Question about Garden
My gas clothes dryer shuts down when the burner comes on.
  • 1 more comment
  • Sam Wells Oct 25, 2013
    There is no pilot light but, yes the burner was coming on for just a short while and then everything woiuld shut down. After waiting a few minutes for it to cool off, it would run on "air only" cycle. Now, it is totally dead and will not start running at all.
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Oct 26, 2013
    I would be looking for a thermal safety switch...
  • Sam Wells Oct 26, 2013
    Thanks, Behind_Blue_Eyes, will do.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Is your pilot light/ignitor working correctly and the burner igniting ??? or does the unit think the burner isn't igniting causing it to shut down
Posted on Oct 22, 2013
Burner lights 5-10 seconds shuts down. Good air flow. Gas smell at times out vent.
The burner will shut off for various reasons.
First, there is a sensor right at the burner flame. If the sensor does not indicate flame the gas is shut off to avoid filling your house with gas. It is usually a short metal rod. Oftentimes cleaning it will get it working again. Or the signal from the sensor isn't getting back to the controller, so check for loose connections.
This page explains it well.
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/flamesensor.php
There are some other sensors that will shut the heat down. A temp sensor where the hot air leaves the dryer drum. This is to keep from overheating the clothes and lighting them on fire. If this sensor is bad, or the wiring to it is not getting that signal back to the controller, the dryer will shut the burner down. Although 10-15 seconds is pretty short, this is a possibility. Try different heat settings to see if you get the same result. If it only happens on one heat setting you most likely have a bad temp sensor.
Visit here for more info.
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/thermostat.php
Another possibility is that the gas valve (solenoid) is getting near the end of its life and can't stay open long. This is not likely, but still possible since the burner does light.
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/gascoil.php
Next possibility is that the gas line is partially plugged. When the burner fires the gas pressure drops rapidly. When the burner goes out the gas sneaking past the obstruction raises the pressure back up.
Final possibility is a bad controller.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
Tappan gas clothes dryer: Burner problem
Two possibilities are the coils on the valve or the valve its self. MOST cases the soils are the problem. How old is it? Do the coils on the valve have quick connects or are there wires coming out of them?
Let me know if I can help further.
Vic
May 10, 2009 | Dryers
Low dry temperature
check your air flow it could be a clogged or pinched vent pipe
Dec 20, 2008 | Maytag Neptune MDG9700A Gas Dryer
Dryer is gas model dg212 flame come on but will not stay on long enough to dry clothes
if burner lights but fails to relight after several shut offs suspect burners solenoids change both they come in a kit ..once the solenoids get hot they will sometimes open electrically and fail to reenergize after cool down they will open gas valve and alow burner to reignite..also be sure vent to outside to clean and vent behind dryer is not flattened or kinked has know flame to not be properly burning due to exhaust problems and flame sensor would shut burner down
Sep 16, 2008 | Maytag Dryers
Frigidaire gas dryer, burner lights but gets shut off immediately
ckd coils on burner /valve they are probably breaking down..be sure you have good gas supply sounds almost like low or no gas pressure but believe you'll find coils bad
Jun 18, 2008 | Dryers
Gas dryer (similar machine) gets hot and shuts off burner
hi thanks for the question All dryers should be cleaned once a year. and proper venting . clean out well & try again . Thanks the appliance doc
Jun 02, 2008 | Whirlpool LGQ9858PG Gas Dryer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
