.
    Feb 23, 2009 | Evenflo Aura Traditions Travel System...
    Help me with my car seat
    You can check around for bases that fit the car seat at garage sales!!! Otherwise click the link- and you can order replacement parts for evenflo products directly from their web-site
    https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=5881485a&txSearchDOM=2/4/2004
    Feb 07, 2008 | Evenflo Aura Elite Travel System Wedgewood...
    EXTRA BASE
    babies r us has the bases they are genric and work for a cuople different travel systems the sales person was super helpful and we love having the second base so there is no installing of the seat from my car to my husbands it just clips right in.
    Jan 10, 2008 | Eddie Bauer Lightweight Travel System...
    Installation of Car Seat base
    Try this link it seems very good http://www.aap.org/family/carseatguide.htm
    May 13, 2007 | Cosco Travel Systems 01-938 Stroller
    Orbit Baby Orbit G2 Stroller with Stroller Seat  Red Logo
    32 people viewed this question
    Top Orbit Baby Baby Gear Experts
    Dorel UK
    Dorel UK
    Are you an Orbit Baby Baby Gear Expert? Answer questions, earn points and help others
