Optical mouse repair
I bought a GE wired optical scroll mouse and plugged it into the usb port. it said the drivers were installed but it still isn't working at all, even the laser on the bottom is on so i know it has power. what do?
  • Computers & ... Master
  • 16,450 Answers
What is the operating system?
Posted on Oct 21, 2013
yooperbud
  • 8637 Answers
SOURCE: MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 28, 2009
SOURCE: G9 Laser Mouse Scrolling Problem
thx for helping dude, logitechexpert my ***... now check that...i was so pissed because of such stupid advice that i hit my mouse on the corner of my desk...yep i really did.  ...and then it worked! it SCROLLS!
my theory: the logitech has a quite complicated mechanical clockwork-like gear switch for their scrollwheel. they are so proud of it, that they even have pictures of it on the box when you buy a g9. well, i guess when you make things more complicated they arent that reliable anymore...like the gear switch at your bycicle which gets messed up sometimes, because its small mechanical parts just get stucked.  so my mechanical solution: turn your g9 around hold it and knock three times(not too soft: imagine the money you paid for this mouse and release your anger) just around the area where the mechanism is located...i had exactly the same problems like you and now it works perfectly! ...i guess i dont need to buy batteries.
Posted on May 29, 2009
romsky79
  • 822 Answers
SOURCE: IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Posted on Jun 02, 2009
SOURCE: Mouse Freezes
I have the same problem in Vista, I found a true and working solution apart of droping the mouse to the trash, ok, go to... http://www.a4tech.com/ go to the english version if you dont speak chinese, then find the driver for the mouse model ***-49Z, and there is the solution, GE isnt the builder of this mouse.
Take Care.
HMMxD
Greetings from Mexico.
Posted on Jul 15, 2009
SOURCE: My Gigaware optical mouse's cursor won't move
I had the same problem, so I tried replacing the battery, and the problem persisted. Took the battery out again, put it back again, and repeated several times to no avail. Took the battery out again, rubbed the metal contacts in the battery compartment with my fingertip to remove any dirt, replaced the battery, and then the mouse started to work normally.
Posted on Jan 05, 2012
I have a usb wired dynex optical mouse, i just bought a Toshiba sattelite laptop and external mouse does not work when i plug into usb port
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a buuon or switch on top or bottom
hope this helps
Jul 01, 2011 | Computers & Internet
My USB and windows vista does not recognize my new optical mouse from GE SKU# is 98543, my motherboard is an ASUS M2N-MX SE, my other optical mouse works fine but when i plug the RF receiver into the usb...
first check the battery inside the mouse make sure it is fully charged and well seated
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
also click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark !or question mark ? or a red x right you will have options to update driver software,disable,uninstall,scan for hardware changes and properties hope this helps
Apr 01, 2011 | ASUS M2N-MX Motherboard
What is up with this mouse?? GE 98529, USB. It didn't come w/ a driver and I can't find on-line. Just a simple USB mouse.... Please help!
It shouldn't need a driver. It is a Plug and Play mouse. It might be bad, or the optical lens might need cleaned.
Have you tried it in another USB port?
Return it if you can and good luck!
Dec 15, 2010 | GE Optical 98802 Mouse
I have a GE wireless mouse = 98563, bought about 2 weeks ago and have used it only a couple of times however recently i have developed problems with it, I bought a new pack of triple As and even then the...
1. Go to manufacturer's website and download the driver for the correct MODEL of the mouse.
2. Install mouse driver. Go "Control Panel" to configure mouse software.
3. o/s XP, right mouse click "My Computer" go Properties, Hardware tab, Device Manager, scroll down to "Mice and other Pointing Devices" to see if it is registered, and also check "USB Human Interface Device" in the same window to see if your usb connections are functioning. There should be NO YELLOW question marks in this window pertaining to USB and Mice Pointing Devices.
If it was a wired mouse with no name or model, you can just plug it into the ports and it will work. Unfortunately, since it is wireless, you MUST have the correct drivers(software that allows your computer to communicate with the device), and the only way you can get the correct drivers is through the manufacturer and choose the right model.
ALSO
The USB device has what appears to be a circle with dots connected to it facing the port. The dots are actually the word "Connect" in infintessimally small letters. Plug it in, then use your thumb to press down on the circle while using another finger to press up on the device's underside - in effect, squeeze it between your fingers where the circle is. You'll see a red light blink. At that point you can push the "connect" button on your mouse and it will work.
Nov 20, 2010 | GE Wireless Optical Mouse
Fairly new mouse (new batteries also)not working. Solid blue light when plugged into USB port but cursor will not move at all when click mouse buttons or scroll bar. Rebooting system nor unplugging USB...
First make sure your mouse is installed properly. Go to Device Manager and see if it lists the mouse and has no conflicts. Also, try a different USB port, especially if it doesn't show up. If your receiver and mouse have reset or connect buttons on them you'll need to push those also. try alternate batteries. if none of these suggestions can solve your problem you may be looking at a defective mouse.
Nov 05, 2009 | GE Optical Mini Wireless Mouse 98793
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
I cant get any mouse to work on my dell laptop.
see the very first thing is that what u can try is that try and connect the same mouse that u had and that had worked and if works then the prob is with the mouse that u have right now and if that also doesnt work then the usb port on the laptop has gone bad and u need to replace the motherboard of the computer but before replacing the motherboard try and connect some other usb device on the same usb port.........
Jan 25, 2009 | KEIO PS2 Optical Scroll Mouse
Hi, I bought the new wireless optical mouse of ge.  I lost my owner's manual and don't know if I have all the parts.  Do I just need the mouse and my apple macbook pro to make it work.  can you tell me how...
The GE mouse came with a Receiver that goes into a USB port after the CD software program is installed. During installation the program will ask you to plug in the receiver into a USB port. This is when to do so. Then it should work properly.
Jan 20, 2009 | GE Wireless Optical Mouse
Usb connector
yes you require.and install the drivers of the wire less optical mouse to make use of the mouse.without installing drivers it will not support.
Nov 20, 2008 | GE Wireless Optical Mouse
#97985 optical mouse
You will have to go to the manufacturers website and download the driver and software for your mouse. Save the file then open it and install the driver. When you plug in your mouse again it should be recognized.
Dec 06, 2007 | GE Optical 98802 Mouse
Computers & Internet Logo
David Payne
David Payne
