Question about Radio Communications
Motor wont start in park but will in nuetral - Radio Communications
    Problem Solver:
  • 16 Answers
Most likely is a neutral safety switch. This switch is also called a prindle switch or a transmission gear select switch. It's very common for these to fail on jeeps but I have seen them fail on other makes as well
Posted on Oct 22, 2013
  • Radio Commun... Master
  • 1,654 Answers
There are a variety of problems which could present this issue on a vehicle. It varies by make and brand of automobile, but some suspect items might include a shifter which is not seating well into park, a worn indicator switch in the steering column, as well as another switch which indicates your foot is on the brake pedal.
One quick thing to check is that the car, if setting on level ground has actually locked the wheels into park. You can check this by having the car in park and giving a slight physical push to the car to see if it rolls a little then locks into park, or if it is already locked into park.
Best regards.
PS. This was posted in the two-way radio category.
Posted on Oct 21, 2013
Daewoo forklift D30s wont start
Hmm, Shifter in Nuetral or park? Parking brake fully engaged?
Seatbelt on ? and LP gas tank on?
Cheers
Aug 22, 2014 | Electronics - Others
Wont start in park
Do you have any code scanner to check the engine system?
Jun 24, 2013 | 1998 Audi A6
Only starts in nuetral
park nuetral switch on transmission may be bad.
Dec 17, 2012 | 1994 Plymouth Voyager
Crown vic 2000 wont crank ? battery, alternator,starter,starter relay all good ?
The problem is in the wiring harness,yes the battery and starter is good, the harness you repaired is the PRNDL. for the starter to start it need a path when the vehicle is Park or Nuetral,there the path is closed some how by Park and Nuetral the path is open.Thats why there is a no start.when in park or nuetral the path is closed.
Nov 12, 2012 | 2000 Ford Crown Victoria
My 2001 dodge durango will run, but once i park it it wont start again. If i play around with the shifter the truck will start, What is wrong with it?
Is this an Automatic transmission? If it is, and what is happening is that when you turn the key the starter will not engage, then you play with the shifter nob, and then it will start, then it is the
NUETRAL SAFETY SWITCH.
This is there to ensure that you cannot start the car in a gear, and will only start in either Park, or Nuetral. They go bad, just like anything else. Try starting the car with the gear-shifter in the NUETRAL position. I bet it will start.
Where the switch is located on this car, I am not sure, but it is not an expensive fix.
Jun 11, 2011 | 2001 Dodge Durango
My jeep wont start!
MOST LIKELY YOU WILL NEED TO REPLACE THE NUETRAL SAFETY SWITCH IT IS THE MOST COMMON CAUSE OF THIS PROBLEM, IT IS LOCATED ON THE TRANSMISSION CASE UNDER THE ARM THE TRANSMISSION SHIFT CABLE ATTACHES TO, SEE PHOTO BELOW.
STANDARD MOTOR PRODUCTS Part # NS113T [NUETRAL SAFETY SWITCH]
Jul 14, 2010 | 1992 Jeep Cherokee Limited
Will only start in nuetral
Neutral safety switch is bad or in need of adjustment
Jul 30, 2009 | Chevrolet Tahoe Cars & Trucks
Wont start in Park But will start in Nuetral
Neutral safety switch usually threaded into transmission, unless AW-4 model. Same switch used to trip back-up lights. Look for harness with approx 3-4 wires, unplug & unscrew switch from transmission.
Apr 11, 2009 | 1994 Jeep Grand Cherokee
Radio Communications Logo
27 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
