Question about Frigidaire Kitchen Ranges
My Frigidaire range model FEF326FBE sparked from the top behind the control knobs, it tripped the breakers, now will not come on at all, even the clock light is out.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
See other posting.
Posted on Oct 21, 2013
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
aborcass
  • 2651 Answers
SOURCE: Replacement knob
imsert your model number here, you can download a complete parts manual
http://www.frigidaire.com/support/manuals.asp
Posted on Jan 15, 2009
dmftrucker
  • 1922 Answers
SOURCE: Maytag Performa Electric Range (PER1510) tripped circuit breaker.
first, un-plug unit and remove rear access cover,it could be a wire with bad insulation that has shorted to the body of the unit,could be an oven/broiler element,could be one of your feed lines to the unit shorted to ground,does it trip brkr w/o anything turned on???you can also isolate the problem that way.good luck
Posted on Aug 23, 2009
  • 497 Answers
SOURCE: I turn the knob on the front right burner and
its a valve issue, most likely needs repair.
Posted on Sep 02, 2009
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,
unsafe to use at any time if the temp controller trips the circuit breaker
could be the oven thermostat causing the trip as well
if Frigidaire are still in business
You will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
Oct 11, 2016 | Frigidaire Ovens
My frigidaire range/oven model FEF365BWC is not working the surface and the oven are both not heating up. Everything other than that are working the oven light and the clock are working fine
You are not getting 240 volts to the heating elements. Go outside to the circuit breaker panel and find the circuit breaker for the range. It will be two breakers with their reset handles linked together so if one breaker trips so will the other. That's the part that isn't working correctly. Only one is tripped allowing the controls and lights to operate . Try manually resetting it. It most likely won't work, so you'll have to replace the circuit breaker.
Jan 22, 2016 | Frigidaire Kitchen Ranges
Why doesn't my stove top and oven heat up
Check your circuit breakers in the power panel for a bad breaker. The breaker has a pin connecting both handles One breaker can trip without tripping the other. This condition will only allow 115 volts to operate the controls and light bulbs but will not power the heating elements.
Jul 14, 2014 | Frigidaire FEF336BC Electric Kitchen Range
My Frigidaire electric stove model FEF326FBE sparked in the back top right behind the control knobs. It tripped the breaker. Now it wont come on at all, not even the clock light
The "control board" shorted out and will need to be replaced. Here is the part to order. Also, on that same parts page you will find a video to show you how to make the repair.
Oct 21, 2013 | Kitchen Ranges
Frigidaire dryer crown series model #FDEB23SRGS1 will not start
Check the breakers first . Reset both poles even though they may not show tripped. The wiring t the receptacle or plug could be loose. Los check behind it behind the back panel.
Feb 03, 2013 | Frigidaire Dryers
I've used you guys once before - right the first time so trying again for a different problem. I've got a Frigidaire glass-top electric range (model PLEF398CCD) and 2 of the four burners stay on...
Thanks for using Fixya once again we appriciate it!
The problem with your stove is going to be with the infinate switch(what ya are calling knob) for the burners that giving ya trouble are shorted and the contacts inside of it are welded so they permanantly are stuck on the HIGH setting. To repair that the switches for the affected burners would need to be replaced.
The part number for those switches is 316095503 they could be purchased at your local appliance partstore or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Oct 02, 2011 | Kitchen Ranges
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Kitchen Ranges Logo
47 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
