Question about Dishwashers
Where are my questions about a touchdown drain? There are 2 that have been posted but I don't see them.
    Scholar:
    New Friend:
  • 53 Answers
Here is the third. Maybe leave bread crumbs next time.
Posted on Jan 11, 2014
The Danze touchdown stopper can be pushed down and it does not leak. It also will not pop back up no matter what, unless you can thumb-screw it backwards to get the stopper lid off. The rubber gasket seems...
This happened to mine too. I took it apart ( removed the whole part, then removed the cap ) clicked it a few times, stuck it back in, and it's worked fine ever since.
I'm going to say that it may be either a manufacturer thing, or perhaps there's some sort of build up going on.
Either way, you could try doing what I did, or contact Danze and ask for a refund. Maybe a different brand would be in order?
Oct 20, 2013 | Danze 1 1/2'' Touch Down Drain DANZE...
Touchdown stopper will not pop back up
The spring-loaded stopper mechanism may be clogged with hair, soap, and "gunk". Repair consists of removing the assembly, disassembling it (remembering the disassembly order of parts), cleaning all parts, and reassembling, testing, and reinstallation. Periodic maintenance will keep your stopper operating like new.
Oct 20, 2013 | Danze D495080AC 1 1/2'' Touch Down Drain -...
I have a project and i don't know what independent or dependent means
When conducting an experiment, a researcher usually has a dependent and independent variable. The independent variable is the variable that can be changed or manipulated (think of it as a cause). The dependent variable is the variable that depends on the independent variable (think effect).
For example, if you wanted to test whether practice improves an athlete's performance (lets say number of touchdowns):
  • Practicing (or not) is what you can manipulate. It is the independent variable.
  • Number of touchdowns is the dependent variable. The results depend on whether or not the athlete practiced.
Sep 07, 2013 | Finance
Are rugby games the same length as soccer games?
Rugby games are unique in that each one consists of two forty minute halves to make a total of eighty minutes game time. Like in soccer, some games can go slightly longer if no one has scored or if there are penalties.
Jan 14, 2013 | Rugby
Ford firing orders
Dennis - - I have been debating on contacting you or not.
Since I don't have any questions I guess the only way for you to speak to me is thru other people's questions which is not fair to them. Maybe I should post a question to give you an avenue to take to reach me.
Don't worry about how I answer questions. I have not been impressed with some of yours either. I answer questions when I think I can help the person asking.
When I post a solution I expect the person asking to engage in a conversation with me to find the answer. And most of my questions are actually suggestions they should have already checked on.
I will either post a question or provide you with my email address if you need to reach me.
Oct 10, 2011 | Cars & Trucks
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
DISHWASHER IS NOT DRAINING COMPLETELY, LEAVING ABOUT 2 IN OF WATER
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | KitchenAid KUDS301V 24 in. Built-in...
How to "Reply All" to an Exchange email on Android
What's stock on your device isn't necessarily the stock onothers. If the stock app doesn't meet your needs then you consideranother Exchange client. The stock email app on my Droid didn't have a lot of functionalitythat I wanted so I've been using Touchdown. Touchdown definitely does ReplyAll. Not sure if the stock app on my Droid does or not.
Have you only looked for a Reply All button? Have you tried long pressing on the email from the list oropening the email and accessing the menu to see if there's a Reply All optionthere?
Jul 21, 2011 | WeedMaps Android Apps
Dishwashers Logo
Top Dishwashers Experts
