Question about HP Color LaserJet 2600n Printer
All colors printout is fade after cleaning lens
  • 40 Answers
I have had this problem before and had to replace the print head/lense unit, as you have cleaned the lenses.
Posted on Oct 21, 2013
I have a problem with the colour prints...there are different kind of lines all over the page..how can i clean the laser heads?is there any automatically way?
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer is clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Try cleaning the toners and see if it makes any difference. You would also have an idea about the toner drum/ parts quality etc and check if they need to be replaced. Furthermore, issues with Laser Unit like dust/ toner dust on the lenses and mirrors inside the printer usually result in faded or discolored prints. For instance, faded text/ picture at certain areas or any color missing when you print.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
The screen looks faded. The colors are right, but
take off the front of the set, and clean the lens as well as the mirrors inside the tv set
Techman
Dec 14, 2009 | Sony KP-53XBR200 53" Rear Projection...
The ink cartridges are full but when i print the colors are faded the red becomes pink and so on
You are lacking yellow on your printouts from what it sounds like. You need to find a printhead nozzle cleaning option in the driver or utilities that installed with the printer. Consult the manual if unsure.
Oct 23, 2009 | Canon Office Equipment & Supplies
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Lines at the top and bottom of landscape printout
Without seeing the lines but you said they are colored I would guess the color pcu needs to be replaced.
Jul 10, 2009 | Ricoh Aficio CL3500N Laser Printer
Printing is Faded
Either your printhead needs cleaning or replacing. There is a known problem with Kodak's earlier models.
http://www.fixya.com/support/t412457-kodak_5300_print_black
May 23, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer doesn't print well
Hav you replaced with original cartridges or 3rd party/refilled ones? This is a common problem when using generic/refilled cartridges. Let me know that first..
When you say poor quality, do you mean faded printouts, or broken print? Kindly explain in detail, so I can assist you further.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Light, Faint or Faded Copies
How is the quality when you just scan a document?
Dec 07, 2007 | Lexmark X83 All-In-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
