Question about Home
Harley davidson pot holder & met - Home
jimmy nutron
  • 132 Answers
SOURCE: what type of motor oil used in 1994 harley davidson 883
harley recomends that you use their oil but i would be carefull because it is a cynthetic now if you were using regular oil what that will do is clean all the old build up out of the motor this can be bad because after time there are pin hole leaks that occure but the build up stops it from leaking but if you use cynthetic you cant go back to regular oil it will gum up on you and ruen your motor so you got to find out what has been put in it. but use a 10-30
Posted on Jun 05, 2009
tundrajet
  • 80 Answers
SOURCE: removing harley davidson ultra classic gas tank
Drain the fuel either by siphening or removing the cross over tube at the front of the tank and letting it drain that way or just block off those cross over lines and leave the fule in the tank for removal.
0) remove seat
1) drain fuel
2) undo cross over line (bottom front of gas tank.
3) shut off pet **** and remove fuel line from pet ****.
4)there should only be 2 bolts holding the tank on, one at the top front of the tank and one at the back of the tank.
All in all a pretty easy (but possibloy messy) job.
Posted on Jun 06, 2009
  • 69 Answers
SOURCE: 2002 harley davidson ultra classic setting the clock
Turn the Bike on and the Radio off and then follow the buttons on the screen. Most people think you have to do it while it is running and this does not work
Posted on Jun 28, 2009
wd4ity
  • 4565 Answers
SOURCE: assy of starter clutch on 2003 Harley Davidson
The starter on a late model Harley is a typical Nippondenso gear reduction type starter. They are all basically the same except for size.
To replace the starter clutch inside the starter assembly requires disassembly of the starter assembly.
I you will contact me directly, I will scan the procedure and drawings out of a service manual for you.
wd4ity@bellsouth.net
Posted on Sep 24, 2009
wd4ity
  • 4565 Answers
SOURCE: Tire Pressure - Harley Davidson Heritage Softtail
30 psi front
36 psi rear (single rider)
40 psi rear (dual riders)
Posted on Apr 03, 2010
Have lost back taillight after installing new rego plate holder,bulbs good,fuses good
Hi, Luke I can absolutely help you but I need more information about the Rego product contact me at the email address below for more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Harley Davidson Manuals Mark Workshop
http://partsfinder.onlinemicrofiche.com/stcharlesharleydavidson/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Oct 05, 2016 | 2007 Harley Davidson FXSTC Softail Custom
My accessory fuse blows on my 2005 harley davidson electra glide?
Hi, Richard you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
May 12, 2016 | 2005 Harley Davidson FLHTCUI Electra Glide...
2007. Why does engine keep dying?
Hi, Chris you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below, and for specific information or questions, please feel free to contact me at xlch@mail.com Good luck and have a nice day.
How to get to the fuse panel on Harley Davidson Electra Glide Motorcycle
Apr 11, 2016 | Harley Davidson FLHTCUI Electra Glide...
ABS fuse continues to blow, and now stereo will not put out sound
Hi, Ignacio you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below, and for specific information or questions, please feel free to contact me at xlch@mail.com Good luck and have a nice day.
Harley Davidson Maintenance Tips Checking the Fuses
Instant Tech Relief A must have!!! $6 a month cheap
Apr 03, 2016 | 2009 Harley Davidson FLHX Street Glide
Blowing 5 amp fuse from ignition
Hi, Kevin you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and free downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com or join 6ya for direct contact. Good luck and have a nice day. Exposing the Wiring and the Battery on 2011 Harley Davidson Road Glide...
Jan 25, 2016 | 2015 Harley Davidson Electra Glide Ultra...
Speedometer not working and fuel gauge not working
Hi Victor, first thing you want to check is your instrument fuse located in the fuse holder right behind the battery. Remove the seat and slide up and off the black plastic cover to access your fuses. For more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Aug 27, 2015 | 2004 Harley Davidson Softail Deuce
NNeed torque specs for 2010 harley ultara classic, front axle nut, front brake calipers, axle nut holder
Front Axle = 60 to 65 foot pounds
Front caliper banjo bolts = 17 to 19 foot pounds
Front Brake disk screws = 16 to 29 foot pounds
Front caliper mounting bolts = 28 to 38 foot pounds
Front axle holder nuts = 132 to 180 inch pounds
Aug 23, 2014 | 2010 Harley Davidson FLHTCUTG Tri Glide...
What is the plug for below the maxi fuse on an 08 harley 1200n?
If you mean a grey connector with a rubber cap on the end of it, it's a diagnostic port for the dealership to plug into.
Apr 20, 2013 | 2008 Harley Davidson XL1200N Sportster...
Home Logo
466 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
